Discuss
Whirlpool Quiet Partner II now working (intermittent power, does not complete cycles)
 in
Dishwasher Repair
I have a Whirlpool Quiet Partner II model #DU1055XTVS1. For the last couple of months the dishwasher began to act
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » Whirlpool Quiet Partner II now working (intermittent power, does not complete cycles)
  #1 (permalink)
Old 12-29-2013, 12:23 PM
Junior Member
xxxsdesdexxx is on a distinguished road
Unhappy Whirlpool Quiet Partner II not working (intermittent power, does not complete cycles)
Model Number: DU1055XTVS1   Brand: Whirlpool   Age: 1 - 5 years
I have a Whirlpool Quiet Partner II model #DU1055XTVS1. For the last couple of months the dishwasher began to act up. The dishwasher would not complete cycles. In fact, it wouldn't run for more than a minute or so. I would then hit cancel to drain the water, and then restart the machine. The machine would run a little bit longer, and then shut off again. I would drain the dishwasher once again, and then restart the machine -- usually this 3rd attempt would end up completing the full normal cycle. The dishwasher worked in this manner for about a month or so and then one day the dishwasher became unresponsive -- the lights on the control panel would not come on. First, I unplugged the dishwasher for about 5 minutes and tried plugging it back in and still no power. I then tried leaving it unplugged for 30 minutes, and still no power. After unplugging it for over an hour, still no power.
The next day I plugged in the dishwasher and, all of the sudden, there was power to the control panel. I hit the cancel/drain button to remove the water that had been sitting in there from the day before -- the water drained and the dishwasher shut off since it had completed the command. I then tried to start the dishwasher, and it was dead just as before. I repeated the same method of unplugging and waiting and it would not come back on.
I decided to take a look at the control board to see if there were any issues there such as blown capacitors, burn marks, or smell of fried electrical components/circuits. I immediately noticed that 2 of the 1000uf 6.3v capacitors were bulged and their bunts were coming out. I removed the 2 1000uf 6.3v capacitors and replaced them with 2 1000uf 35v capacitors that I bought a Radio Shack. I then reinstalled the control board, and the control panel once again had power. I ran the dishwasher using the default settings -- normal cycle with heated dry -- and it ran for about a 30 seconds to a minute before shutting itself off. Once again the control panel was dead. I left the machine unplugged for an entire day and nothing. I did some more checking on the control board and I thought that maybe the single transistor with heat sink might have gone bad, so I replaced that. Unfortunately, I could not find that same exact transistor so I just put a different one on there (I know bad idea). After reconnecting the board with the wrong transistor on there, the control panel once again came back on. Even though I could smell the burning coming from the transistor that had the wrong voltage the entire time the dishwasher was running, it finished its complete cycle on the the first attempt -- it was on normal cycle with heated dry.
I then tried restarting the dishwasher and it filled with water and shut off about 30 seconds later. At this point, I decided to order a new control board.
When the new control board arrived, I immediately installed it and the control panel was working again. I decided to run the dishwasher using the normal setting with hi-temp wash, sani-rinse, and heated dry. The dishwasher ran perfectly for nearly 30 minutes (something it hadn't done for a while epecially with those settings) -- my wife then decided to hit the cancel/drain button since she wanted to go to Target and she's a freak about leaving stuff on due to possible fires occuring. When we returned about an hour and a half later I tried turning the dishwasher on and it once again was dead -- I was very frustrated with this. On a whim, I decided to reconnect the old control board and once again had power. I hit start and the dishwasher ran for about 20 seconds and shut off -- dead again.
The next day I started doing some testing with my multi-meter (I'm really new to using them). After reading through many threads, I follow some instructions in them. I checked voltage at the bottom right of the machine and got 120 volts. I read this on another thread here:
Quote:
Also verify the correct voltage at the control board, with the door latch switches open and closed. P2 (blk/wht ) to P6 (wht/blu) should have 120 VAC across the pins, whether the door is open or closed. P4(wht/prp) to P8(tan) should have 120 VAC only if the door is closed and the latch switches are activated(closed). If the voltages are correct and present at the proper times, then reset the control board, and replace the control panel.
