1. Only the model with "F00" & "F01" appear online; mine is "F02" but parts are mostly same as F01. 2. Failure to drain soapy water first happened 2 months ago, and was intermittent. "Solved" problem by running "rinse only" option. 4. Now, doesn't drain at all, leaving full load of soapy water. 5. I've disassembled everything and found some minor stuff in sump that I cleaned; all hoses clear; red flapper is supple; piston&nut seal is supple with good spring action; check valve body that piston&nut screw into is clean; disassembled sequencer/timer and cleaned contact points; disassembled drain pump and found impeller fine, movable (in 1/4-turns) and rubber backing supple; checked drain line for proper routing before it goes into disposal; so lastly ran pushbutton panel diagnostics=ok. 6. Noticed there is no solenoid on main pump/motor like other models. Main pump motor runs when demanded. 7. Noticed 2nd pump (drain pump) metal surface seemed quite hot to touch while running so thought maybe it wasn't getting enuf juice. Tested it's motor for continuity and got 1000ohms which one site said was right for this type of motor. 8. I'm at a loss at this point, and can only suspect control panel not providing enuf juice to run drain pump hard enuf. 9. Appreciate any suggestions! Thanks!
