Discuss
Kenmore DW leaking after new door seal
 in
Dishwasher Repair
had water on kitchen floor after overnight wash cycle. Replaced large door seal and small lower seal. Ran test wash,
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » Kenmore DW leaking after new door seal
  #1 (permalink)
Old 10-18-2009, 10:31 AM
Junior Member
ucmba97 is on a distinguished road
Default Kenmore DW leaking after new door seal
Model Number: 363.15212100   Brand: Kenmore   Age: 5 - 10 years
had water on kitchen floor after overnight wash cycle. Replaced large door seal and small lower seal. Ran test wash, still dripping from lower section of door, albeit a little less than before.
Water level seems high. How high should it be when I open the door mid cycle?
After cycle completes, there is still water in the tub bottom.
Float and float switch tested good.
Drain under sink unhooked, and tested for backflow. Valve seems good as no water flowed back into the dishwasher when the hose was filled from the sink end and raised above the DW.
no soap has bene use din last 2 test cycles, yet water is very sudsy.
I'm not sure what to do next....and suggestions?
Ads By Google
Related Models
Kenmore 363.3042992  24" GAS BUILT-IN OVEN
Kenmore 363.33355590  KENMORE 30" COUNTER UNIT
Kenmore 363.33356590  KENMORE 30" COUNTER UNIT
Kenmore 363.33359590  KENMORE 30" COUNTER UNIT
Kenmore 363.356630  GAS RANGE
Kenmore 363.37400790  REFRIGERATOR
Kenmore 363.37400791  REFRIGERATOR
Kenmore 363.37400792  REFRIGERATOR
Kenmore 363.37401790  Top-Mount
Kenmore 363.37401791  REFRIGERATOR
Kenmore 363.37401792  REFRIGERATOR
Kenmore 363.37408790  REFRIGERATOR
Kenmore 363.37408791  REFRIGERATOR
Kenmore 363.37408792  REFRIGERATOR
Kenmore 363.37409790  REFRIGERATOR
Kenmore 363.37409791  REFRIGERATOR
Kenmore 363.37409792  REFRIGERATOR
Kenmore 363.37450791  REFRIGERATOR
Kenmore 363.37450792  REFRIGERATOR
Kenmore 363.37450890  REFRIGERATOR
Kenmore 363.37451791  REFRIGERATOR
Kenmore 363.37451792  REFRIGERATOR
Kenmore 363.37451890  REFRIGERATOR
Kenmore 363.37458791  REFRIGERATOR
Kenmore 363.37458792  REFRIGERATOR
Kenmore 363.37458890  REFRIGERATOR
Kenmore 363.37459791  REFRIGERATOR
Kenmore 363.37459792  REFRIGERATOR
Kenmore 363.37459890  REFRIGERATOR
Kenmore 363.38450890  REFRIGERATOR
Kenmore 363.38451890  REFRIGERATOR
Kenmore 363.38458890  REFRIGERATOR
Kenmore 363.38459890  REFRIGERATOR
Kenmore 363.39400990  REFRIGERATOR
Kenmore 363.39400991  REFRIGERATOR
Kenmore 363.39401990  REFRIGERATOR
Kenmore 363.39401991  REFRIGERATOR
Kenmore 363.42482200  ELECTRIC RANGE
Kenmore 363.42484200  ELECTRIC RANGE
Kenmore 363.42489200  ELECTRIC RANGE
Kenmore 363.4272790  MODULAR COOKTOP
Kenmore 363.43482200  ELECTRIC RANGE
Kenmore 363.43484200  ELECTRIC RANGE
Kenmore 363.43489200  ELECTRIC RANGE
Kenmore 363.4672994  30" RADIANT SLIDE IN RANGE
Kenmore 363.46964001  REFRIGERATOR
Kenmore 363.46964009  REFRIGERATOR
Kenmore 363.4803592  DOUBLE CONVECTION BUILT-IN OVEN
Kenmore 363.4803993  DOUBLE CONVECTION BUILT-IN OVEN
Kenmore 363.48042890  REFRIGERATOR
Kenmore 363.48042891  REFRIGERATOR
Kenmore 363.48042892  REFRIGERATOR
Kenmore 363.48042893  REFRIGERATOR
Kenmore 363.48042894  REFRIGERATOR
