So here's the deal, I not sure about the history of this particular washer, we acquired it through purchase of our current home. I'm guessing it's age. Any way, I've had problems with it in the past, all the lights on the control panel would illuminate randomly and I'd pull the plug for a couple minutes and everything would turn out fine. This time however, I've pulled the plug multiple times and no joy. My only indication of power is the "2 Hour" delay light is on and blinks when I hit any other button other than the "Pots & Pans" option, in which case it stays steady. Other things of value I've noticed, the last cycle it did complete, the secondary soap holder did not deploy. Other than that, cycle completed fine. Reading some of the other forums I've concluded it's a control board or control panel problem. Just not sure how to tell which it is. I've tested the thermal fuse and it is functioning properly. Any other trouble shooting tips/tricks out there?
Thanks guys.
Tryin2GetBy
