My Kenmore dishwasher door does not stay latched, and the dishwasher keeps stopping. The door will latch but it does not hold it securely enough. It seems likely that either the latch on the door, or the wire loop that inserts in it to close the latch, is the problem. The wire loop is slightly crooked, see picture. Are these parts available and easy enough to install for an amateur? Any other solutions to try first? Thanks Dmazur1945 attached the following image(s):