Kenmore 363.48042896  REFRIGERATOR
Kenmore 363.48042897  REFRIGERATOR
Kenmore 363.48047890  REFRIGERATOR
Kenmore 363.48047891  REFRIGERATOR
Kenmore 363.48047892  REFRIGERATOR
Kenmore 363.48047893  REFRIGERATOR
Kenmore 363.48047894  REFRIGERATOR
Kenmore 363.48047896  REFRIGERATOR
Kenmore 363.48047897  REFRIGERATOR
Kenmore 363.48252890  REFRIGERATOR
Kenmore 363.48252891  REFRIGERATOR
Kenmore 363.48252892  REFRIGERATOR
Kenmore 363.48252893  REFRIGERATOR
Kenmore 363.48252894  REFRIGERATOR
Kenmore 363.48252896  REFRIGERATOR
Kenmore 363.48252897  REFRIGERATOR
Kenmore 363.48257890  REFRIGERATOR
Kenmore 363.48257891  REFRIGERATOR
Kenmore 363.48257892  REFRIGERATOR
Kenmore 363.48257893  REFRIGERATOR
Kenmore 363.48257894  REFRIGERATOR
Kenmore 363.48257896  REFRIGERATOR
Kenmore 363.48257897  REFRIGERATOR
Kenmore 363.4832594  27" ELECTRIC BUILT-IN DOUBLE OVEN
Kenmore 363.4832995  27" ELECTRIC BUILT-IN DOUBLE OVEN
Kenmore 363.4842592  ELEC BUILT-IN DBL OVEN
Kenmore 363.4842594  ELECTRIC BUILT-IN DOUBLE OVEN
Kenmore 363.4842992  ELEC BUILT-IN DBL OVEN
Kenmore 363.4842995  ELECTRIC BUILT-IN DOUBLE OVEN
Kenmore 363.4998731  RADIANT MODULE
Kenmore 363.50221000  REFRIGERATOR
Kenmore 363.50222000  REFRIGERATOR
Kenmore 363.50227000  REFRIGERATOR
Kenmore 363.50232000  REFRIGERATOR
Kenmore 363.50237000  REFRIGERATOR
Kenmore 363.50242000  REFRIGERATOR
Kenmore 363.50247000  REFRIGERATOR
Kenmore 363.50622000  REFRIGERATOR
Kenmore 363.50627000  REFRIGERATOR
Kenmore 363.57552790  SIDE BY SIDE
Kenmore 363.57552791  SIDE BY SIDE
Kenmore 363.57557790  SIDE BY SIDE
Kenmore 363.57557791  SIDE BY SIDE
Kenmore 363.58042890  REFRIGERATOR
Kenmore 363.58042891  REFRIGERATOR
Kenmore 363.58042892  REFRIGERATOR
Kenmore 363.58042893  REFRIGERATOR
Kenmore 363.58042894  REFRIGERATOR
Kenmore 363.58042896  REFRIGERATOR
Kenmore 363.58042897  REFRIGERATOR
Kenmore 363.58047890  REFRIGERATOR
Kenmore 363.58047891  REFRIGERATOR
Kenmore 363.58047892  REFRIGERATOR
Kenmore 363.58047893  REFRIGERATOR
Kenmore 363.58047894  REFRIGERATOR
Kenmore 363.58047896  REFRIGERATOR
Kenmore 363.58047897  REFRIGERATOR
Kenmore 363.58062890  REFRIGERATOR
Kenmore 363.58062891  REFRIGERATOR
Kenmore 363.58062892  REFRIGERATOR
Kenmore 363.58062893  REFRIGERATOR
Kenmore 363.58062894  REFRIGERATOR
Kenmore 363.58062896  REFRIGERATOR
Kenmore 363.58062897  REFRIGERATOR
Kenmore 363.58067890  REFRIGERATOR
Kenmore 363.58067891  REFRIGERATOR
  #2 (permalink)
Old 10-18-2009, 11:21 AM
Junior Member
Default
UPDATE: could it be as simple as the rinse aid cup was overfilled??
I filled it last wednesday.
Just emptied it, and am running a test cycle...no leaks so far.
Why is it suds can leak out but water without suds doesn't leak out?
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Kenmore [Frigidaire] Leaking from outer tub seal swanny Washer Repair 2 02-10-2009 06:12 PM
leaking front loader door /drum seal bfd Washer Repair 0 12-22-2008 07:21 PM
dishwasher door seal leaking onemoretime Dishwasher Repair 3 12-20-2008 02:59 PM
Water leaking under door...need to know how to remove door & replace seal edbolliera Dishwasher Repair 1 11-27-2007 03:42 AM
door seal leaking karenslawrence Dishwasher Repair 1 08-29-2007 11:13 PM
