Discuss
LG Dishwasher 3 Flashing Lights Code LE
 in
Dishwasher Repair
My LG dishwasher LDF9932ST has started to fault out (most not all of the time) with 3 flashing blue lights,
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » LG Dishwasher 3 Flashing Lights Code LE
  #1 (permalink)
Old 04-29-2014, 09:37 AM
Junior Member
tulsatwisters is on a distinguished road
Default LG Dishwasher 3 Flashing Lights Code LE
Model Number: LDF9932ST   Brand: -other-   Age: 1 - 5 years
My LG dishwasher LDF9932ST has started to fault out (most not all of the time) with 3 flashing blue lights, and show the fault code LE, which I understand is a motor code. The dishwasher will run a couple of min, just long enough to fill with water, but then will fault out with the LE code.
I then will turn the breaker off and back on to reset the electronics and then restart the dishwasher and it will operate normally.
Again, it does not always fault out, but when it does it is always at the same point of time just after the dishwasher fills with water and once reset will always run normally.
This is driving me crazy, it does not seem to be a motor problem nor does it seem to be a loose electrical connection problem.
If it was the motor or electical problem then it would fault at other times and you would think it would falut out with the LE code at lest sometimes after turning the power of and on again, instead of working normally each time.
I think it might have something to do with the signal going to the motor after the fill cycle, but why only at the first couple of min of operation and why only once in a while and why never after resetting the power.
Plese help, thank you.
Related Models
 LDF9932ST Dishwasher
Admiral LDG1000AAE DRYER- GAS
Maytag LDG110 DRYER- GAS
Maytag LDG18CA MAYTAG LAUNDRY (DRYER GAS)
Maytag LDG18CM MAYTAG LAUNDRY (DRYER GAS)
Maytag LDG18CS MAYTAG LAUNDRY (DRYER GAS)
Maytag LDG18CT MAYTAG LAUNDRY (DRYER GAS)
Maytag LDG19CD MAYTAG LAUNDRY (DRYER GAS)
Maytag LDG19CS MANUAL, PARTS (DRYER GAS)
Maytag LDG19CT MANUAL, PARTS (DRYER GAS)
Maytag LDG210 DRYER- GAS
Maytag LDG212 DRYER- GAS
Maytag LDG21CS MAYTAG LAUNDRY (DRYER GAS)
Maytag LDG22CS MANUAL, PARTS (DRYER GAS)
Maytag LDG22CT MANUAL, PARTS (DRYER GAS)
Maytag LDG23CD MAYTAG LAUNDRY (DRYER GAS)
Maytag LDG24CA MAYTAG LAUNDRY (DRYER GAS)
Maytag LDG24CM MAYTAG LAUNDRY (DRYER GAS)
Maytag LDG24CS MAYTAG LAUNDRY (DRYER GAS)
Maytag LDG24CT MAYTAG LAUNDRY (DRYER GAS)
Maytag LDG25CS MAYTAG LAUNDRY (DRYER GAS)
Maytag LDG26CA MAYTAG COMMERCIAL LAUNDRY (DRYER GAS)
Maytag LDG26CD MAYTAG COMMERCIAL LAUNDRY (DRYER GAS)
Maytag LDG26CS MANUAL, PARTS (DRYER GAS)
Maytag LDG26CT MAYTAG COMMERCIAL LAUNDRY (DRYER GAS)
Maytag LDG27CA MANUAL, PARTS (DRYER GAS)
Maytag LDG27CD MAYTAG COMMERCIAL LAUNDRY (DRYER GAS)
Maytag LDG27CS MAYTAG LAUNDRY (DRYER GAS)
Maytag LDG27CT MAYTAG LAUNDRY (DRYER GAS)
Maytag LDG303 DRYER- GAS
Maytag LDG30CMD MANUAL, PARTS (DRYER GAS)
Maytag LDG312 DRYER- GAS
Maytag LDG313 DRYER- GAS
Maytag LDG31CA MAYTAG LAUNDRY (DRYER GAS)
