Discuss
Whirlpool dishwasher wont drain
 in
Dishwasher Repair
Hi all -- This great forum helped me repair my wall oven recently, and now I'm working on my dishwasher
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » Whirlpool dishwasher wont drain
  #1 (permalink)
Old 03-30-2014, 02:53 PM
Junior Member
JayTeeC is on a distinguished road
Default Whirlpool dishwasher wont drain
Model Number: GU1100XTLS1   Brand: Whirlpool   Age: 5 - 10 years
Hi all -- This great forum helped me repair my wall oven recently, and now I'm working on my dishwasher (about 10 years old). It has been blowing thermal fuses for over a year - 18mos... i'm on my 5th thermal fuse. Sometimes they last several months, sometimes only weeks. Every time a fuse blows, there is water in the bottom. With a fresh fuse, press Cancel and it pumps out. But this time, replace the fuse, and it wont drain. No noise, no humming, nothing. Indicator lights are on, but wont drain. I figured the drain pump was failing, drawing too much current, blowing fuses, and now its failed and the motor wont run. So to test this theory I checked resistance at the pump (unplugged) and get about 10 ohms - what should this value be? The impeller spins as it should and is not damaged. Drain line appears unobstructed. I then checked voltage at the drain pump terminals (by pressing Cancel) and get zero volts. I've read that pressing Cancel should send 120v to the pump, and would indicate a bad control board. BUT - Does there need to be water in the basin to trigger voltage at the pump? There is no water in there (drained it out manually when I removed the unit, and I dont want to pour a gallon in there to test it, only to have to drain it again to work on it).
So a few questions - what resistance should the drain pump motor read? Does there need to be water in the basin to get 120v at the drain pump terminals? or is pressing Cancel enough? Any other thoughts or suggestions?
Many thanks!!
Related Models
Whirlpool GU1100XTLS1 UNDERCOUNTER DISHWASHER
Whirlpool GU1100XTLT0 UNDERCOUNTER DISHWASHER
Whirlpool GU1100XTLT1 UNDERCOUNTER DISHWASHER
Whirlpool GU1101XTLB0 UNDERCOUNTER DISHWASHER
Whirlpool GU1101XTLQ0 UNDERCOUNTER DISHWASHER
Whirlpool GU1101XTLS0 UNDERCOUNTER DISHWASHER
Whirlpool GU1101XTLT0 UNDERCOUNTER DISHWASHER
Whirlpool GU1108XTLB0 UNDERCOUNTER DISHWASHER
Whirlpool GU1108XTLB1 UNDERCOUNTER DISHWASHER
Whirlpool GU1108XTLQ0 UNDERCOUNTER DISHWASHER
Whirlpool GU1108XTLQ1 UNDERCOUNTER DISHWASHER
Frigidaire GU11L
Frigidaire GU11W
Whirlpool GU1200XTKB0 UNDERCOUNTER DISHWASHER
Whirlpool GU1200XTKQ0 UNDERCOUNTER DISHWASHER
Whirlpool GU1200XTKS0 UNDERCOUNTER DISHWASHER
Whirlpool GU1200XTKT0 UNDERCOUNTER DISHWASHER
Whirlpool GU1200XTLB0 UNDERCOUNTER DISHWASHER
Whirlpool GU1200XTLB1 UNDERCOUNTER DISHWASHER
Whirlpool GU1200XTLB2 UNDERCOUNTER DISHWASHER
