Register | FAQ's | New Posts | Today's Posts | Extras |
» kitchenaid dishwasher leaking water from door |
![]() Model Number: KUDS02SRSS0 Brand: Kitchen Aid Age: 5 - 10 years
![]() Hi, my kitchenaid dishwasher is leaking (dripping) water from the left bottom side of the door. I changed the door gasket and cleaned the spray arms. After reading your blog, it seems that the leak could come from the door vent and/or soap dispenser. One thing i noticed is water marks on the lower middle left side next to the door gasket. Can this be a sign of the hinges or door not closing tightly? Also, the leak generates a strange smell. I appreciate any other clues. Thanks! Related Models Last edited by brasuca : 01-20-2014 at 03:34 PM. Reason: additional information... |
See inside of your appliance - diagrams and part photos for virtually every model.![]() powered by AppliancePartsPros.com |
![]() Does your model have any plastic tabs installed in each lower corner, if so these go bad. Also I have seen hinges being bent from too much weight on door from kids or other reasons. Can you remove outer cover and watch for leaks.
![]() It seems that the leak comes from the very top edge of the left side of the door. Like you mentioned it could be the hinges since the left side is wet, but the right side is dry. Either the door is not closing all the way to make a tight seal or it's something else.
![]() Try and run it without dishes. Also maybe try some type of lubricant like Vaseline by smearing a Small amount on the gasket on the left side and close the door like NORMAL and open and see if it makes contact with the door. If only one side is leaking something must be wrong with the door. You could add a small piece of thin gasket type material behind the new gasket in this area and see if that works.
Display Modes | |
Thread | Thread Starter | Forum | Replies | Last Post |
Kitchenaid leaking near bottom of door | haleytd | Dishwasher Repair | 3 | 02-01-2013 12:32 PM |
KitchenAid Superba freezer door opening, leaking, etc. | Lynneam | Refrigerator & Freezer Repair | 4 | 09-14-2012 03:59 PM |
KitchenAid Dishwasher Door not Closing and Leaking | BTMS | Dishwasher Repair | 0 | 01-22-2012 01:46 PM |
Dishwasher leaking water through door | redcam80 | Dishwasher Repair | 1 | 05-08-2010 06:47 PM |
Kitchenaid dishwasher leaking from bottom | smithguy | Dishwasher Repair | 1 | 05-26-2009 12:50 AM |
