Won't drain fully
Dishwasher Repair
When cycle completes, there is an inch of water in bottom and dishes are not clean with soap spotting. Only
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » Won't drain fully
  #1 (permalink)
Old 04-23-2014, 08:11 AM
Junior Member
mwmcdona is on a distinguished road
Default Won't drain fully
Model Number: 16831792   Brand: Sears   Age: More than 10 years
When cycle completes, there is an inch of water in bottom and dishes are not clean with soap spotting. Only way to evacuate water is to run CANCEL/DRAIN function prior to new load. Have checked drain line for restriction-none.
I gravitate towards rebuilding pump if all controller sequencing is time based then it stands to reason if pump efficiency is off it will empty slower.
Could it be a controller issue?
How can I troubleshoot?
Related Models
Hoover 168691
Magic Chef 16RA-3B RV RANGE- GAS
Magic Chef 16RA-3B-49 RV RANGE- GAS
Magic Chef 16RA-3BK RV RANGE- GAS
Magic Chef 16RA-3BKZ RV RANGE- GAS
Magic Chef 16RA-3BT RV RANGE- GAS
Magic Chef 16RA-3BT49 RV RANGE- GAS
Magic Chef 16RA-3BTZ RV RANGE- GAS
Magic Chef 16RA-3BZ RV RANGE- GAS
Magic Chef 16RA-4 RV RANGE- GAS
Magic Chef 16RA-4K RV RANGE- GAS
Magic Chef 16RA-4KZ RV RANGE- GAS
Magic Chef 16RA-4T RV RANGE- GAS
Magic Chef 16RA-4TZ RV RANGE- GAS
Magic Chef 16RA-4Z RV RANGE- GAS
Magic Chef 16RB-3B RV RANGE- GAS
Magic Chef 16RB-3BT RV RANGE- GAS
Magic Chef 16RB-3BTZ RV RANGE- GAS
Magic Chef 16RB-3BZ RV RANGE- GAS
Magic Chef 16RB-4 RV RANGE- GAS
Magic Chef 16RB-4KZ RV RANGE- GAS
Magic Chef 16RB-4TZ RV RANGE- GAS
Magic Chef 16RB-4Z RV RANGE- GAS
Magic Chef 16RS-4 RV RANGE- GAS
Magic Chef 16RS-4K RV RANGE- GAS
Magic Chef 16RS-4T RV RANGE- GAS
Magic Chef 16RS-4Z RV RANGE- GAS
Magic Chef 16RW-3B RV RANGE- GAS
Magic Chef 16RW-3B-49 RV RANGE- GAS
Magic Chef 16RW-3BK RV RANGE- GAS
Magic Chef 16RW-3BKZ RV RANGE- GAS
Magic Chef 16RW-3BT RV RANGE- GAS
Magic Chef 16RW-3BT49 RV RANGE- GAS
Magic Chef 16RW-3BTZ RV RANGE- GAS
Magic Chef 16RW-4 RV RANGE- GAS
Magic Chef 16RW-4K RV RANGE- GAS
Magic Chef 16RW-4KZ RV RANGE- GAS
Magic Chef 16RW-4T RV RANGE- GAS
Magic Chef 16RW-4TZ RV RANGE- GAS
Magic Chef 16RW-4Z RV RANGE- GAS
Magic Chef 16TA-3B-49 RV RANGE- GAS
Magic Chef 16TA-3BK49 RV RANGE- GAS
Magic Chef 16TA-3BZ RV RANGE- GAS
Magic Chef 16TA-4Z RV RANGE- GAS
Magic Chef 16TB-3B RV RANGE- GAS
Magic Chef 16TB-3BK RV RANGE- GAS
Magic Chef 16TB-3BZ RV RANGE- GAS
Magic Chef 16TB-4 RV RANGE- GAS
Magic Chef 16TW-3B RV RANGE- GAS
Magic Chef 16TW-3B-49 RV RANGE- GAS
Magic Chef 16TW-3BK RV RANGE- GAS
Magic Chef 16TW-3BK49 RV RANGE- GAS
Magic Chef 16TW-3BKE RV RANGE- GAS
Magic Chef 16TW-3BKZ RV RANGE- GAS
Magic Chef 16TW-3BZ RV RANGE- GAS
Magic Chef 16TW-4KZ RV RANGE- GAS
Thermador 1701
Amana 1708.000 MWAVE - FAMILY SIZE (60 HZ)
Amana 1708.001 MWAVE - FAMILY SIZE (60 HZ)
