GE dw about 7years old. After it fills up and starts to wash, water slowly from the tub escapes through the drain hose. This model has a separate drain pump motor which is not energized and the drain hose is looped higher than the tub. It is not syphoning but rather it seems the water is being pushed out. Ant thoughts or suggestions?