I did these tests and got 120 volts when I was supposed to be getting it. I checked the thermal fuse for continuity with my multimeter and it beeps. I did read elsewhere that the fuse should have 120v going through it -- not sure if that's correct or how to actually check the voltage of the thermal fuse. I connected the red lead to one side of fuse and the black lead to the other side of the fuse, with power cord connected, and the voltage said ~ 2 volts -- I don't remember if I simulated the door switches being closed when doing the voltage test (not sure if it would give a different reading if they were closed). I'll admit that I haven't tested the pins coming from the control panel's ribbon because I don't have a tech sheet and I don't really understand how to do it. I will do this if someone can give me clearer instructions -- or dumb it down for me so that I can do it.
Since I had just paid almost $90.00 for this new control board, I thought I would give it one more shot. I reinstalled the replacement control board that I thought was dead, and was able to get it to run for about 20 minutes before it shut itself off mid-cycle. At this point, I'm frustrated with this dishwasher but I don't want to go out and buy a new one -- this one is ~ 3 years old.
I am thinking of ordering a new control panel, but I would like some more assurance that it's that part that is bad. Any help would greatly be appreciated. I tried reading through all the different Whirlpool threads I could find, and thought I should post the symptoms of mine as well as the measures I have attempted.
Thank you.
Related Models
Whirlpool DU1055XTVS1 UNDERCOUNTER DISHWASHER
Whirlpool DU1055XTVS2 UNDERCOUNTER DISHWASHER
Whirlpool DU1055XTVS3 UNDERCOUNTER DISHWASHER
Whirlpool DU1055XTVS5 UNDERCOUNTER DISHWASHER
Whirlpool DU1055XTVS6 UNDERCOUNTER DISHWASHER
Whirlpool DU1055XTVS7 UNDERCOUNTER DISHWASHER
Whirlpool DU1055XTVS8 UNDERCOUNTER DISHWASHER
Whirlpool DU1055XTVT0 UNDERCOUNTER DISHWASHER
Whirlpool DU1055XTVT1 UNDERCOUNTER DISHWASHER
Whirlpool DU1055XTVT2 UNDERCOUNTER DISHWASHER
Whirlpool DU1055XTVT3 UNDERCOUNTER DISHWASHER
Whirlpool DU1055XTVT5 UNDERCOUNTER DISHWASHER
Whirlpool DU1055XTVT6 UNDERCOUNTER DISHWASHER
Whirlpool DU1055XTVT7 UNDERCOUNTER DISHWASHER
Whirlpool DU1055XTVT8 UNDERCOUNTER DISHWASHER
Whirlpool DU1061XTSB0 UNDERCOUNTER DISHWASHER
Whirlpool DU1061XTSQ0 UNDERCOUNTER DISHWASHER
Whirlpool DU1061XTST0 UNDERCOUNTER DISHWASHER
Whirlpool DU1065XTPB0 UNDERCOUNTER DISHWASHER
Whirlpool DU1065XTPB1 UNDERCOUNTER DISHWASHER
Whirlpool DU1065XTPQ0 UNDERCOUNTER DISHWASHER
