Discuss
Pressure switch is disconnected - Is that normal?
 in
Dishwasher Repair
Hello esteemed community. I have a Kenmore 17372 dishwasher. All of a sudden, it stopped filling with water. - I
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » Pressure switch is disconnected - Is that normal?
  #1 (permalink)
Old 04-24-2014, 03:25 PM
Junior Member
Bmachine is on a distinguished road
Default Pressure switch is disconnected - Is that normal?
Model Number: 17372   Brand: Kenmore   Age: 5 - 10 years
- I checked the float and its switch and that seems ok.
- I checked the voltage at the inlet pump and it is ok.
- Water pressure to the dw has not changed and is fine
- When I turn the dw on, I clearly hear water passing through the valve which is puzzling. Then a small amount of water seems to fill the sump and before it reaches the usual level of the float, it stops filling up and starts "washing".
Since the dw is 8 years old I went ahead and ordered a new valve, thinking it might be on its way out soon anyway.
But while I was under there, I noticed an odd thing: Both connectors to the pressure switch are disconnected. Since I am quite sure I did not do that, and no one has been under there that I remember, I wonder if it was like this since new. Is there any reason you guys can think of why that would be disconnected? Is there any reason not to reconnect? We are not having any draining issues. Probably because I take the whole motor sump assembly apart once a years to clean out all the gunk in there...
Thank you very much for any help.
Bo.
Related Models
Amana 1739.000 MWAVE - FAMILY SIZE (60 HZ)
Amana 1739.001 MWAVE - FAMILY SIZE (60 HZ)
Whirlpool 1743W0A
Roper 1745*0A 30" GAS DOUBLE OVEN RANGE
Roper 1745W0A 30" GAS DOUBLE OVEN RANGE
Amana 1750.000 MWAVE - FAMILY SIZE (60 HZ)
Amana 1752.000 MWAVE - FAMILY SIZE (60 HZ)
Amana 1752.001 MWAVE - FAMILY SIZE (60 HZ)
Kenmore 17550125 GARBAGE DISPOSAL
Kenmore 17560101 DISPOSER (IN-SINK-ERATOR)
Kenmore 17560102 DISPOSER
Kenmore 17560110 KENMORE DISPOSER
Kenmore 17560111 DISPOSER (IN-SINK-ERATOR)
Kenmore 17560111X KENMORE DISPOSER
Kenmore 17560115 KENMORE DISPOSER
Kenmore 17560120 KENMORE DISPOSER
Kenmore 17560121 DISPOSER (IN-SINK-ERATOR)
Kenmore 17560122 KENMORE DISPOSER
Kenmore 17560130 KENMORE DISPOSER
Kenmore 17560131 DISPOSER (IN-SINK-ERATOR)
Kenmore 17560135 KENMORE DISPOSER
Kenmore 17560200 FOOD WASTE DISPOSER
Kenmore 17560300 KENMORE DISPOSER
Kenmore 17560350 DISPOSER (IN-SINK-ERATOR)
Kenmore 17560351X KENMORE DISPOSER
Kenmore 17560400 KENMORE DISPOSER
Kenmore 17560400A KENMORE DISPOSER
Kenmore 17560401 DISPOSER (IN-SINK-ERATOR)
Kenmore 17560450 DISPOSER
Kenmore 17560451 DISPOSER
Kenmore 17560452 DISPOSER
Kenmore 17560500 KENMORE DISPOSER
Kenmore 17560500A KENMORE DISPOSER
Kenmore 17560500X KENMORE DISPOSER
Kenmore 17560501 DISPOSER (IN-SINK-ERATOR)
Kenmore 17560503 KENMORE DISPOSER
Kenmore 17560504 DISPOSER (IN-SINK-ERATOR)
Kenmore 17560504X KENMORE DISPOSER
Kenmore 175605090 DISPOSER (IN-SINK-ERATOR)
