Discuss
Whirlpool Duet Washer won't turn on
 in
Dishwasher Repair
I have a Whirlpool Model #WFW9200SQ00 and have had it for less than 2 years. I bought it from Lowes
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » Whirlpool Duet Washer won't turn on
  #1 (permalink)
Old 10-14-2009, 06:52 PM
tommyhal tommyhal is offline
Junior Member
tommyhal is on a distinguished road
Question Whirlpool Duet Washer won't turn on
Model Number: WFW9200SQ00   Brand: Whirlpool   Age: 1 - 5 years
I have a Whirlpool Model #WFW9200SQ00 and have had it for less than 2 years. I bought it from Lowes and called them to get it repaired and they sent a repairman. Since it was more than 1 yr. the warranty was out. The problem is that it won't turn on when you press the Power button. The repairman checked a few things and called someone at Sears repair center and told him the symptoms and then checked a few more things and they decided the door switch was the problem. The repairman didn't have any parts for the washer even though we had to set up an appointment and gave him the Manufacturer and Model Number and had to wait a week to get him out here. He had a door switch sent out here the following Tuesday by UPS and returned on Thursday to install it and it didn't fix it. He said the CCU was the problem since the door switch didn't fix it and the CCU would cost $400 but he said he'd take the door switch back and send a check for the $100 I had paid for that. I told him I wasn't gonna spend $400 for a CCU as I'd only paid $600 for the washer to start with. I had already seen the CCU at your web site for $268.85 so I bought a CCU from you (Order Date: 10/1/2009 Order Number: 845739) to try to fix the problem and installed it myself. Nothing's changed. I now have $129 in a service call to a repairman that knew no more about it than I do plus $100 for the door switch if he doesn't send the money back and $268.85 plus shipping to you guys and still have the same problem. When you press the Power on button all it does is give 3 quick audible dings. I can lock the controls and unlock them and can get the maintenance codes by pressing the Water Temp button for 3 seconds and release for 3 sec. and press and release for total of three times. All the led's light up even around the knob, then it displays the codes C:00 - Ding - C:00 - Ding - C:00 - Ding - U:01 - Ding - U:00 - Ding - U:00 - Ding - C:00 - Ding - n:00 - Ding - off - Ding - C:00 and stops till you press Pause/Cancel. What else can the problem be?
Thanks for any help you can give.
Tommy Hall
Related Models
Whirlpool WFW9200SQ00 Automatic Washer
Whirlpool WFW9200SQ01 Automatic Washer
Whirlpool WFW9200SQ02 Automatic Washer
Whirlpool WFW9200SQ10 Automatic Washer
Whirlpool WFW9200SQA10 Automatic Washer
Whirlpool WFW9200SQA11 Automatic Washer
Whirlpool WFW9400SB00 Automatic Washer
Whirlpool WFW9400SB01 Automatic Washer
Whirlpool WFW9400SBA10 Automatic Washer
Whirlpool WFW9400ST00 Automatic Washer
Whirlpool WFW9400ST01 Automatic Washer
Whirlpool WFW9400STA10 Automatic Washer
Whirlpool WFW9400SU00 Automatic Washer
Whirlpool WFW9400SU01 Automatic Washer
Whirlpool WFW9400SW00 Automatic Washer
Whirlpool WFW9400SW01 Automatic Washer
Whirlpool WFW9400SWA10 Automatic Washer
Whirlpool WFW9400SZ00 Automatic Washer
Whirlpool WFW9400SZ01 Automatic Washer
Whirlpool WFW9400SZA10 Automatic Washer