Maytag LDG31CM MAYTAG LAUNDRY (DRYER GAS)
Maytag LDG31CT MAYTAG LAUNDRY (DRYER GAS)
Frigidaire LDG333PEW0 Frg(v0) / Gas Dryer
Maytag LDG33CA MANUAL, PARTS (DRYER GAS)
Maytag LDG33CM MAYTAG LAUNDRY (DRYER GAS)
Maytag LDG34CD MAYTAG LAUNDRY (DRYER GAS)
Maytag LDG34CQ MAYTAG LAUNDRY (DRYER GAS)
Maytag LDG382 DRYER- GAS
Maytag LDG4000 DRYER- GAS
Maytag LDG4000AAL DRYER- GAS
Maytag LDG4000AAW DRYER- GAS
Maytag LDG4000ABL DRYER- GAS
Maytag LDG4000ABW DRYER- GAS
Maytag LDG410 DRYER- GAS
Maytag LDG412 DRYER- GAS
Maytag LDG482 DRYER- GAS
Maytag LDG490 DRYER- GAS
Maytag LDG4910 DRYER- GAS
Maytag LDG4910AAL DRYER- GAS
Maytag LDG4910AAW DRYER- GAS
Maytag LDG4914AAE DRYER- GAS
Maytag LDG4914AAL DRYER- GAS
Maytag LDG4914AAM DRYER- GAS
Maytag LDG4916AAE DRYER- GAS
Maytag LDG4916AAM DRYER- GAS
Maytag LDG5004AAW DRYER- GAS
Maytag LDG5004ABW DRYER- GAS
Maytag LDG5005AAE DRYER- GAS
Maytag LDG5005ABE DRYER- GAS
Maytag LDG510 DRYER- GAS
Maytag LDG512 DRYER- GAS
Maytag LDG590 DRYER- GAS
Maytag LDG5910 DRYER- GAS
Maytag LDG5910AAL DRYER- GAS
Maytag LDG5910AAW DRYER- GAS
Maytag LDG5914AAE DRYER- GAS
Maytag LDG5914AAL DRYER- GAS
Maytag LDG5914AAM DRYER- GAS
Maytag LDG5916AAE DRYER- GAS
Maytag LDG5916AAM DRYER- GAS
Maytag LDG6004AAW DRYER- GAS
Maytag LDG610 DRYER- GAS
Maytag LDG612 DRYER- GAS
Maytag LDG6914AAE DRYER- GAS
Maytag LDG6914AAL DRYER- GAS
Maytag LDG6914AAM DRYER- GAS
Maytag LDG710 DRYER- GAS
Maytag LDG712 DRYER- GAS
Maytag LDG713 DRYER- GAS
Maytag LDG7304AAE DRYER- GAS
Maytag LDG7304AAL DRYER- GAS
Maytag LDG7304AAM DRYER- GAS
Maytag LDG7304ABE DRYER- GAS
Maytag LDG7304ABL DRYER- GAS
Maytag LDG7304ABM DRYER- GAS
Maytag LDG7304AGE DRYER- GAS
Maytag LDG7304AGL DRYER- GAS
Maytag LDG7304AGM DRYER- GAS
Maytag LDG7304EGE DRYER- GAS
Maytag LDG7304EGL DRYER- GAS
Maytag LDG7304EGM DRYER- GAS
Maytag LDG7314AAE DRYER- GAS
Maytag LDG7314AAL DRYER- GAS
Maytag LDG7314AAM DRYER- GAS
Maytag LDG7334AAE DRYER- GAS
Maytag LDG7334AAL DRYER- GAS
Maytag LDG7334AAM DRYER- GAS
Maytag LDG7400 DRYER- GAS
Maytag LDG7400AAL DRYER- GAS
Maytag LDG7400AAW DRYER- GAS
Maytag LDG7400ABL DRYER- GAS
Maytag LDG7400ABW DRYER- GAS
Maytag LDG7480AAL DRYER- GAS
Maytag LDG7480AAW DRYER- GAS
Maytag LDG7480ABL DRYER- GAS
Maytag LDG7480ABW DRYER- GAS
Maytag LDG7500 DRYER- GAS
Maytag LDG7500AAE DRYER- GAS
Maytag LDG7500AAL DRYER- GAS
Maytag LDG7500AAM DRYER- GAS
Maytag LDG7500AAW DRYER- GAS
Maytag LDG7500ABE DRYER- GAS
Maytag LDG7500ABL DRYER- GAS
Maytag LDG7500ABM DRYER- GAS
Maytag LDG7500ABW DRYER- GAS
Maytag LDG7600 DRYER- GAS
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Kenmore Dishwasher panel lights are flashing a code bbenton8 Dishwasher Repair 0 07-01-2013 07:01 AM
Error code and lights flashing-Frigidaire Dishwasher tocruise-2007 Dishwasher Repair 0 01-27-2013 01:44 PM
Two fault code lights flashing hobnob Dishwasher Repair 0 09-09-2010 10:31 AM
interpret flashing lights to error code toquey Oven Repair (including Ranges and Cooktops) 0 10-01-2009 04:15 PM
Flashing control lights & code F-70 ernstbankst Dryer Repair 0 03-16-2009 05:40 PM
