Discuss
No water in - E 24, unless jiggle float switch
 in
Dishwasher Repair
It began with hit start hear it start up then cut off with E24 (error 24) displayed. I troubleshoot and
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » No water in - E 24, unless jiggle float switch
  #1 (permalink)
Old 04-09-2014, 09:09 AM
Junior Member
gjp105 is on a distinguished road
Default No water in - E 24, unless jiggle float switch
Model Number: SHE6AP02UC/05   Brand: Bosch   Age: 1 - 5 years
It began with hit start hear it start up then cut off with E24 (error 24) displayed. I troubleshoot and find a small item int the pump out sump and clean it it out and think it will be fixed. NOPE-hit start, hear it drain out water, although there is no water, then you hear a pause and it switch to begin washing but no water came through inlet. It pumps imaginary water for about 30 seconds then cuts off to dispay E24.
There are 2 ways to make it wash: 1. Add water manually-about a gallon, after a few tries it will run until completion. 2.. remove kick plate and manually jiggle the float switch several times, after a few attempts will run until completion.
You say - replace the float switch - YEP, it was replaced, did it fix it, NOPE-hit start and if no action taken on my part of step 1 or 2 above, the result is E24.
Any Ideas?
Related Models
Whirlpool SHF3801W0 Dishwasher
Whirlpool SHF3804W2 Dishwasher
Whirlpool SHF4500W0 Dishwasher
Whirlpool SHF5500W0 Dishwasher
Whirlpool SHF5501W0 Dishwasher
Whirlpool SHF5504W0 Dishwasher
Whirlpool SHF5584P1 Dishwasher
Whirlpool SHF5584P2 Dishwasher
Whirlpool SHF5801W0 Dishwasher
Whirlpool SHF5801W1 Dishwasher
Whirlpool SHF5884P1 Dishwasher
Whirlpool SHF5884P2 Dishwasher
Whirlpool SHF7800W0 Dishwasher
Whirlpool SHF7801W0 Dishwasher
Whirlpool SHF7804W1 Dishwasher
Whirlpool SHF7884P0 Dishwasher
Whirlpool SHF7884P1 Dishwasher
Whirlpool SHF7884P2 Dishwasher
Bosch SHI4302 UC/06 -FD8002
Bosch SHI4302 UC/11 -FD8003
Bosch SHI4302 UC/12
Bosch SHI4306 UC/06 -FD8002
Bosch SHI4306 UC/11 -FD8003
Bosch SHI4306 UC/12
Bosch SHI66A05 UC/14 (FD 8211-)
Bosch SHI6802 UC/06
Bosch SHI6802 UC/11
Bosch SHI6802 UC/12
Bosch SHI6805 UC/06
Bosch SHI6805 UC/11
Bosch SHI6805 UC/12
Bosch SHI6806 UC/06
Bosch SHI6806 UC/11
Bosch SHI6806 UC/12
Whirlpool SHU30011 DISHWASHER
Bosch SHU3002
Whirlpool SHU30041 DISHWASHER
Bosch SHU3006
Bosch SHU3012
Whirlpool SHU30140 DISHWASHER
Whirlpool SHU30141 DISHWASHER
Bosch SHU3016
Bosch SHU3032 UC/06 (FD 7908-8002)
Bosch SHU3032 UC/11 (FD 8002-8003)
Bosch SHU3032 UC/12 (FD 8003-)
Bosch SHU3035 UC/12 (FD 8006-)
Bosch SHU3036 UC/06 (FD 7908-8002)
Bosch SHU3036 UC/11 (FD 8002-8003)
Bosch SHU3036 UC/12 (FD 8003-)
Bosch SHU3132 UC/12 (FD 8105-)
Bosch SHU3135 UC/12 (FD 8105-)
Bosch SHU3136 UC/12 (FD 8105-)
Bosch SHU3302 UC/06 (FD 7902-8003)
Bosch SHU3302 UC/11 (FD 8003-8003)
Bosch SHU3302 UC/12 (FD 8003 -)
Bosch SHU3305 UC/06 (FD 7902-8003)
Bosch SHU3305 UC/11 (FD 8003-8003)
Bosch SHU3305 UC/12 (FD 8003 -)
Bosch SHU3306 UC/06 (FD 7902-8003)
Bosch SHU3306 UC/11 (FD 8003-8003)
Bosch SHU3306 UC/12 (FD 8003 -)
Bosch SHU3307 UC/12 (FD 8005 -)
Bosch SHU3322 UC/06
Bosch SHU3322 UC/11
