Our Electrolux dishwasher does not do a complete wash cycle. Part way through the cycle all the program lights on the control panel start flashing and the 'wash pump' error behind the bottom kick plate starts flashing. It seems that the wash cycle has not been completed, however there is no water or suds in the tub. The first time this happened, after several attempts at pressing the 'Start/Cancel' button it seemed to reset, all lights on control panel and 'wash pump' error light stopped flashing. Everything worked fine for a few washes and then went back to original fault. Did the reset and it worked fine again for a few more washes. Now it is back to original fault with all lights on the control panel and the 'wash pump' error light flashing and will not do a complete cycle after being reset. Wondering if anyone has experienced same issue.
