Noticed water spot near dish washer. Removed lower access panel and discovered water dripping while dishwasher is running. With flashlight and small mirror discovered water dripping from below the motor kit harness. Drips about ever 15 seconds and appears to be coming from the ventilation webbing on the motor kit harness. Dishwasher appears to be running well otherwise. Part Diagram indicate that there are two Oring (front/back) located nearby. Could this be the source of the water issue? Read more: http://forum.appliancepartspros...rness.html#ixzz2wicT9ggo http://forum.appliancepartspros.com
