As the title says the unit does not stop. The timer will countdown from 99 minutes to zero, sometimes the display with go black midway through. All the while it runs, when I open the door, there is a trickle of water spraying from the spray heads. I'm not sure if its draining or not, cause when I hit the drain/cancel button the noise increases. With my head by the bottom I can almost hear movement inside the undercarriage of the unit.
I disconnected the power, and when we wash dishes by hand, the inside of the dishwasher fills up with sink water.
Any help would be welcome.
