Discuss
How to Measure Current in Main Power Line
 in
Dishwasher Repair
Greetings, I've been troubleshooting my Bosch SHU5315 dishwasher using the Bosch self test program. I've proceeded through the "Heating &
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » How to Measure Current in Main Power Line
  #1 (permalink)
Old 11-24-2013, 10:09 AM
Junior Member
jdirmeyer is on a distinguished road
Default How to Measure Current in Main Power Line
Model Number: SHU5315UC   Brand: Bosch   Age: 5 - 10 years
Greetings,
I've been troubleshooting my Bosch SHU5315 dishwasher using the Bosch self test program. I've proceeded through the "Heating & Circulating" test and it's been running in that test for 45 minutes leading me to believe, per instructions, that I've either got a Heater, Hi-Limit, or Flow switch problem. Instructions say "measure current in main power line to dishwasher". Correct amperage is 11. But, how do you do this exactly? I do have a digital multimeter and have used it before in many automotive projects. Would appreciate some instructions on where you take this measurement and how?
Thanks!
Related Models
Bosch SHU5316 UC/06
Bosch SHU5316 UC/11
Bosch SHU5316 UC/12
Bosch SHU5317 UC/12
Bosch SHU53A02 UC/14 (FD 8211-)
Bosch SHU53A05 UC/14 (FD 8211-)
Bosch SHU53A06 UC/14 (FD 8211-)
Bosch SHU53E02 UC/14 (FD 8211-)
Bosch SHU53E05 UC/14 (FD 8211-)
Bosch SHU53E06 UC/14 (FD 8211-)
Whirlpool SHU55010 Dishwasher
Whirlpool SHU55040 Dishwasher
Whirlpool SHU55042 Dishwasher
Whirlpool SHU60020 Dishwasher
Bosch SHU66C02 UC/14 (FD 8211-)
Bosch SHU66C05 UC/14 (FD 8211-)
Bosch SHU66C06 UC/14 (FD 8211-)
Bosch SHU66C07 UC/14 (FD 8211-)
Bosch SHU66E02 UC/14 (FD 8211-)
Bosch SHU66E05 UC/14 (FD 8211-)
Bosch SHU66E06 UC/14 (FD 8211-)
Bosch SHU66E07 UC/14 (FD 8211-)
Bosch SHU6802 UC/06 (FD 7705-7912)
Bosch SHU6802 UC/11 (FD 8001-8003)
Bosch SHU6802 UC/12 (FD 8003-)
Bosch SHU6805 UC/06 (FD 7705-7912)
Bosch SHU6805 UC/11 (FD 8001-8003)
Bosch SHU6805 UC/12 (FD 8003-)
Bosch SHU6806 UC/06 (FD 7705-7912)
Bosch SHU6806 UC/11 (FD 8001-8003)
Bosch SHU6806 UC/12 (FD 8003-)
Whirlpool SHU70010 Dishwasher
Whirlpool SHU70041 Dishwasher
Whirlpool SHU70050 Dishwasher
Whirlpool SHU70051 Dishwasher
Whirlpool SHU70052 Dishwasher
Whirlpool SHU75010 Dishwasher
Whirlpool SHU75042 Dishwasher
Whirlpool SHU80010 Dishwasher
Whirlpool SHU80041 Dishwasher
Whirlpool SHU80042 Dishwasher
