Cheers all,
i have a frigidaire dishwasher that leaks. i inspected underneath while it was initially filling with water. no leaks. it goes into the first cycle. no leaks. after about 2 minutes it sounded like it was pumping out the water. water came out the bottom and violently sprayed out the top of the door like something was under pressure. my expertise ended at that point. any help will be greatly appreciated and would be much cheaper than another dishwasher.
walkingscar