Whirlpool WFW9600TA00 Automatic Washer
Whirlpool WFW9600TB00 Automatic Washer
Whirlpool WFW9600TC00 Automatic Washer
Whirlpool WFW9600TU00 Automatic Washer
Whirlpool WFW9600TW00 Automatic Washer
Whirlpool WFW9600TZ00 Automatic Washer
Amana WG1010.000 Commercial Microwaves
Amana WG1010.010 Commercial Microwaves
Amana WG1010.200 Commercial Microwaves
Amana WG1021.000 Commercial Microwaves
Amana WG1021.200 Commercial Microwaves
Amana WG1065.000 Commercial Microwaves
Amana WG1120.500 Commercial Microwaves
Amana WG1120.600 Commercial Microwaves
Amana WG1121.000 Commercial Microwaves
Amana WG1165.000 Commercial Microwaves
Amana WG1165.700 Commercial Microwaves
Amana WG1166.500 Commercial Microwaves
Jenn-Air WG200 Walloven - Cont Clean Gas
Jenn-Air WG206 Walloven - Cont Clean Gas
Jenn-Air WG24000B Walloven - Std Gas
Jenn-Air WG24000W Walloven - Std Gas
Jenn-Air WG30100B Walloven - S/c Gas
Jenn-Air WG30100W Walloven - S/c Gas
Amana WG445.1 Commercial Microwaves
Amana WG445.2 Commercial Microwaves
Whirlpool WGD5100SQ0 29" Gas Dryer
Whirlpool WGD5200TQ0 29" Gas Dryer
Whirlpool WGD5300SQ0 29"gas Dryer
Whirlpool WGD5300ST0 29"gas Dryer
Whirlpool WGD5310SQ0 29"gas Dryer
Whirlpool WGD5320SQ0 29"gas Dryer
Whirlpool WGD5321SQ0 29"gas Dryer
Whirlpool WGD5500SQ0 29"gas Dryer
Whirlpool WGD5500ST0 29"gas Dryer
Whirlpool WGD5520SQ0 29" Gas Dryer
Whirlpool WGD5521SQ0 29"gas Dryer
Whirlpool WGD5530SQ0 29"gas Dryer
Whirlpool WGD5540SQ0 29"gas Dryer
Whirlpool WGD5540ST0 29"gas Dryer
Whirlpool WGD5550SQ0 29" Gas Dryer
Whirlpool WGD5550ST0 29" Gas Dryer
Whirlpool WGD5560SQ0 29" Gas Dryer
Whirlpool WGD5600SQ0 29" Gas Dryer
Whirlpool WGD5600ST0 29" Gas Dryer
Whirlpool WGD5700SW0 29" Gas Dryer
Whirlpool WGD5790SQ0 29" Gas Dryer
Whirlpool WGD5790ST0 29" Gas Dryer
Whirlpool WGD5800SG0 29"gas Dryer
Whirlpool WGD5800SW0 29"gas Dryer
Whirlpool WGD5810SW0 29"gas Dryer
Whirlpool WGD5820SW0 29"gas Dryer
Whirlpool WGD5821SW0 29"gas Dryer
Whirlpool WGD5830SW0 29"gas Dryer
Whirlpool WGD5840SG0 29"gas Dryer
Whirlpool WGD5840SW0 29"gas Dryer
Whirlpool WGD5850SG0 29"gas Dryer
Whirlpool WGD5850SW0 29"gas Dryer
Whirlpool WGD5856SG0 29"gas Dryer
Whirlpool WGD5860SW0 29"gas Dryer
Whirlpool WGD5900SB0 29" Gas Dryer
Whirlpool WGD5900SW0 29" Gas Dryer
Whirlpool WGD6200SW0 29"gas Dryer
Whirlpool WGD6200SW1 29" Gas Dryer
Whirlpool WGD6400SB0 29"gas Dryer
Whirlpool WGD6400SB1 29"gas Dryer
Whirlpool WGD6400SG0 29"gas Dryer
Whirlpool WGD6400SG1 29"gas Dryer
Whirlpool WGD6400SW0 29"gas Dryer
Whirlpool WGD6400SW1 29"gas Dryer
Whirlpool WGD8300SB0 27" Gas Dryer
Whirlpool WGD8300SB1 27" Gas Dryer
Whirlpool WGD8300SW0 27" Gas Dryer
Whirlpool WGD8300SW1 27" Gas Dryer
Whirlpool WGD8410SW0 27"gas Dryer
Whirlpool WGD8410SW1 27" Gas Dryer
Whirlpool WGD8500SR0 27"gas Dryer
Whirlpool WGD8500SR1 27" Gas Dryer
Whirlpool WGD9200SQ0 Gas Dryer
Whirlpool WGD9400SB0 Gas Dryer
Whirlpool WGD9400ST0 Gas Dryer
Whirlpool WGD9400SU0 Gas Dryer
Whirlpool WGD9400SW0 Gas Dryer
Whirlpool WGD9400SZ0 Gas Dryer
Whirlpool WGD9500TC0 Gas Dryer
Whirlpool WGD9500TU0 Gas Dryer
Whirlpool WGD9500TW0 Gas Dryer
Whirlpool WGD9600SU0 Gas Dryer
Whirlpool WGD9600TA0 27" Gas Dryer
Whirlpool WGD9600TB0 27" Gas Dryer
Whirlpool WGD9600TU0 27" Gas Dryer
Whirlpool WGD9600TW0 27" Gas Dryer
Whirlpool WGD9600TZ0 27" Gas Dryer
Whirlpool WGE30302 30" Electric Range Coil Cooktop
Whirlpool WGE32301 30"electric Range Coil Cooktop E - Z Clean Oven
