Discuss
Whirpool Dishwasher has no power
 in
Dishwasher Repair
I am really struggling. My dishwasher quit working a few days ago so I took the door panel off and
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » Whirpool Dishwasher has no power
  #1 (permalink)
Old 10-16-2009, 06:53 PM
Junior Member
clark1994 is on a distinguished road
Default Whirpool Dishwasher has no power
Model Number: DU930PWPQ2   Brand: Whirlpool   Age: 1 - 5 years
I am really struggling. My dishwasher quit working a few days ago so I took the door panel off and saw the door switch had went bad. So I went to the local appliance store and just bought the switch itself that went bad. After I replaced it I was able to wash 1 load and it quit again. This time I bought the door switch kit with the new leads and hooked it up and still nothing. Does anyone please have any idea what could be wrong now? I have power coming to the outlet, but that is all I know.
Ads By Google
Related Models
Whirlpool DU930PWPQ2 Undercounter Dishwasher
Whirlpool DU930PWPS0 Undercounter Dishwasher
Whirlpool DU930PWPS1 Undercounter Dishwasher
Whirlpool DU930PWPS2 Undercounter Dishwasher
Whirlpool DU930PWPT0 Undercounter Dishwasher
Whirlpool DU930PWPT1 Undercounter Dishwasher
Whirlpool DU930PWPT2 Undercounter Dishwasher
Whirlpool DU930PWSB0 Undercounter Dishwasher
Whirlpool DU930PWSQ0 Undercounter Dishwasher
Whirlpool DU930PWSS0 Undercounter Dishwasher
Whirlpool DU930PWST0 Undercounter Dishwasher
Whirlpool DU930QWDB0
Whirlpool DU930QWDB2
Whirlpool DU930QWDB3
Whirlpool DU930QWDB4
Whirlpool DU930QWDB5
Whirlpool DU930QWDB6
Whirlpool DU930QWDQ0
Whirlpool DU930QWDQ2
Whirlpool DU930QWDQ3
Whirlpool DU930QWDQ4
Whirlpool DU930QWDQ5
Whirlpool DU930QWDQ6
Whirlpool DU931SCGB0
Whirlpool DU931SCGB1
Whirlpool DU931SCGQ0
Whirlpool DU931SCGQ1
Whirlpool DU935QWDB0
Whirlpool DU935QWDB1
Whirlpool DU935QWDB5
Whirlpool DU935QWDB6
Whirlpool DU935QWDQ0
Whirlpool DU935QWDQ1
Whirlpool DU935QWDQ5
Whirlpool DU935QWDQ6
Whirlpool DU9400XB0
Whirlpool DU9400XB1
Whirlpool DU9400XT0
Whirlpool DU9400XT1
Whirlpool DU9400XT4
Whirlpool DU9400XY0
Whirlpool DU9400XY1
Whirlpool DU9400XY2
Whirlpool DU940PWKB0
Whirlpool DU940PWKB1
Whirlpool DU940PWKQ0
Whirlpool DU940PWKQ1
Whirlpool DU940PWKS1
Whirlpool DU940PWKT0
Whirlpool DU940PWKT1
Whirlpool DU940QWDB0
Whirlpool DU940QWDB2
Whirlpool DU940QWDB3
Whirlpool DU940QWDB4
Whirlpool DU940QWDB5
Whirlpool DU940QWDB6
Whirlpool DU940QWDQ0
Whirlpool DU940QWDQ2
Whirlpool DU940QWDQ3
Whirlpool DU940QWDQ4
Whirlpool DU940QWDQ5
Whirlpool DU940QWDQ6
Whirlpool DU940QWDZ0
Whirlpool DU940QWDZ2
Whirlpool DU940QWDZ3
Whirlpool DU940QWDZ4
Whirlpool DU940QWDZ5
Whirlpool DU940QWDZ6
Whirlpool DU941PWKB0
Whirlpool DU941PWKB1
Whirlpool DU941PWKQ0
Whirlpool DU941PWKQ1
Whirlpool DU9420XX0
Whirlpool DU943PWKB0 Undercounter Dishwasher
Whirlpool DU943PWKQ0 Undercounter Dishwasher
Whirlpool DU943PWKS0 Undercounter Dishwasher
Whirlpool DU943PWKT0 Undercounter Dishwasher
Whirlpool DU9450XB0
Whirlpool DU9450XB1
Whirlpool DU9450XT0
Whirlpool DU9450XT2
Whirlpool DU9450XX0
Whirlpool DU9450XY0
Whirlpool DU9450XY1
Whirlpool DU9450XY2
Whirlpool DU945PWKB0
Whirlpool DU945PWKB1
Whirlpool DU945PWKQ0
Whirlpool DU945PWKQ1
Whirlpool DU945PWKT0
Whirlpool DU945PWKT1
Whirlpool DU945PWPB0 Undercounter Dishwasher
Whirlpool DU945PWPB1 Undercounter Dishwasher
Whirlpool DU945PWPB2 Undercounter Dishwasher
Whirlpool DU945PWPQ0 Undercounter Dishwasher
Whirlpool DU945PWPQ1 Undercounter Dishwasher
Whirlpool DU945PWPQ2 Undercounter Dishwasher
Whirlpool DU945PWPS0 Undercounter Dishwasher
Whirlpool DU945PWPS1 Undercounter Dishwasher
Whirlpool DU945PWPS2 Undercounter Dishwasher
Whirlpool DU945PWPT0 Undercounter Dishwasher
Whirlpool DU945PWPT1 Undercounter Dishwasher
Whirlpool DU945PWPT2 Undercounter Dishwasher
Whirlpool DU945PWSB0 Undercounter Dishwasher
Whirlpool DU945PWSQ0 Undercounter Dishwasher
Whirlpool DU945PWSS0 Undercounter Dishwasher
Whirlpool DU945PWST0 Undercounter Dishwasher
Whirlpool DU948PWKB0
Whirlpool DU948PWKB1
Whirlpool DU948PWKQ0
Whirlpool DU948PWKQ1
Whirlpool DU948PWPB0 Undercounter Dishwasher
Whirlpool DU948PWPB1 Undercounter Dishwasher
Whirlpool DU948PWPB2 Undercounter Dishwasher
Whirlpool DU948PWPQ1 Undercounter Dishwasher
Whirlpool DU948PWPQ2 Undercounter Dishwasher
Whirlpool DU948PWPW0 Undercounter Dishwasher
Whirlpool DU948PWSB0 Undercounter Dishwasher
Whirlpool DU948PWSQ0 Undercounter Dishwasher
Whirlpool DU9500XR1
  #2 (permalink)
Old 10-17-2009, 04:42 AM
Senior Expert
APP Volunteer
denman is just really nice
Default
Replacement parts for WHIRLPOOL DU930PWPQ2 | AppliancePartsPros.com
Check the fuse Item 4 in the "Frame and console" section.
This may also help
http://www.servicematters.com/docs/w...%208535431.pdf
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Whirpool Dishwasher bigproblem Dishwasher Repair 1 10-16-2009 03:58 AM
Whirpool Gold not freezing and fridge not at full power kinetikkurtis Refrigerator & Freezer Repair 3 10-05-2009 05:34 AM
Whirpool dishwasher acts like it has NO power! PLEASE HELP! Momto8 Dishwasher Repair 1 03-23-2009 05:08 PM
Whirpool Dishwasher pbroghamer@remax.net Dishwasher Repair 1 09-15-2008 08:48 AM
whirpool dishwasher drcreen Dishwasher Repair 1 07-16-2008 10:35 AM
