Discuss
Dishwasher drain pump running constantly
 in
Dishwasher Repair
Model number: MDB7749SAB0 My dishwasher's drain pump will run at the end of the cycle even if the tub is
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » Dishwasher drain pump running constantly
  #1 (permalink)
Old 01-11-2014, 08:15 PM
Junior Member
burtonjt36 is on a distinguished road
Default Dishwasher drain pump running constantly
Brand: Maytag   Age: 1 - 5 years
My dishwasher's drain pump will run at the end of the cycle even if the tub is dry. I looked underneath the unit and the drain hose still has water in it. I replaced the overfill float switch and electronic control. I still have the problem. The was wash cycle works normally. Any ideas?
Is it possible for something to be plugged where I cannot see it? What about a check valve being stuck?
This unit is only 1-1/2 years old and I do not want to replace it.
Last edited by burtonjt36 : 01-13-2014 at 04:05 PM. Reason: Added model number and additional information
  #2 (permalink)
Old 01-12-2014, 02:15 AM
Senior Expert
APP Volunteer
denman is a splendid one to behold
Default
A model number may help others help you.
Find your model number - AppliancePartsPros.com
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
GE Triton XL - Stuck on rinse cycle, drain pump runs constantly str-il Dishwasher Repair 3 06-12-2014 07:23 PM
Drain pump runs constantly Snackyd Dishwasher Repair 0 06-08-2013 09:27 AM
Bosch dishwasher shu5316uc drain pump won't stop running justkoz Dishwasher Repair 2 03-21-2010 03:14 PM
Pump not running to drain jpritcha Dishwasher Repair 0 08-29-2009 12:17 PM
Drain Pump keeps running WaltG Dishwasher Repair 1 02-08-2008 12:06 PM
