This 14 year-old machine has worked perfectly until this week. Now the circulating pump will not operate following the major drain at the 5:30 point on the rotating dial. The cycle advances on to the end, but no water flows. Assuming that the pump is at fault and needs replacement, are parts still available for such an old unit?
