123POW
#1 Posted : Friday, October 16, 2009 10:28:55 AM(UTC)
123POW
Purchased this dishwasher 2007, had the motor or pump replaced in 2008 because it developed a loud whining noise. Now it is making the same noise again. I suspect the motor/pump needs to be replaced again? Are instructions available? I beleive it is out of warranty.
#2 Posted : Friday, October 16, 2009 5:53:53 PM(UTC)
Replacement parts for WHIRLPOOL GU2700XTSQ1 | AppliancePartsPros.com
Here is the tech sheet
http://www.servicematters.com/d...heet%20-%20W10130990.pdf
Here is a manual that I believe uses the same pump as yours
https://secured.whirlpoo...520548/$FILE/8178022.pdf
Be sure to check the chopper area just in case something in there is causing the noise.
