Hlarsen1982
#1 Posted : Saturday, March 8, 2014 1:46:55 PM(UTC)
Hlarsen1982
Dishwasher was leaking from motor-volute joint. I purchased an impeller and seal kit (8193951) that was recommended for this model on the vendor's website. I removed the motor and took the old impeller off the motor shaft. I tried to screw on the new impeller, but the diameter of the screw hole on the impeller is smaller than the diameter of the motor shaft. Is there a different impeller and seal kit that will work in this application, or do I need to buy a whole new motor assembly with impeller and volute? Thanks.
Dishes dirty after Whirlpool/Kenmore Impeller replacement - incorrecct part? (Dishwasher Repair)
by rrintala 11/25/2018 4:56:04 PM(UTC)
