Discuss
Roper dishwasher will not run cycles
 in
Dishwasher Repair
Basin fills with water, the switch turns off the flow then when the wash cycle goes to engage it makes
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » Roper dishwasher will not run cycles
  #1 (permalink)
Old 12-03-2013, 11:53 AM
Junior Member
Lfrisk is on a distinguished road
Default Roper dishwasher will not run cycles
Model Number: RUD4000SQ1   Brand: Roper   Age: 1 - 5 years
Basin fills with water, the switch turns off the flow then when the wash cycle goes to engage it makes a humming noise for a few seconds then the machine stops. At this point the basin will not drain, and I cannot get the machine to run any of the cycles. I turn the selector to each cycle and it does the same thing, hums for a few seconds then stops.
Related Models
Roper RUD4000SQ1 UNDERCOUNTER DISHWASHER
Roper RUD4000SU0 UNDERCOUNTER DISHWASHER
Roper RUD4300DQ2 UNDER-COUNTER DISHWASHER
Roper RUD4300DQ3 DISHWASHERS
Roper RUD4500DB0 UNDERCOUNTER DISHWASHER
Roper RUD4500DB1 UNDERCOUNTER DISHWASHER
Roper RUD4500DB2 UNDERCOUNTER DISHWASHER
Roper RUD4500DB3 DISHWASHERS
Roper RUD4500DB4 UNDERCOUNTER DISHWASHER
Roper RUD4500MB0 UNDERCOUNTER DISHWASHER
Roper RUD4500MB2 UNDERCOUNTER DISHWASHER
Roper RUD4500MQ0 UNDERCOUNTER DISHWASHER
Roper RUD4500MQ2 UNDERCOUNTER DISHWASHER
Roper RUD5000HB0 DISHWASHER
Roper RUD5000HB1 DISHWASHER
Roper RUD5000HQ0 DISHWASHER
Roper RUD5000HQ1 DISHWASHER
Roper RUD5000KB0 DISHWASHER
Roper RUD5000KB1 UNDERCOUNTER DISHWASHER
Roper RUD5000KQ0 DISHWASHER
Roper RUD5000KQ1 UNDERCOUNTER DISHWASHER
Roper RUD5750DB0 UNDERCOUNTER DISHWASHER
Roper RUD5750DB1 UNDERCOUNTER DISHWASHER
Roper RUD5750DB2 DISHWASHER
Roper RUD5750DB3 DISHWASHERS
Roper RUD5750DB4 UNDERCOUNTER DISHWASHER
Roper RUD5750DQ0 UNDERCOUNTER DISHWASHER
Roper RUD5750DQ1 UNDERCOUNTER DISHWASHER
Roper RUD5750DQ2 DISHWASHER
Roper RUD5750DQ3 DISHWASHERS
Roper RUD5750DQ4 UNDERCOUNTER DISHWASHER
Roper RUD5750HB0 DISHWASHER
Roper RUD5750HQ0 DISHWASHER
Roper RUD5750KB0 DISHWASHER
Roper RUD5750KB1 DISHWASHER
Roper RUD5750KQ0 DISHWASHER
Roper RUD5750KQ1 DISHWASHER
Roper RUD6000PB2 UNDERCOUNTER DISHWASHER
Roper RUD6000PQ2 UNDERCOUNTER DISHWASHER
Whirlpool RUD6050RD0 UNDERCOUNTER DISHWASHER
Roper RUD6050RD2 UNDERCOUNTER DISHWASHER
Roper RUD8000RQ0 UNDERCOUNTER DISHWASHER
Roper RUD8000RQ1 UNDERCOUNTER DISHWASHER
Roper RUD8000SQ0 UNDERCOUNTER DISHWASHER
Roper RUD8050RD0 UNDERCOUNTER DISHWASHER
Roper RUD8050SD0 UNDERCOUNTER DISHWASHER
Roper RUD8050SD1 UNDERCOUNTER DISHWASHER
Roper RUD8050SD2 UNDERCOUNTER DISHWASHER
Amana RV-10 COMMERCIAL MICROWAVES
Amana RV-10A COMMERCIAL MICROWAVES
Amana RV-8 COMMERCIAL MICROWAVES
Amana RV10 COMMERCIAL MICROWAVES
Roper RV1088RBW00 VERTICAL FREEZER
Amana RV10A COMMERCIAL MICROWAVES
Amana RV10AT COMMERCIAL MICROWAVES
Roper RV1299RBW00 FREEZER
Roper RV1299RBW01 FREEZERS
