I have deposits of fine debris sprayed onto my dishes after a wash and rinse cycle. It's always the same, fine gray stuff with some small black stuff mixed in. I have taken it down to the impeller, and found a lot of soft goo, but no bones or anything hard. There doesn't seem to be a sump, exactly, but a small amount murky water sits at the bottom under the pump and spray assembly. Check valve? Or pump maybe? Chopper blade seems OK, is it supposed to be sharp?