Whirlpool WGE33001 30" Electric Range E - Z Clean Oven
Whirlpool WGE33301 30" Electric Range
Whirlpool WGE34303 30" Electric Range E - Z Clean Oven
Whirlpool WGE34304 30" Electric Range E - Z Clean Oven
White Westinghouse WGF317ESA White Westinghouse/range
  #2 (permalink)
Old 11-06-2009, 09:01 PM
lightenfx lightenfx is offline
Junior Member
lightenfx is on a distinguished road
Default Did you ever find a solution?
Hello Tommyhal,
I have the exact same problem, I believed the locking mechanism was the issue, however I replaced it and the machine kept doing the same.
Did you ever find a solution to your problem? I checked my connections and nothing seems to be damaged, the CCU seems to be working or else the diagnostics would not run (well it's what I am led to believe). Please post any other info you may have,
Thanks.
  #3 (permalink)
Old 11-08-2009, 07:24 AM
Junior Member
Default
Quote:
Originally Posted by lightenfx View Post
Hello Tommyhal,
Thanks.
I replaced the CCU and the door switch and neither had any effect on the problem or the codes. I returned the CCU and door switch for refund and as of yet have done no more. We had cheched every voltage, wires for continuity and connections and have found nothing. One tech responded that possibly the new CCU was bad, but like you say, I get all diags. and the only error is "door switch" and if it sits long enough after running diags. we get a 71 code that says User Interface to CCU not communicating? I'm ready to bust it up and get a mechanical machine. I still have a Fisher-Paykel that's fine after replacing a leaking pump 2 yrs ago, when I bought this headache.
  #4 (permalink)
Old 11-08-2009, 08:53 AM
7ntxx 7ntxx is offline
Junior Member
7ntxx is on a distinguished road
Default
Quote:
Tommy, Last night I got the exact same symptons you cited in your original post (down to the series of codes "C00" etc.). From what I had read on various sites/posts, it seems that loose connectors are the main culprit. After spends 10s of minutes wiggling various connectors, my washer came back to life (it's doing the first load now so who knows how long it will last). The last connectors that I manipulated seemed to be the set of 4 (3 white, one green) at the end of the electronics cluster at the front right of the machine (as you look at it with the top cover off. I have no idea if this is a coincidence or not.
FWIW, I had the F70 error code before it started failing to power up at all. I got this error code very soon after I fist got the machine 2 years ago. The service tech unplugged/replugged a few connectors, it started working, and he pronounced it something that had wiggled loose in shipping process. I was dubious but it did continue to work until last night. Seems like a problem with the overall design if things can wiggle loose on a device that is intended to have a lot if vibration and motion in the first place!!
HTH, Mike
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Stupid Whirlpool Duet Wont Turn On sarawins Washer Repair 3 09-30-2009 03:47 PM
Whirlpool Duet Dryer clicks, but does not turn KPfromIowa Dryer Repair 3 08-11-2009 08:40 PM
whirlpool duet washer won't run JenniferB Washer Repair 3 07-06-2009 01:57 PM
Whirlpool Duet washer Giacalone Washer Repair 1 01-30-2009 03:20 AM
Whirlpool Duet HT Washer PeterMNelson Dishwasher Repair 0 05-09-2008 04:36 PM