Roper RV1299REW00 REFRIGERATORS
Roper RV1299REW01 UPRIGHT FREEZER
Roper RV1299REW02 UPRIGHT FREEZER
Roper RV12EFRXW00 Freezers*
Amana RV1450.000 MWAVE - FAMILY SIZE (60 HZ)
Amana RV1450.004 MWAVE - FAMILY SIZE (60 HZ)
Amana RV1450.102 MWAVE - FAMILY SIZE (60 HZ)
Roper RV1599RBW00 VERTICAL FREEZER
Roper RV1599RBW01 FREEZERS
Roper RV1599REW00 VERTICAL FREEZER
Roper RV1599REW01 VERTICAL FREEZER
Roper RV1599REW02 VERTICAL FREEZER
Roper RV1599REW03 FREEZER
Roper RV15EFRAW00 VERTICAL FREEZER
Roper RV15EFRDW00 VERTICAL FREEZER
Roper RV15EFRDW01 REFRIGERATORS
Roper RV15EFREW00 VERTICAL FREEZER
Roper RV15EFREW01 VERTICAL FREEZER
Roper RV15EFREW02 VERTICAL FREEZER
Roper RV15EFREW03 FREEZER
Roper RV15EFRXW00 Freezers*
Roper RV2099RBW00 VERTICAL FREEZER
Roper RV2099RBW01 VERTICAL FREEZER
Roper RV2099REW00 VERTICAL FREEZER
Roper RV2099REW01 UPRIGHT FREEZER
Roper RV2099REW02 FREEZER
Amana RV8 COMMERCIAL MICROWAVES
 RVC30 RAISED VENT
 RVC36 RAISED VENT
 RVC46 RAISED VENT
Whirlpool RVE30100 30" ELECTRIC FREESTANDING STANDARD CLEAN RANGE
Frigidaire RVG12C1WT2A Gib(v1) / Top Mount Refrigerator
Amana RVH-2 RANGE- S/C S/I DDRAFT GAS
Amana RVH-5 MWAVE- MOUNTED OVER RANGE/WO
Amana RVH-6 RANGE- S/C S/I DDRAFT GAS
Amana RVH1L HOOD
Amana RVH1L HOOD
Amana RVH1L HOOD
Amana RVH1S MWAVE- MOUNTED OVER RANGE/WO
Amana RVH1SS HOOD
Amana RVH1SS HOOD
Amana RVH1W HOOD
Amana RVH1W HOOD
Amana RVH1W HOOD
Amana RVH4B HOOD
Amana RVH4C HOOD
Amana RVH5B HOOD
Amana RVH5C HOOD
Amana RVH6 HOOD
Amana RVH6 HOOD
Amana RVH7 HOOD
Amana RVH7 HOOD
Amana RVHB8 HOOD
Amana RVHB8 HOOD
Amana RVHRC1 ELE CARTRIDGE
Amana RVHW8 HOOD
  #2 (permalink)
Old 12-04-2013, 05:17 AM
Senior Expert
APP Volunteer
denman is a splendid one to behold
Default
RUD4000SQ1
You have to find out where the hum is coming from.
I suspect it is the motor.
Sounds like it is overheating and then tripping an internal thermal protect.
Could be it is seized or the impeller has something in it.
Check that the armature turns easily.
If it is OK check across it for 120 volts when it should be running.
If you get 120 then the motor is toast.
If the voltage is low, check across the start relay contacts.
There should be 0 volts when the relay is closed.
If there is voltage then the relay contacts are bad re: they are dropping voltage so there is not enough voltage across the motor to start it.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Roper Washing Machine, No cycles work, Not draining 13steps Washer Repair 0 05-05-2012 02:27 PM
Roper Dryer won't heat and doesn't run in all cycles fnelson Dryer Repair 0 01-06-2012 03:03 PM
Intermittent Cycles Roper Machine agdodge4x4 Washer Repair 1 11-08-2011 07:05 PM
Roper Washer will not change cycles mestes Washer Repair 7 01-06-2011 12:11 PM
Roper gas dryer cycles a few times fine then no flame Honey-Do Dryer Repair 0 08-25-2010 05:08 PM
