Discuss
Kenmore dishwasher Control Board or Console Panel?
 in
Dishwasher Repair
My Kenmore Elite Ultrawash dishwasher model 665.13123K703 has intermittent issues. At times it will run fine but mostly it will
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » Kenmore dishwasher Control Board or Console Panel?
  #1 (permalink)
Old 01-04-2014, 04:22 PM
Junior Member
wyorob is on a distinguished road
Default Kenmore dishwasher Control Board or Console Panel?
Model Number: 665.13123K703   Brand: Kenmore   Age: 1 - 5 years
At times it will run fine but mostly it will run partially through the cycle and then stop with the Start/Resume button flashing. The door appears to be closed and when the Start button is pushed again it will run – sometimes through the rest of the cycle, other times it will stop and blink again.
Sometimes only the Cancel button will respond – no other buttons on the Console Panel will light up when pressed.
When running the Self Diagnostic (if it even works), I can only get through two pushes of the Heated Dry/Normal wash sequence before it starts – which performs the diagnostic WITHOUT error codes.
With a multimeter I’ve checked the thermal fuse (OK), door switch (OK) and continuity on each of the buttons of the Console Panel (OK). I’ve also done the keypad ribbon – unplug sequence and the drain motor does run.
So to boil it down – it appears that I either have
1)an issue with the Control Board (since the continuity on the Console Panel keypad checks out)
OR
2)have an issue with the Console Panel (since the the keypad ribbon – unplug sequence results in the drain motor running).
Any ideas on which it might be? Is there something else I’m missing??
Thanks!!
Related Models
Kenmore 665110739120 DISHWASHER
Kenmore 665110739130 DISHWASHER
Kenmore 665110739140 DISHWASHER
Kenmore 665110739190 DISHWASHER
Kenmore 66513012K110 UNDERCOUNTER DISHWASHER
Kenmore 66513013K110 UNDERCOUNTER DISHWASHER
Kenmore 66513014K110 UNDERCOUNTER DISHWASHER
Kenmore 66513019K110 UNDERCOUNTER DISHWASHER
Kenmore 66513023K110 DISHWASHER
Kenmore 66513032K110 UNDERCOUNTER DISHWASHER
Kenmore 66513033K110 UNDERCOUNTER DISHWASHER
Kenmore 66513039K110 UNDERCOUNTER DISHWASHER
Kenmore 66513042K110 UNDERCOUNTER DISHWASHER
Kenmore 66513043K110 UNDERCOUNTER DISHWASHER
Kenmore 66513044K110 UNDERCOUNTER DISHWASHER
Kenmore 66513049K110 UNDERCOUNTER DISHWASHER
Kenmore 66513102K900 DISHWASHER
Kenmore 66513102K901 UNDERCOUNTER DISHWASHER
Kenmore 66513102K902 UNDERCOUNTER DISHWASHER
Kenmore 66513103K900 DISHWASHER
Kenmore 66513103K901 UNDERCOUNTER DISHWASHER
Kenmore 66513103K902 UNDERCOUNTER DISHWASHER
Kenmore 66513104K900 DISHWASHER
Kenmore 66513104K901 UNDERCOUNTER DISHWASHER
Kenmore 66513104K902 UNDERCOUNTER DISHWASHER
Kenmore 66513109K900 DISHWASHER
Kenmore 66513109K901 UNDERCOUNTER DISHWASHER
Kenmore 66513109K902 UNDERCOUNTER DISHWASHER
Kenmore 66513112K700 DISHWASHER
Kenmore 66513112K701 DISHWASHER
Kenmore 66513112K702 UNDERCOUNTER DISHWASHER
Kenmore 66513113K700 DISHWASHER
Kenmore 66513113K701 DISHWASHER
Kenmore 66513113K702 UNDERCOUNTER DISHWASHER
Kenmore 66513114K700 DISHWASHER
Kenmore 66513114K701 DISHWASHER
Kenmore 66513114K702 UNDERCOUNTER DISHWASHER
Kenmore 66513119K700 DISHWASHER
Kenmore 66513119K701 DISHWASHER
Kenmore 66513119K702 UNDERCOUNTER DISHWASHER
Kenmore 66513122K700 DISHWASHER
Kenmore 66513122K701 DISHWASHER
Kenmore 66513122K702 DISHWASHER
Kenmore 66513122K703 DISHWASHER
Kenmore 66513123K700 DISHWASHER
Kenmore 66513123K701 DISHWASHER
Kenmore 66513123K702 DISHWASHER
Kenmore 66513123K703 DISHWASHER
Kenmore 66513124K700 DISHWASHER
Kenmore 66513124K701 DISHWASHER
Kenmore 66513124K702 DISHWASHER
Kenmore 66513124K703 DISHWASHER
Kenmore 66513129K700 DISHWASHER
Kenmore 66513129K701 DISHWASHER
Kenmore 66513129K702 DISHWASHER
Kenmore 66513129K703 UNDERCOUNTER DISHWASHER
Kenmore 66513132K700 DISHWASHER
Kenmore 66513132K701 DISHWASHER
Kenmore 66513133K700 DISHWASHER
Kenmore 66513133K701 DISHWASHER
