Discuss
Dishwasher Not heating
 in
Dishwasher Repair
I have a Whirlpool Quiet Partner ll and the Clean light blinks 7 times during the wash cycle. I've run
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » Dishwasher Not heating
  #1 (permalink)
Old 12-04-2013, 10:38 AM
Junior Member
Kenpilot is on a distinguished road
Default Dishwasher Not heating
Brand: Whirlpool   Age: 1 - 5 years
I have a Whirlpool Quiet Partner ll and the Clean light blinks 7 times during the wash cycle. I've run through the reset procedure found on this website and it runs fine for 1 cycle and then the next cycle I get the flashing Clean light again. I ran hot water at the sink first before starting the next cycle and then ran the dishwasher for a couple mins and checked the water temp and its only 89 degrees. Felt the heater element as well and it isn't warm at all. I also noticed even when the dishwasher ran through the entire cycle after the reset procedure, the dishes were still all wet and were as if they were never dried, even though the Heated Dry was selected. Question is, How can I tell if it's just the heater element that's bad or the thermostat or control board? Thanks for any help!
Mod # DU1100XTPBA
  #2 (permalink)
Old 12-05-2013, 01:43 AM
Senior Expert
APP Volunteer
denman is a splendid one to behold
Default
You need a meter.
Then you measure the heating element for continuity (usually around 20 ohms).
Measure across the thermostat, should be 0 ohms.
If both OK measure the combo at the control board just to be sure it is not a bad wire.
If OK then odds are the board is shot.
Note that some units run just the heater through one of the door switches.
You will have to check the wiring diagram just in case yours does this.
4. When you start always short the meter leads together. This will tell you that the meter is working and if there is any 0 offset.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Dishwasher not heating misschief Dishwasher Repair 1 08-12-2011 06:59 AM
Dishwasher not heating Lindagayle428 Dishwasher Repair 1 12-21-2010 09:33 AM
dishwasher spray arm melted to heating element and now dishwasher not working msphillips2 Dishwasher Repair 0 05-08-2010 10:21 AM
Dishwasher not heating Richard Mastroberte Dishwasher Repair 1 05-31-2009 08:55 AM
Dishwasher not heating maebee1 Dishwasher Repair 0 03-06-2008 11:15 AM