Whirlpool DU1065XTPQ1 UNDERCOUNTER DISHWASHER
Whirlpool DU1065XTPS0 UNDERCOUNTER DISHWASHER
Whirlpool DU1065XTPS1 UNDERCOUNTER DISHWASHER
Whirlpool DU1098XLW0 Dishwasher
Whirlpool DU1098XLW1 Dishwasher
Whirlpool DU1098XRW0 Dishwasher
Whirlpool DU1098XRW1 Dishwasher
Whirlpool DU1099XT0 Dishwasher
Whirlpool DU1099XT1 Dishwasher
Whirlpool DU1099XT2 Dishwasher
Whirlpool DU1099XT3 Dishwasher
Whirlpool DU1100XTPB0 UNDERCOUNTER DISHWASHER
Whirlpool DU1100XTPB1 UNDERCOUNTER DISHWASHER
Whirlpool DU1100XTPB3 UNDERCOUNTER DISHWASHER
Whirlpool DU1100XTPB6 UNDERCOUNTER DISHWASHER
Whirlpool DU1100XTPB7 UNDERCOUNTER DISHWASHER
Whirlpool DU1100XTPB8 UNDERCOUNTER DISHWASHER
Whirlpool DU1100XTPB9 UNDERCOUNTER DISHWASHER
Whirlpool DU1100XTPBA UNDERCOUNTER DISHWASHER
Whirlpool DU1100XTPBB UNDERCOUNTER DISHWASHER
Whirlpool DU1100XTPQ0 UNDERCOUNTER DISHWASHER
Whirlpool DU1100XTPQ1 UNDERCOUNTER DISHWASHER
Whirlpool DU1100XTPQ3 UNDERCOUNTER DISHWASHER
Whirlpool DU1100XTPQ6 UNDERCOUNTER DISHWASHER
Whirlpool DU1100XTPQ7 UNDERCOUNTER DISHWASHER
Whirlpool DU1100XTPQ8 UNDERCOUNTER DISHWASHER
Whirlpool DU1100XTPQ9 UNDERCOUNTER DISHWASHER
Whirlpool DU1100XTPQA UNDERCOUNTER DISHWASHER
Whirlpool DU1100XTPQB UNDERCOUNTER DISHWASHER
Whirlpool DU1100XTPS0 UNDERCOUNTER DISHWASHER
Whirlpool DU1100XTPS1 UNDERCOUNTER DISHWASHER
Whirlpool DU1100XTPS3 UNDERCOUNTER DISHWASHER
Whirlpool DU1100XTPS6 UNDERCOUNTER DISHWASHER
Whirlpool DU1100XTPS7 UNDERCOUNTER DISHWASHER
Whirlpool DU1100XTPS8 UNDERCOUNTER DISHWASHER
Whirlpool DU1100XTPS9 UNDERCOUNTER DISHWASHER
Whirlpool DU1100XTPSA UNDERCOUNTER DISHWASHER
Whirlpool DU1100XTPSB UNDERCOUNTER DISHWASHER
Whirlpool DU1100XTPT0 UNDERCOUNTER DISHWASHER
Whirlpool DU1100XTPT1 UNDERCOUNTER DISHWASHER
Whirlpool DU1100XTPT3 UNDERCOUNTER DISHWASHER
Whirlpool DU1100XTPT6 UNDERCOUNTER DISHWASHER
Whirlpool DU1100XTPT7 UNDERCOUNTER DISHWASHER
Whirlpool DU1100XTPT8 UNDERCOUNTER DISHWASHER
Whirlpool DU1100XTPT9 UNDERCOUNTER DISHWASHER
Whirlpool DU1100XTPTA UNDERCOUNTER DISHWASHER
Whirlpool DU1100XTPTB UNDERCOUNTER DISHWASHER
Whirlpool DU1101XTPB0 UNDERCOUNTER DISHWASHER
Whirlpool DU1101XTPB1 UNDERCOUNTER DISHWASHER
Whirlpool DU1101XTPB3 UNDERCOUNTER DISHWASHER
Whirlpool DU1101XTPB6 UNDERCOUNTER DISHWASHER
Whirlpool DU1101XTPB7 UNDERCOUNTER DISHWASHER
Whirlpool DU1101XTPB8 UNDERCOUNTER DISHWASHER
Whirlpool DU1101XTPB9 UNDERCOUNTER DISHWASHER
Whirlpool DU1101XTPBA UNDERCOUNTER DISHWASHER
Whirlpool DU1101XTPBB UNDERCOUNTER DISHWASHER
Whirlpool DU1101XTPQ0 UNDERCOUNTER DISHWASHER
Whirlpool DU1101XTPQ1 UNDERCOUNTER DISHWASHER
Whirlpool DU1101XTPQ3 UNDERCOUNTER DISHWASHER
Whirlpool DU1101XTPQ6 UNDERCOUNTER DISHWASHER