Whirlpool GU1200XTLB3 UNDERCOUNTER DISHWASHER
Whirlpool GU1200XTLQ0 UNDERCOUNTER DISHWASHER
Whirlpool GU1200XTLQ1 UNDERCOUNTER DISHWASHER
Whirlpool GU1200XTLQ2 UNDERCOUNTER DISHWASHER
Whirlpool GU1200XTLS0 UNDERCOUNTER DISHWASHER
Whirlpool GU1200XTLS1 UNDERCOUNTER DISHWASHER
Whirlpool GU1200XTLS2 UNDERCOUNTER DISHWASHER
Whirlpool GU1200XTLT0 UNDERCOUNTER DISHWASHER
Whirlpool GU1200XTLT1 UNDERCOUNTER DISHWASHER
Whirlpool GU1200XTLT2 UNDERCOUNTER DISHWASHER
Whirlpool GU1200XTLT3 UNDERCOUNTER DISHWASHER
Whirlpool GU1500XTKB0 UNDERCOUNTER DISHWASHER
Whirlpool GU1500XTKQ0 UNDERCOUNTER DISHWASHER
Whirlpool GU1500XTKS0 UNDERCOUNTER DISHWASHER
Whirlpool GU1500XTKT0 UNDERCOUNTER DISHWASHER
Whirlpool GU1500XTLB0 UNDERCOUNTER DISHWASHER
Whirlpool GU1500XTLB1 UNDERCOUNTER DISHWASHER
Whirlpool GU1500XTLB2 UNDERCOUNTER DISHWASHER
Whirlpool GU1500XTLQ0 UNDERCOUNTER DISHWASHER
Whirlpool GU1500XTLQ1 UNDERCOUNTER DISHWASHER
Whirlpool GU1500XTLQ2 UNDERCOUNTER DISHWASHER
Whirlpool GU1500XTLS0 UNDERCOUNTER DISHWASHER
Whirlpool GU1500XTLS1 UNDERCOUNTER DISHWASHER
Whirlpool GU1500XTLS2 UNDERCOUNTER DISHWASHER
Whirlpool GU1500XTLT0 UNDERCOUNTER DISHWASHER
Whirlpool GU1500XTLT1 UNDERCOUNTER DISHWASHER
Whirlpool GU1500XTLT2 UNDERCOUNTER DISHWASHER
Whirlpool GU1500XTLT3 UNDERCOUNTER DISHWASHER
Frigidaire GU16
Frigidaire GU17L
Frigidaire GU17W
Frigidaire GU20L
Frigidaire GU20W
Whirlpool GU2200XTSB0 UNDERCOUNTER DISHWASHER
Whirlpool GU2200XTSB1 UNDERCOUNTER DISHWASHER
Whirlpool GU2200XTSB2 UNDERCOUNTER DISHWASHER
Whirlpool GU2200XTSB3 UNDERCOUNTER DISHWASHER
Whirlpool GU2200XTSQ0 UNDERCOUNTER DISHWASHER
Whirlpool GU2200XTSQ1 UNDERCOUNTER DISHWASHER
Whirlpool GU2200XTSQ2 UNDERCOUNTER DISHWASHER
Whirlpool GU2200XTSQ3 UNDERCOUNTER DISHWASHER
Whirlpool GU2200XTSS0 UNDERCOUNTER DISHWASHER
Whirlpool GU2200XTSS1 UNDERCOUNTER DISHWASHER
Whirlpool GU2200XTSS2 UNDERCOUNTER DISHWASHER
Whirlpool GU2200XTSS3 UNDERCOUNTER DISHWASHER
Whirlpool GU2275XTVB0 UNDERCOUNTER DISHWASHER
Whirlpool GU2275XTVB1 UNDERCOUNTER DISHWASHER
Whirlpool GU2275XTVB2 UNDERCOUNTER DISHWASHER
Whirlpool GU2275XTVB3 UNDERCOUNTER DISHWASHER
Whirlpool GU2275XTVQ0 UNDERCOUNTER DISHWASHER
Whirlpool GU2275XTVQ1 UNDERCOUNTER DISHWASHER
Whirlpool GU2275XTVQ2 UNDERCOUNTER DISHWASHER
Whirlpool GU2275XTVQ3 UNDERCOUNTER DISHWASHER
Whirlpool GU2275XTVY0 UNDERCOUNTER DISHWASHER
Whirlpool GU2275XTVY1 UNDERCOUNTER DISHWASHER
Whirlpool GU2275XTVY2 UNDERCOUNTER DISHWASHER
Whirlpool GU2275XTVY3 UNDERCOUNTER DISHWASHER
Whirlpool GU2300XTKB0 DISHWASHER
Whirlpool GU2300XTKQ0 DISHWASHER
Whirlpool GU2300XTKS0 DISHWASHER
Whirlpool GU2300XTLB0 UNDERCOUNTER DISHWASHER
Whirlpool GU2300XTLB1 UNDERCOUNTER DISHWASHER
Whirlpool GU2300XTLB2 UNDERCOUNTER DISHWASHER
Whirlpool GU2300XTLB3 UNDERCOUNTER DISHWASHER
Whirlpool GU2300XTLQ0 UNDERCOUNTER DISHWASHER
Whirlpool GU2300XTLQ1 UNDERCOUNTER DISHWASHER