Kenmore 17560510 KENMORE DISPOSER
Kenmore 17560510A KENMORE DISPOSER
Kenmore 17560511 DISPOSER (IN-SINK-ERATOR)
Kenmore 175605140 DISPOSER (IN-SINK-ERATOR)
Kenmore 175605150 DISPOSER (IN-SINK-ERATOR)
Kenmore 175605160 DISPOSER (IN-SINK-ERATOR)
Kenmore 17560517 DISPOSER (IN-SINK-ERATOR)
Kenmore 17560517X KENMORE DISPOSER
Kenmore 175605250 DISPOSER (IN-SINK-ERATOR)
Kenmore 17560542 KENMORE HOT WATER DISPENSER
Kenmore 175605520 DISPOSER
Kenmore 17560552CE DISPOSER
Kenmore 175605530 DISPOSER
Kenmore 175605540 DISPOSER
Kenmore 17560554CE DISPOSER
Kenmore 17560555 DISPOSER (IN-SINK-ERATOR)
Kenmore 175605560 DISPOSER
Kenmore 175605590 DISPOSER
Kenmore 17560560 DISPOSER
Kenmore 17560563 GARBAGE DISPOSAL
Kenmore 17560572 FOOD WASTE DISPOSER
Kenmore 17560580 KENMORE DISPOSER
Kenmore 175605810 DISPOSER
Kenmore 17560700 DISPOSER (IN-SINK-ERATOR)
Kenmore 17560720 KENMORE DISPOSER
Kenmore 17560721 DISPOSER (IN-SINK-ERATOR)
Kenmore 175607930 DISPOSER
Kenmore 17560950 HOT WATER DISPENSER
Kenmore 17560960 HOT WATER DISPENSER
Kenmore 17561055 DISPOSER (IN-SINK-ERATOR)
Kenmore 175610550 DISPOSER (IN-SINK-ERATOR)
Kenmore 175610551 DISPOSER (IN-SINK-ERATOR)
Kenmore 17561090 DISPOSER
Kenmore 17565220 KENMORE DISPOSER
Kenmore 17565223 KENMORE DISPOSER
Kenmore 17565225 KENMORE DISPOSER
Kenmore 17565230 KENMORE DISPOSER
Kenmore 17565233 KENMORE DISPOSER
Kenmore 17565240 KENMORE DISPOSER
Kenmore 17565243 KENMORE DISPOSER
Kenmore 17565245 KENMORE DISPOSER
Kenmore 17565250 LADY KENMORE DISPOSER
Kenmore 17565253 LADY KENMORE DISPOSER
Kenmore 17565260 LADY KENMORE DISPOSER
Kenmore 17565263 KENMORE DISPOSER
Kenmore 17565280 KENMORE DISPOSER
Kenmore 17565290 KENMORE DISPOSER
Kenmore 17565323 KENMORE DISPOSER
Kenmore 17565324 KENMORE DISPOSER
Kenmore 17565325 KENMORE DISPOSER
Kenmore 17565360 KENMORE DISPOSER
Kenmore 17565370 KENMORE DISPOSER
Kenmore 17565380 KENMORE DISPOSER
Kenmore 17565390 KENMORE DISPOSER
Kenmore 17566440 KENMORE DISPOSER
Kenmore 17566441 KENMORE DISPOSER
Kenmore 17566442 KENMORE DISPOSER
Kenmore 17566443 KENMORE DISPOSER
Kenmore 17566450 KENMORE DISPOSER
Kenmore 17566451 KENMORE DISPOSER
Kenmore 17566452 KENMORE DISPOSER
Kenmore 17566453 KENMORE DISPOSER
Kenmore 17566480 KENMORE DISPOSER
Kenmore 175664801 KENMORE DISPOSER
Kenmore 17566482 KENMORE DISPOSER
Kenmore 17566484 KENMORE DISPOSER
Kenmore 17566488 KENMORE DISPOSER
Kenmore 17566490 KENMORE DISPOSER
Kenmore 17566491 KENMORE DISPOSER
Kenmore 17566492 KENMORE DISPOSER
Kenmore 17566494 KENMORE DISPOSER
Kenmore 17566495 KENMORE DISPOSER
Kenmore 17566500 KENMORE DISPOSER
Kenmore 17566501 KENMORE DISPOSER
Kenmore 17566502 KENMORE DISPOSER
Kenmore 17566503 KENMORE DISPOSER
Kenmore 17566510 KENMORE DISPOSER
Kenmore 17566511 KENMORE DISPOSER
Kenmore 17566513 KENMORE DISPOSER
Kenmore 17566515 KENMORE DISPOSER
Kenmore 17566517 KENMORE DISPOSER
  #2 (permalink)
Old 04-25-2014, 05:01 AM
Senior Expert
APP Volunteer
denman is a splendid one to behold
Default
Your model number is not complete.