Whirlpool DU1101XTPQ7 UNDERCOUNTER DISHWASHER
Whirlpool DU1101XTPQ8 UNDERCOUNTER DISHWASHER
Whirlpool DU1101XTPQ9 UNDERCOUNTER DISHWASHER
Whirlpool DU1101XTPQA UNDERCOUNTER DISHWASHER
Whirlpool DU1101XTPQB UNDERCOUNTER DISHWASHER
Whirlpool DU1101XTPS0 UNDERCOUNTER DISHWASHER
Whirlpool DU1101XTPS1 UNDERCOUNTER DISHWASHER
Whirlpool DU1101XTPS3 UNDERCOUNTER DISHWASHER
Whirlpool DU1101XTPS6 UNDERCOUNTER DISHWASHER
Whirlpool DU1101XTPS7 UNDERCOUNTER DISHWASHER
Whirlpool DU1101XTPS8 UNDERCOUNTER DISHWASHER
Whirlpool DU1101XTPS9 UNDERCOUNTER DISHWASHER
Whirlpool DU1101XTPSA UNDERCOUNTER DISHWASHER
Whirlpool DU1101XTPSB UNDERCOUNTER DISHWASHER
Magic Chef DU110CA-01 DISHWASHER- UNDERCOUNTER
Magic Chef DU110CA-02 DISHWASHER- UNDERCOUNTER
Magic Chef DU110CA-03 DISHWASHER- UNDERCOUNTER
Magic Chef DU110CA-04 DISHWASHER- UNDERCOUNTER
Magic Chef DU110CA-05 DISHWASHER- UNDERCOUNTER
Magic Chef DU110CA-20 DISHWASHER- UNDERCOUNTER
Magic Chef DU110DA-25 DISHWASHER- UNDERCOUNTER
Magic Chef DU110DA-35 DISHWASHER- UNDERCOUNTER
Magic Chef DU110DA-45 DISHWASHER- UNDERCOUNTER
Magic Chef DU110DA-48 DISHWASHER- UNDERCOUNTER
Whirlpool DU1145XTPB0 UNDERCOUNTER DISHWASHER
Whirlpool DU1145XTPB1 UNDERCOUNTER DISHWASHER
Whirlpool DU1145XTPB3 UNDERCOUNTER DISHWASHER
Whirlpool DU1145XTPB6 UNDERCOUNTER DISHWASHER
Whirlpool DU1145XTPB7 UNDERCOUNTER DISHWASHER
Whirlpool DU1145XTPB8 UNDERCOUNTER DISHWASHER
Whirlpool DU1145XTPB9 UNDERCOUNTER DISHWASHER
Whirlpool DU1145XTPBA UNDERCOUNTER DISHWASHER
Whirlpool DU1145XTPQ0 UNDERCOUNTER DISHWASHER
Whirlpool DU1145XTPQ1 UNDERCOUNTER DISHWASHER
Whirlpool DU1145XTPQ3 UNDERCOUNTER DISHWASHER
Whirlpool DU1145XTPQ6 UNDERCOUNTER DISHWASHER
Whirlpool DU1145XTPQ7 UNDERCOUNTER DISHWASHER
Whirlpool DU1145XTPQ8 UNDERCOUNTER DISHWASHER
Whirlpool DU1145XTPQ9 UNDERCOUNTER DISHWASHER
Last edited by xxxsdesdexxx : 12-29-2013 at 01:56 PM. Reason: title should say "not working" rather than "now working"
  #2 (permalink)
Old 12-30-2013, 08:57 PM
Junior Member
Default
I used the tech sheet found here Tech Sheet - W10130990 and checked my control pad. When using the "Keyswitch Resistance Check Table" located near the bottom center of page 1, I got no voltage at all using any of the buttons on the keypad when doing the Diode test on the control panel's ribbon using my digital multimeter. I'm assuming that my control pad is bad now that I have seen that no voltages are present -- yes I am pressing the buttons when the leads are connected to their proper positions. I also checked the P1 connector pins on the control board and those all show voltages of ~ 2.1 or so.
