Discuss
Kenmore Dishwasher not filling up with water
 in
Dishwasher Repair
Hi, I was hoping that someone might be able to direct me as to how to diagnosis a problem that
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » Kenmore Dishwasher not filling up with water
  #1 (permalink)
Old 04-25-2014, 11:20 AM
Junior Member
Bukwas is on a distinguished road
Default Kenmore Dishwasher not filling up with water
Model Number: 363.14398991   Brand: Kenmore   Age: 5 - 10 years
Hi, I was hoping that someone might be able to direct me as to how to diagnosis a problem that I am having with a dishwasher in an apartment. It's a Kenmore Dishwasher, model number: 363.14398991
The dishwasher does not seem to be filling up with water.
I've performed the following checks.
1. Checked float, looks ok
2. Checked float switch, continuity is good.
3. Unplugged connector from water inlet value. Started dishwasher and was looking for 120 volts in the connector. All I saw was .7 Volts.
I even ran the same test with the float switch removed and I connected the wires together to remove the switch from the equation.
Is the next step to check and/or replace the timer?
Thank you,
brett
Related Models
Kenmore 3631401190 DISHWASHER
Kenmore 3631401191 DISHWASHER
Kenmore 3631401590 DISHWASHER
Kenmore 3631401591 DISHWASHER
Kenmore 3631401592 DISHWASHER
Kenmore 3631401890 DISHWASHER
Kenmore 3631401891 DISHWASHER
Kenmore 3631401892 DISHWASHER
Kenmore 3631402190 DISHWASHER
Kenmore 3631402191 KENMORE DISHWASHER
Kenmore 3631402192 DISHWASHER
Kenmore 3631402590 DISHWASHER
Kenmore 3631402591 DISHWASHER
Kenmore 3631402592 DISHWASHER
Kenmore 3631402890 DISHWASHER
Kenmore 3631402891 KENMORE DISHWASHER
Kenmore 3631402892 DISHWASHER
Kenmore 36314031000 DISHWASHER
Kenmore 36314031001 DISHWASHER
Kenmore 36314032000 DISHWASHER
Kenmore 36314032001 DISHWASHER
Kenmore 36314038000 DISHWASHER
Kenmore 36314038001 DISHWASHER
Kenmore 36314039000 DISHWASHER
Kenmore 36314039001 DISHWASHER
Kenmore 3631404193 DISHWASHER
Kenmore 3631404194 DISHWASHER
Kenmore 3631404196 DISHWASHER
Kenmore 3631404197 DISHWASHER
Kenmore 3631404593 DISHWASHER
Kenmore 3631404594 DISHWASHER
Kenmore 3631404595 DISHWASHER
Kenmore 3631404596 DISHWASHER
Kenmore 3631404597 DISHWASHER
Kenmore 3631404893 DISHWASHER
Kenmore 3631404894 DISHWASHER
Kenmore 3631404895 DISHWASHER
Kenmore 3631404896 DISHWASHER
Kenmore 3631404897 DISHWASHER
Kenmore 36314051690 DISHWASHER
Kenmore 36314051691 DISHWASHER
Kenmore 36314061790 AUTOMATIC DISHWASHER
Kenmore 36314061791 DISHWASHER
Kenmore 36314071790 AUTOMATIC DISHWASHER
Kenmore 36314071791 DISHWASHER
Kenmore 36314071792 DISHWASHER
Kenmore 36314071793 DISHWASHER
Kenmore 36314071794 DISHWASHER
Kenmore 36314072790 AUTOMATIC DISHWASHER
Kenmore 36314072791 DISHWASHER
Kenmore 36314072792 DISHWASHER
Kenmore 36314072793 DISHWASHER
Kenmore 36314072794 DISHWASHER
Kenmore 36314072795 DISHWASHER
Kenmore 36314074790 AUTOMATIC DISHWASHER
Kenmore 36314074791 DISHWASHER
Kenmore 36314074792 DISHWASHER
Kenmore 36314074793 DISHWASHER
Kenmore 36314074794 DISHWASHER
