Discuss
Whirpool Dishwasher
 in
Dishwasher Repair
The control panel is not currently working therefore causing the dishwasher not to turn on In the past few months
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » Whirpool Dishwasher
Reply By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use.
  #1 (permalink)
Old 02-14-2008, 08:40 AM
FEZ20@AOL.COM FEZ20@AOL.COM is offline
Junior Member
FEZ20@AOL.COM is on a distinguished road
Default Whirpool Dishwasher
Model Number: DU960PWKQ1   Brand: Whirlpool   Age: 1 - 5 years
In the past few months it has been working on and off
Shall I try the thermal fuse first ?
I had a local repair come and they said it was the control panel.
Please help !!
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 02-14-2008, 06:28 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
The first thing I would check is 120V at the power outlet and the plug connection.
Remove the bottom panel and check for burned wires at the junction box.
Check for reversed polarity at the power cord connection to the dishwasher.
Reversed polarity means the hot power cord wire connected to the neutral dishwasher wire and the neutral power cord wire connected to the hot dishwasher wire.
Reversed polarity could cause a damage to the control board.
If there is nothing wrong then check the thermal fuse, located on the control board box.
If this is not the issue then replace the control board.
- The part number for the thermal fuse is AP3115186
- The part number for the control board is AP3175633
Here are the break down diagrams for the Whirlpool dishwasher Model DU960PWKQ1
__________________
Professional appliance repair services in Orange County, California.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
whirpool won't drain Markks Dishwasher Repair 1 02-02-2008 03:16 PM
Whirpool Ultimate Care II pauleyg Washer Repair 0 02-02-2008 02:39 PM
Whirpool Duet Washer mansoor ali Washer Repair 1 12-16-2007 07:45 PM
Whirpool gas dryer will not heat smsgtweber Dryer Repair 0 12-08-2007 08:48 PM
Whirpool Dryer will not heat up GaryA Dryer Repair 1 12-06-2007 03:21 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
