Front door continues to leak after following repairs.
Replaced following parts 1. Door gasket (#902894): New one was shorter than the old one! repair-man bought the part from a store in town. Package said genuine OEM. 2. Water deflector 3. Soap cup dispenser door latch and gasket 4. Inner door foam insulation strip
Checked and Cleaned: 1. Float assembly and switch. Cleaned gunk from the float-assembly. Removed palnut to make sure that the water level does not rise too much. 2. Upper and lower spray arms: removed calcium build-up from holes. 3. Secondary filter plate: had a lot of gunk inside. dipped in vinegar and rinsed with water to remove all solid deposit.
Any help will be appreciated.
Taylor