Kenmore 66513139K700 DISHWASHER
Kenmore 66513139K701 DISHWASHER
Kenmore 66513152K700 DISHWASHER
Kenmore 66513152K701 DISHWASHER
Kenmore 66513152K702 DISHWASHER
Kenmore 66513153K700 DISHWASHER
Kenmore 66513153K701 DISHWASHER
Kenmore 66513153K702 DISHWASHER
Kenmore 66513154K700 DISHWASHER
Kenmore 66513154K701 DISHWASHER
Kenmore 66513154K702 DISHWASHER
Kenmore 66513159K700 DISHWASHER
Kenmore 66513159K701 DISHWASHER
Kenmore 66513159K702 DISHWASHER
Kenmore 66513163K700 DISHWASHER
Kenmore 66513163K701 DISHWASHER
Kenmore 66513163K702 DISHWASHER
Kenmore 66513163K703 DISHWASHER
Kenmore 66513169K700 DISHWASHER
Kenmore 66513169K701 DISHWASHER
Kenmore 66513169K702 DISHWASHER
Kenmore 66513169K703 DISHWASHER
Kenmore 66513173K700 DISHWASHER
Kenmore 66513173K701 DISHWASHER
Kenmore 66513173K702 DISHWASHER
Kenmore 66513173K703 DISHWASHER
Kenmore 66513173K704 UNDERCOUNTER DISHWASHER
Kenmore 66513182K800 DISHWASHER
Kenmore 66513182K801 DISHWASHER
Kenmore 66513182K802 DISHWASHER
Kenmore 66513183K800 DISHWASHER
Kenmore 66513183K801 DISHWASHER
Kenmore 66513183K802 DISHWASHER
Kenmore 66513189K800 DISHWASHER
Kenmore 66513189K801 DISHWASHER
Kenmore 66513189K802 DISHWASHER
Kenmore 66513192K900 DISHWASHER
Kenmore 66513192K901 UNDERCOUNTER DISHWASHER
Kenmore 66513192K902 DISHWASHER
Kenmore 66513193K900 DISHWASHER
Kenmore 66513193K901 UNDERCOUNTER DISHWASHER
Kenmore 66513193K902 DISHWASHER
Kenmore 66513194K900 DISHWASHER
Kenmore 66513194K901 UNDERCOUNTER DISHWASHER
Kenmore 66513194K902 DISHWASHER
Kenmore 66513199K900 DISHWASHER
Kenmore 66513199K901 UNDERCOUNTER DISHWASHER
Kenmore 66513199K902 DISHWASHER
Kenmore 66513206K901 UNDERCOUNTER DISHWASHER
Kenmore 66513206K902 DISHWASHER
Kenmore 66513212K901 UNDERCOUNTER DISHWASHER
Kenmore 66513212K902 UNDERCOUNTER DISHWASHER
Kenmore 66513213K900 UNDERCOUNTER DISHWASHER
Kenmore 66513213K901 UNDERCOUNTER DISHWASHER
Kenmore 66513213K902 UNDERCOUNTER DISHWASHER
Kenmore 66513219K901 UNDERCOUNTER DISHWASHER
Kenmore 66513219K902 UNDERCOUNTER DISHWASHER
Kenmore 66513222K600 DISHWASHER
Kenmore 66513222K601 DISHWASHER
Kenmore 66513223K600 DISHWASHER
  #2 (permalink)
Old 01-25-2014, 08:17 AM
Junior Member
Default
Just giving this a bump...
  #3 (permalink)
Old 01-30-2014, 08:49 PM
Junior Member
Question Control Board didn't work
I ordered the Control Board and replaced it but it didn't help.
After observing the cycles and when the dishwasher is shutting off - it seems to be consistently near the beginning of the cycle and there's a period of time before the Start button will work again - I'm thinking it might not be the Console Panel either. I'm wondering if maybe the thermal fuse might be failing but not dead yet...?
Any other thoughts out there?
  #4 (permalink)
Old 05-31-2014, 07:44 AM
Junior Member
Thow1906 is on a distinguished road
Angry Same issue with my Kenmore Elite Ultra Wash HE
I have the same issue and just started the troubleshooting efforts (in depth). So far the thermal fuse is fine.
I came across your posting as I was searching for HOW TO test the control panel and control board. But after seeing your reply, I'm not getting a sense of confidence that I'm going to be able to narrow down the issue and end up throwing money at a black hole (the dishwasher).
Before I go off and purchase a control panel or control board, I'd like to find out if you got a resolution.
This intermittent crap is killing me.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Whirlpool Dishwasher: Control Panel, or Control Board? caloren Dishwasher Repair 5 11-22-2013 01:30 PM
how do I test dishwasher control panel or board? bgoebel Dishwasher Repair 0 09-15-2013 09:10 AM
Whirlpool dishwasher control panel circuit board cover JamesEI Dishwasher Repair 0 07-01-2010 02:12 PM
whirlpool dishwasher control panel insert console rive0108 Dishwasher Repair 0 07-28-2009 05:56 PM
Dishwasher touch panel or control board? Kebmike Dishwasher Repair 2 04-22-2008 06:44 PM
