Discuss
Dishwasher won't drain all the way
 in
Dishwasher Repair
My GE dishwasher won't drain all the way after cycles. Sometimes the water is up to the door, sometimes it
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » Dishwasher won't drain all the way
  #1 (permalink)
Old 04-09-2014, 10:58 AM
Junior Member
jennie_49031 is on a distinguished road
Default Dishwasher won't drain all the way
Brand: GE   Age: 1 - 5 years
My GE dishwasher won't drain all the way after cycles. Sometimes the water is up to the door, sometimes it is lower but never always gone. We've checked the drain lines and everything's clear. The basket inside is clean. It's almost like it drains when it wants to or that something is getting stuck and not allowing it to drain completely. During the drain cycle times it sounds like it wants to drain but does nothing. I have to flip the door switch open and close several times for it to reset it which seems to help it drain what is left in the bottom of the disher. Does anyone know what part I should be replacing on it? Is it the flapper that needs replaced or check valve? I just don't want to replace a bunch of parts that don't need it and want to get to the bottom of what the problem really is. I was thinking it could be the flapper getting stuck and not opening when it should but I'm not sure. Model # GSD5920DBB GE Profile Performance
  #2 (permalink)
Old 04-10-2014, 02:17 AM
Senior Expert
APP Volunteer
denman is a splendid one to behold
Default
A model number may help others help you.
http://www.appliancepartspros.com/mo...r_locator.aspx
__________________
  #3 (permalink)
Old 05-05-2014, 10:06 AM
Junior Member
Default
I had a hard time finding the model # on the dishwasher and ended up having to research which one it was online but here it is Model # GSD5920DBB.
  #4 (permalink)
Old 05-07-2014, 02:27 AM
Senior Expert
APP Volunteer
Default
Parts for GE GSD5920D00BB Dishwasher - AppliancePartsPros.com
With the kick plate off check that the solenoid pulls the flapper all the way into the drain position. Down on the solenoid is the drain position.
Check the piston and nut assembly (item 564 in Section 02). It is behind the screen cover at the back bottom of the tub. It unscrews. If it does not seal when in a drain cycle water is pumped back into the tub instead of out the drain.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Fridigaire dishwasher no power to the dishwasher and water will not drain out jarhead1984 Dishwasher Repair 0 02-27-2012 07:43 AM
Dishwasher won't drain, push cancel/drain button will clicking then hum, no draining bluelakes77 Dishwasher Repair 0 11-10-2011 09:17 PM
Dishwasher drain motor not spinning and won't drain bwp Dishwasher Repair 1 01-02-2011 03:39 PM
dishwasher will not drain (drain pump is new) jkda1975 Dishwasher Repair 1 04-06-2010 01:56 PM
dishwasher will not drain drichi Dishwasher Repair 0 02-09-2010 06:02 PM