Whirlpool GU2300XTLQ2 UNDERCOUNTER DISHWASHER
Whirlpool GU2300XTLQ3 UNDERCOUNTER DISHWASHER
Whirlpool GU2300XTLS0 UNDERCOUNTER DISHWASHER
Whirlpool GU2300XTLS1 UNDERCOUNTER DISHWASHER
Whirlpool GU2300XTLS2 UNDERCOUNTER DISHWASHER
Whirlpool GU2300XTLS3 UNDERCOUNTER DISHWASHER
Whirlpool GU2300XTSB0 UNDERCOUNTER DISHWASHER
Whirlpool GU2300XTSQ0 UNDERCOUNTER DISHWASHER
Whirlpool GU2300XTSS0 UNDERCOUNTER DISHWASHER
Whirlpool GU2300XTST0 UNDERCOUNTER DISHWASHER
Whirlpool GU2300XTVB0 UNDERCOUNTER DISHWASHER
Whirlpool GU2300XTVB1 UNDERCOUNTER DISHWASHER
Whirlpool GU2300XTVB2 UNDERCOUNTER DISHWASHER
Whirlpool GU2300XTVB3 UNDERCOUNTER DISHWASHER
Whirlpool GU2300XTVQ0 UNDERCOUNTER DISHWASHER
Whirlpool GU2300XTVQ1 UNDERCOUNTER DISHWASHER
Whirlpool GU2300XTVQ2 UNDERCOUNTER DISHWASHER
Whirlpool GU2300XTVQ3 UNDERCOUNTER DISHWASHER
Whirlpool GU2300XTVS0 UNDERCOUNTER DISHWASHER
Whirlpool GU2300XTVS1 UNDERCOUNTER DISHWASHER
Whirlpool GU2300XTVS2 UNDERCOUNTER DISHWASHER
Whirlpool GU2300XTVS3 UNDERCOUNTER DISHWASHER
Whirlpool GU2300XTVT0 UNDERCOUNTER DISHWASHER
Whirlpool GU2300XTVT1 UNDERCOUNTER DISHWASHER
Whirlpool GU2300XTVT2 UNDERCOUNTER DISHWASHER
Whirlpool GU2300XTVT3 UNDERCOUNTER DISHWASHER
Whirlpool GU2370XTSB0 UNDERCOUNTER DISHWASHER
Whirlpool GU2370XTSQ0 UNDERCOUNTER DISHWASHER
Whirlpool GU2370XTSS0 UNDERCOUNTER DISHWASHER
Whirlpool GU2370XTST0 UNDERCOUNTER DISHWASHER
Whirlpool GU2400XTPB0 UNDERCOUNTER DISHWASHER
Whirlpool GU2400XTPB1 DISHWASHER
Whirlpool GU2400XTPB3 UNDERCOUNTER DISHWASHER
Whirlpool GU2400XTPB6 DISHWASHER
  #2 (permalink)
Old 03-31-2014, 05:58 AM
Senior Expert
APP Volunteer
denman is a splendid one to behold
Default
Parts for Whirlpool GU1100XTLS1 Dishwasher - AppliancePartsPros.com
According to the operators manual at Whirlpool, cancel should do a drain.
There are some diagnostics in the data sheet.
The drain motor should be 16.3 ohms according to the tech sheet but I do not know what the plus/minus is on this spec. Could be you have a winding to winding short in the motor.
Not having any voltage at the motor is also a concern.
Makes me think that perhaps a motor short blew the control triac on the board.
Could be that the motor is also the cause of your short fuse life.
One thing to note with theses fuses is to use the new harness that comes with the fuse.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Whirlpool Dishwasher Wont Drain WINGR8 Dishwasher Repair 0 12-28-2013 07:39 AM
Whirlpool dishwasher wont drain doanhtran@gmail.com Dishwasher Repair 11 10-18-2012 09:43 AM
ge nautilus dishwasher wont drain and sprayarms wont spin James Jenkins Dishwasher Repair 0 07-25-2010 05:59 PM
Whirlpool Dishwasher wont drain water shirump Dishwasher Repair 1 06-07-2010 06:57 AM
Whirlpool dishwasher wont wash or rinse, does drain ppotman Dishwasher Repair 5 01-13-2010 09:59 AM