Bosch SHU3322 UC/12
Bosch SHU3322 UC/12 (FD 8003-)
Bosch SHU3326 UC/06
Bosch SHU3326 UC/11
Bosch SHU3326 UC/12
Bosch SHU3326 UC/12 (FD 8003-)
Bosch SHU3336 UC/06
Bosch SHU3336 UC/11
Bosch SHU3336 UC/12
Bosch SHU3336 UC/12 (FD 8003-)
Bosch SHU33A02 UC/14 (FD 8211-)
Bosch SHU33A06 UC/14 (FD 8211-)
Bosch SHU33AC02 UC/14
Bosch SHU33AC06 UC/14
Whirlpool SHU40011 DISHWASHER
Bosch SHU4002 UC/06
Whirlpool SHU40041 DISHWASHER
Bosch SHU4006 UC/06
Bosch SHU4016 UC/06
Bosch SHU4022 UC/06
Bosch SHU4026 UC/06
Bosch SHU4036 UC/06
Bosch SHU4302 UC/06 (FD 7705-7912)
Bosch SHU4302 UC/11 (FD 8001-8003)
Bosch SHU4302 UC/12 (FD 8003-)
Bosch SHU4306 UC/06 (FD 7705-7912)
Bosch SHU4306 UC/11 (FD 8001-8003)
Bosch SHU4306 UC/12 (FD 8003-)
Bosch SHU4312 UC/06 (FD 7701-7912)
Bosch SHU4312 UC/11 (FD 8001-8003)
Bosch SHU4312 UC/12 (FD 8003-)
Bosch SHU4316 UC/06
Bosch SHU4316 UC/11
Bosch SHU4316 UC/12
Bosch SHU4322 UC/12
Bosch SHU4322 UC/12 (FD 8003-)
Bosch SHU4326 UC/12
Bosch SHU4326 UC/12 (FD 8003-)
Bosch SHU43C02 UC/14 (FD 8211-)
Bosch SHU43C05 UC/14 (FD 8211-)
Bosch SHU43C06 UC/14 (FD 8211-)
Bosch SHU43C07 UC/14 (FD 8211-)
Bosch SHU43E02 UC/14 (FD 8211-)
Bosch SHU43E05 UC/14 (FD 8211-)
Bosch SHU43E06 UC/14 (FD 8211-)
Bosch SHU43E07 UC/14 (FD 8211-)
Whirlpool SHU45010 Dishwasher
Whirlpool SHU45020 Dishwasher
Whirlpool SHU50041 Dishwasher
Whirlpool SHU50043 Dishwasher
Bosch SHU5302 UC/06 (FD 7705-7912)
Bosch SHU5302 UC/11 (FD 8001-8003)
Bosch SHU5302 UC/12 (FD 8003-)
Bosch SHU5304 UC/06 (FD 7705-7912)
Bosch SHU5304 UC/11 (FD 8001-8003)
Bosch SHU5304 UC/12 (FD 8003-)
  #2 (permalink)
Old 04-16-2014, 03:45 PM
Junior Member
Default
Anybody? Anybody? Bueller?
  #3 (permalink)
Old 05-02-2014, 05:27 AM
Junior Member
Default
No replies-so I called repair man. He checks it out. Tells me it is the control module (bottom right underneath-not the one in the door) and tells mee it's over 400 dollars. I tell him thanks but I will buy a replAcement. He says they will bill me.
I call bosch to complain how expensive this part is. They tell me that this specefic part has a five year warranty. So now it's s three way arguent between Bosch, a&e repair (sears subcontractor that bosch uses) and me.
Will eventually post how this turns out! Should be fun.
  #4 (permalink)
Old 06-16-2014, 08:31 AM
Junior Member
Default
The repair guy puts on the control panel turns it on and leaves. Shows e24. We call but dispatch advised too far away to return.
A few weeks later different guy same company shows up. Finds a popcorn kernel in drain. Removed and fixes it for the cycles until he leaves. Now e24 again. I just open the door to bypass the e24 for now. Still not fixed
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Whirlpool dishwasher - float/float switch problem mbherbener Dishwasher Repair 1 02-08-2013 02:59 AM
Where does the float switch belong? toes314 Dishwasher Repair 0 01-14-2013 03:28 PM
Dishwasher Float & Float Switch -Whirlpool solisms Dishwasher Repair 1 11-27-2012 01:36 AM
Help finding float switch trash123 Dishwasher Repair 1 09-29-2012 01:47 AM
Float switch not activating frankleibo Dishwasher Repair 1 08-03-2012 11:25 AM