Please check it.
Kenmore numbers are usually 3 digits, a period and then an additional 8 digits.
__________________
  #3 (permalink)
Old 04-25-2014, 08:54 AM
Junior Member
Default
Sorry about that. That is what is written on the door frame.
I see a longer version on the bill:
6651737201
Does that help?
Thank you
Bo
  #4 (permalink)
Old 04-25-2014, 05:18 PM
Senior Expert
APP Volunteer
Default
Sorry but I cannot find any info on the given model number .
Tried at AppliancePartsPros and the Sears parts site.
__________________
  #5 (permalink)
Old 04-25-2014, 05:59 PM
Junior Member
Default
I appreciate your help very much, denman.
I found another version of the number inside the door. This time it is "spelled" like this:
665.17372301
Thank you
Bo
  #6 (permalink)
Old 04-26-2014, 02:47 AM
Senior Expert
APP Volunteer
Default
OK that number did come up.
Parts for Kenmore Dishwasher 66517372301 - AppliancePartsPros.com
If you go to the Sears parts site they have actual parts breakdown diagrams.
Unfortunately they do not share these with other parts vendors.
See the attachment for the units tech sheet.
I cannot say why the pressure switch is disconnected but this should not effect the fill so was probably disconnected from day one.
If you look a part up on AppliancePartsPros often there will be more views and a Q&A section about that part.
You mentioned the float. This is just a safety device to prevent over fills (floods). Fill is just a timed event.
I would remove and check the fill valve.
There is a screen filter on the input side of the valve which may be dirty and might just need cleaning.
Do not permanently remove the screen as it is there to keep crud out of the valve which could hold the valve open and cause a flood.
You have one on order so that will most likely solve your fill problem.
Since you are working on it you may as well give the pump a cleaning.
__________________
  #7 (permalink)
Old 04-26-2014, 11:14 AM
Junior Member
Default
Thank you very much denman. Very useful info.
I received my replacement inlet valve yesterday and installed it. It now works perfect! The screen was very clean so that was not the problem. The only difference I noticed between the new and the old valve was that the new valve read 1.2 ohms while the other one was more like 920 ohms. Not a huge difference. But evidently enough to cause water to stop filling before it reached normal level. Odd.
But back to the main original question: The unplugged pressure switch. I will reconnect and see what that does. But, what does that pressure switch do exactly? The schematic just says that it measures the soil amount. Does it measure the outgoing water pressure? And then what happened once it detects too much or too little pressure? Does it switch the chopper on to grind some of the food debris?
Thank you.
Bo
  #8 (permalink)
Old 04-27-2014, 05:56 AM
Senior Expert
APP Volunteer
Default
Yes and yes
If it senses soil then I think it adds another rinse cycle.
No the3 chopper is always on.
__________________
  #9 (permalink)
Old 04-28-2014, 07:16 AM
Junior Member
Default
OK, thank you very much for your info, penman.
I will reconnect it.
Bo
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
is it normal to fail pressure test? saturnstroll Oven Repair (including Ranges and Cooktops) 0 11-14-2013 11:15 AM
Disconnected wire to oven lock switch Another Device Oven Repair (including Ranges and Cooktops) 0 07-25-2012 09:41 AM
pressure switch donnadale@myfrontiermail. Washer Repair 1 07-20-2012 02:28 AM
Will Dryer Work With The Door Switch Disconnected? Justmenky Dryer Repair 4 02-07-2009 05:28 PM
Water Does Not Stop/hose Disconnected To Pressure Switch JANEY2008 Washer Repair 1 05-13-2008 05:53 AM