  #3 (permalink)
Old 01-03-2014, 04:03 PM
Junior Member
Default
So I just got the new control panel and and the dishwasher still shuts itself off. If I replaced the control board and the control panel, why is the dishwasher still shutting itself off?
  #4 (permalink)
Old 01-03-2014, 11:07 PM
Junior Member
Default
I really need some help with this dishwasher. I've taken it apart so many times and can't figure it out.
  #5 (permalink)
Old 01-09-2014, 09:03 AM
Junior Member
decepticon07 is on a distinguished road
Default
Hello,
I have the same model dishwasher (DU1055XTVS) and it started shutting off on me as well. The last time I ran it, it shut off after the tank filled up and the jets started spraying. Then I started the cycle again, and it ran for about 15 minutes before shutting off. The third time I started it is when it completed the cycle. I bought it at Best Buy almost four years ago. Fortunately I put a five year warranty on it. A technician came and checked it today. He is going to order a control board for it. Hopefully that will solve the issue for me.
  #6 (permalink)
Old 01-09-2014, 07:12 PM
Junior Member
Default
I'm still working on this but I think I may have found the source of the problem. All in all I have replaced, in order, the Control Board W10084142, Control Panel/Pad W10459139, Wiring Harness W10328603, and will be replacing the Turbidity sensor W10134017. After pulling the dishwasher completely out in order to install the new wiring harness, I discovered that the wire
that plugged into the turbidity sensor had been charred and most of the copper from the sensor had turned to patina (green). Water got onto the circuit board within the sensor housing and caused it to short circuit and fry.
-- I will admit that this may not have originally been a problem because I did at one point loosen it and reinstall it during my troubleshooting but maybe this problem was present all along; I will never know since I didn't pay attention at the time. Here's a picture of the Turbidity Sensor taken apart (I started the scrape the patina off -- the copper was completely green before)
I will be replacing this part tomorrow and I will get back to this thread to let you know the outcome. My recommendation is to pull the dishwasher completely out -- it's really not that hard -- and take a look to see what's going on underneath the dishwasher. You can only do so much by taking the door off and laying on the ground looking underneath. If you don't do this, you might be replacing parts that are working just fine.
  #7 (permalink)
Old 01-09-2014, 09:56 PM
Junior Member
AntonioStogsdill is on a distinguished road
Default
Did you replace that..?I think it will work better if you replace with original parts.
The Lost Ways
  #8 (permalink)
Old 01-09-2014, 10:01 PM
Junior Member
Default
Quote:
Yes, I bought a new wiring harness and I also ordered a new turbidity sensor which will be arriving tomorrow.
  #9 (permalink)
Old 01-11-2014, 01:24 PM
Junior Member
Default
I can now report that the dishwasher works and finishes its cycles.
  #10 (permalink)
Old 02-21-2015, 03:20 PM
Junior Member
Emlg is on a distinguished road
Default
I have the Whirpool Quiet Partner II and its doing the same thing.
It starts, pulls water but then it stops.
I have to hit drain/cancel and start again.
It does that 2-3 times then it finally starts and completes the cycle.
Now it's been acting up more. Like not starting having to open and close the lid on and off, holding the power button longer, the cancel button.
Can you help?
What would be the first thing to look at?
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Whirlpool Quiet Partner III will not turn on - has power to control panel. rramkumar Dishwasher Repair 0 10-25-2013 03:55 PM
WhirlPool Quiet Partner II No Power AnneZ Dishwasher Repair 0 01-11-2013 05:54 AM
No Power to Whirlpool Quiet Partner 2 josalbrec Dishwasher Repair 0 12-26-2010 07:05 AM
Whirlpool Quiet Partner 2 no power lordcrom Dishwasher Repair 1 07-21-2009 02:03 PM
Whirlpool gold quiet partner III no power pops Dishwasher Repair 1 05-08-2009 11:54 AM