Amana 1709.000 MWAVE - FAMILY SIZE (60 HZ)
Amana 1709.001 MWAVE - FAMILY SIZE (60 HZ)
Amana 1718.000 MWAVE - FAMILY SIZE (60 HZ)
Amana 1718.001 MWAVE - FAMILY SIZE (60 HZ)
Amana 1720.000 MWAVE - FAMILY SIZE (60 HZ)
Amana 1736.000 MWAVE - FAMILY SIZE (60 HZ)
Amana 1736.001 MWAVE - FAMILY SIZE (60 HZ)
Amana 1739.000 MWAVE - FAMILY SIZE (60 HZ)
Amana 1739.001 MWAVE - FAMILY SIZE (60 HZ)
Whirlpool 1743W0A
Amana 1750.000 MWAVE - FAMILY SIZE (60 HZ)
Amana 1752.000 MWAVE - FAMILY SIZE (60 HZ)
Amana 1752.001 MWAVE - FAMILY SIZE (60 HZ)
Kenmore 17550125 GARBAGE DISPOSAL
Kenmore 17560101 DISPOSER (IN-SINK-ERATOR)
Kenmore 17560102 DISPOSER
Kenmore 17560110 KENMORE DISPOSER
Kenmore 17560111 DISPOSER (IN-SINK-ERATOR)
Kenmore 17560111X KENMORE DISPOSER
Kenmore 17560115 KENMORE DISPOSER
Kenmore 17560120 KENMORE DISPOSER
Kenmore 17560121 DISPOSER (IN-SINK-ERATOR)
Kenmore 17560122 KENMORE DISPOSER
Kenmore 17560130 KENMORE DISPOSER
Kenmore 17560131 DISPOSER (IN-SINK-ERATOR)
Kenmore 17560135 KENMORE DISPOSER
Kenmore 17560200 FOOD WASTE DISPOSER
Kenmore 17560300 KENMORE DISPOSER
Kenmore 17560350 DISPOSER (IN-SINK-ERATOR)
Kenmore 17560351X KENMORE DISPOSER
Kenmore 17560400 KENMORE DISPOSER
Kenmore 17560400A KENMORE DISPOSER
Kenmore 17560401 DISPOSER (IN-SINK-ERATOR)
Kenmore 17560450 DISPOSER
Kenmore 17560451 DISPOSER
Kenmore 17560452 DISPOSER
Kenmore 17560500 KENMORE DISPOSER
Kenmore 17560500A KENMORE DISPOSER
Kenmore 17560500X KENMORE DISPOSER
Kenmore 17560501 DISPOSER (IN-SINK-ERATOR)
Kenmore 17560503 KENMORE DISPOSER
Kenmore 17560504 DISPOSER (IN-SINK-ERATOR)
Kenmore 17560504X KENMORE DISPOSER
Kenmore 175605090 DISPOSER (IN-SINK-ERATOR)
Kenmore 17560510 KENMORE DISPOSER
Kenmore 17560510A KENMORE DISPOSER
Kenmore 17560511 DISPOSER (IN-SINK-ERATOR)
Kenmore 175605140 DISPOSER (IN-SINK-ERATOR)
Kenmore 175605150 DISPOSER (IN-SINK-ERATOR)
Kenmore 175605160 DISPOSER (IN-SINK-ERATOR)
Kenmore 17560517 DISPOSER (IN-SINK-ERATOR)
Kenmore 17560517X KENMORE DISPOSER
Kenmore 175605250 DISPOSER (IN-SINK-ERATOR)
Kenmore 175605520 DISPOSER
Kenmore 17560552CE DISPOSER
Kenmore 175605530 DISPOSER
Kenmore 175605540 DISPOSER
Kenmore 17560554CE DISPOSER
  #2 (permalink)
Old 04-26-2014, 03:38 AM
Senior Expert
APP Volunteer
denman is a splendid one to behold
Your model number is incomplete.
Kenmore numbers are usually 3 digits, a period and then an additional 8 digits.
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Frigidaire won't drain fully! drainwoes Dishwasher Repair 5 04-17-2012 02:45 PM
Dishwasher won't fully drain gweidenh Dishwasher Repair 0 10-03-2011 07:58 PM
GE Dishwasher won't fully drain GoldenRose Dishwasher Repair 0 09-16-2011 01:47 PM
Washer does not fully drain JMJNet Washer Repair 1 07-06-2010 01:06 PM
Dishwasher Does Not Fully Drain braun647 Dishwasher Repair 0 03-28-2008 08:09 AM
