Not sure that this is the it model number. Per the manual it appears to be DU1050 or DUC600. These do appear in your parts listings but not anywhere on the dishwasher itself. Now to the actual issue.The dishwasher does not drain at the end of the wash cycle. It will however drain properly when one selects the cancel/drain button. So this seems to not be an issue with mechanical parts of the drain system (ie clogged) but more of a control issue. Likely the the control board is what has become defective but before making the investment wanted to ask an expert. If it is the board, help in identifying the correct board would also be greatly appreciated. Thanks much, Jim Jamieson