Kenmore 36314075790 AUTOMATIC DISHWASHER
Kenmore 36314075791 DISHWASHER
Kenmore 36314075792 DISHWASHER
Kenmore 36314075793 DISHWASHER
Kenmore 36314075794 DISHWASHER
Kenmore 36314081990 DISHWASHER
General Electric 36314081991 DISHWASHER
Kenmore 36314081992 DISHWASHER
Kenmore 36314081993 DISHWASHER
Kenmore 36314081994 DISHWASHER
Kenmore 3631410690 DISHWASHER
Kenmore 3631410691 DISHWASHER
Kenmore 3631410692 DISHWASHER
Kenmore 3631410693 DISHWASHER
Kenmore 3631410694 DISHWASHER
Kenmore 3631411690 DISHWASHER
Kenmore 3631411691 KENMORE DISHWASHER
Kenmore 3631411692 DISHWASHER
Kenmore 36314141690 DISHWASHER
Kenmore 3631414593 DISHWASHER
Kenmore 3631414594 DISHWASHER
Kenmore 3631414595 DISHWASHER
Kenmore 3631414596 DISHWASHER
Kenmore 3631414597 DISHWASHER
Kenmore 3631414598 DISHWASHER
Kenmore 3631414691 DISHWASHER
Kenmore 36314151000 DISHWASHER
Kenmore 36314152000 DISHWASHER
Kenmore 36314158000 DISHWASHER
Kenmore 36314159000 DISHWASHER
Kenmore 36314171790 AUTOMATIC DISHWASHER
Kenmore 36314171791 DISHWASHER
Kenmore 36314171792 DISHWASHER
Kenmore 36314172790 AUTOMATIC DISHWASHER
Kenmore 36314172791 DISHWASHER
Kenmore 36314172792 DISHWASHER
Kenmore 36314174790 AUTOMATIC DISHWASHER
Kenmore 36314174791 DISHWASHER
Kenmore 36314175790 AUTOMATIC DISHWASHER
Kenmore 36314175791 DISHWASHER
Kenmore 36314181200 DISHWASHER
Kenmore 36314181202 DISHWASHER
Kenmore 36314191990 DISHWASHER
Kenmore 36314191991 DISHWASHER
Kenmore 36314191992 DISHWASHER
Kenmore 36314191993 DISHWASHER
Kenmore 36314192990 DISHWASHER
Kenmore 36314192991 DISHWASHER
Kenmore 36314192992 DISHWASHER
Kenmore 36314192993 DISHWASHER
Kenmore 36314194990 DISHWASHER
Kenmore 36314194991 DISHWASHER
Kenmore 36314194992 DISHWASHER
Kenmore 36314194993 DISHWASHER
Kenmore 36314195990 DISHWASHER
Kenmore 36314195991 DISHWASHER
Kenmore 36314195992 DISHWASHER
Kenmore 36314195993 DISHWASHER
Kenmore 36314231100 DISHWASHER
Kenmore 36314232100 DISHWASHER
Kenmore 36314234100 DISHWASHER
  #2 (permalink)
Old 04-26-2014, 02:56 AM
Senior Expert
APP Volunteer
denman is a splendid one to behold
Default
Yes it is probably the timer.
To double check you could measure the fill valve/ float switch circuit at the timer usinf resistance to see if all the wiring is OK. I am not sure what the fill valve resistance should be so I would measure across it first.
I do not have access to GE wiring diagrams so unless you have it you will have to trace the wires.
__________________
  #3 (permalink)
Old 04-28-2014, 07:59 AM
Junior Member
Default
Thank you. I'm going to order the timer and swap it out. I'll update the thread with the results.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Kenmore Washer not filling up with water Jamielynn Washer Repair 1 12-08-2012 04:08 PM
Kenmore dishwasher not filling weekendrailroader Dishwasher Repair 1 10-09-2010 03:39 PM
Kenmore Dishwasher not filling Castrok Dishwasher Repair 4 07-13-2010 04:47 PM
Kenmore series 80 hot water will not stop filling rodney482 Washer Repair 2 09-07-2009 11:58 AM
Kenmore Washer Keeps Filling w/water devilduck81 Washer Repair 0 10-29-2007 05:16 PM
