I replaced the front panel 2&1/2 years ago. Now it is not working properly. The normal wash light won't turn on, yet all the other lights seem to be working. The machine won't turn on. Do you think it is the front panel again. As you know it is not cheap. I don't want to spend the money unless I know that is what I need. Is the front panel the only think that would go bad to cause this problem? Do you think it could be something else, or perhaps can I just buy the board that all of the connectors go into. Thanks for any help.
