I had a couple things wrong and one might have contributed to the other. First, my door latch was broken and stuck in the closed position (on all the time). I replaced that hoping that would make the dishwasher run again. No luck. The buttons(lights) on the door strip light up and seem to be working normally. Push the lights and close the door and the unit seems to try to run (as there is a humming noise) but nothing happens. A minute later the humming noise is back. This happens about 5 times and then nothing. I open the door and the lights are off and heat comes out of the dishwasher but it hasn't run a cycle. Is it the control board? Thanks, Jim