Bosch SHU8802 UC/12 (FD 8105-)
Bosch SHU8805 UC/12 (FD 8105-)
Bosch SHU8806 UC/12 (FD 8105-)
Bosch SHU8812 UC/12 (FD 8105-)
Bosch SHU8815 UC/12 (FD 8105-)
Bosch SHU8816 UC/12 (FD 8105-)
Whirlpool SHU90002 Dishwasher
Whirlpool SHU90041 Dishwasher
Whirlpool SHU90050 Dishwasher
Bosch SHU9902 UC/06
Bosch SHU9902 UC/06 (FD 7905-7912)
Whirlpool SHU99041 Dishwasher
Bosch SHU9905 UC/06
Bosch SHU9905 UC/06 (FD 7905-7912)
Whirlpool SHU99052 Dishwasher
Whirlpool SHU99053 Dishwasher
Bosch SHU9906 UC/06
Bosch SHU9906 UC/06 (FD 7905-7912)
Bosch SHU9912 UC/06
Bosch SHU9912 UC/06 (FD 7908-8002)
Bosch SHU9912 UC/11
Bosch SHU9912 UC/11 (FD 8002-8003)
Bosch SHU9912 UC/12
Bosch SHU9912 UC/12 (FD 8003-)
Bosch SHU9915 UC/06
Bosch SHU9915 UC/06 (FD 7908-8002)
Bosch SHU9915 UC/11
Bosch SHU9915 UC/11 (FD 8002-8003)
Bosch SHU9915 UC/12
Bosch SHU9915 UC/12 (FD 8003-)
Bosch SHU9916 UC/06
Bosch SHU9916 UC/06 (FD 7908-8002)
Bosch SHU9916 UC/11
Bosch SHU9916 UC/11 (FD 8002-8003)
Bosch SHU9916 UC/12
Bosch SHU9916 UC/12 (FD 8003-)
Bosch SHU9922 UC/12 (FD 8003-)
Bosch SHU9925 UC/12 (FD 8003-)
Bosch SHU9926 UC/12 (FD 8003-)
Bosch SHU9952 UC/12 (FD 8105 -)
Bosch SHU9955 UC/12 (FD 8105 -)
Bosch SHU9956 UC/12 (FD 8105 -)
Bosch SHV4303 UC/06
Bosch SHV4303 UC/06 (FD 7712-8002)
Bosch SHV4303 UC/11
Bosch SHV4303 UC/11 (FD 8002-8003)
Bosch SHV4303 UC/12
Bosch SHV4303 UC/12 (FD 8003-)
Bosch SHV46C03 UC/14 (FD 8211-)
Bosch SHV4803 UC/06
Bosch SHV4803 UC/06 (FD 7712-7812, 7905-7907)
Bosch SHV4803 UC/07
Bosch SHV4803 UC/07 (FD 7812-7905, 7907-8010)
Bosch SHV4803 UC/12
Bosch SHV66A03 UC/14 (FD 8301-)
Bosch SHV6803 UC/12 (FD 8105 -)
Bosch SHV99A03 UC/14 (FD 8212-)
Hoover SHWA2501A WASHER-TOP LOADING
Hoover SHWA2501W WASHER-TOP LOADING
Hoover SHWA2506A WASHER-TOP LOADING
Hoover SHWA2506AT WASHER-TOP LOADING
Hoover SHWA2506W WASHER-TOP LOADING
Hoover SHWA2506WT WASHER-TOP LOADING
Hoover SHWA2507V WASHER-TOP LOADING
Bosch SHX33A02 UC/14 (FD 8211-)
Bosch SHX33A05 UC/14 (FD 8211-)
Bosch SHX33A06 UC/14 (FD 8211-)
Bosch SHX43E02 UC/14 (FD 8211-)
Bosch SHX43E05 UC/14 (FD 8211-)
Bosch SHX43E06 UC/14 (FD 8211-)
Bosch SHX46A02 UC/14 (FD 8211-)
Bosch SHX46A05 UC/14 (FD 8211-)
Bosch SHX46A06 UC/14 (FD 8211-)
Bosch SHX46A07 UC/14 (FD 8211-)
Bosch SHX46B02 UC/14 (FD 8211-)
Bosch SHX46B05 UC/14 (FD 8211-)
Bosch SHX46B06 UC/14 (FD 8211-)
Bosch SHX46B07 UC/14 (FD 8211-)
Bosch SHX56B02 UC/14 (FD 8211-)
  #2 (permalink)
Old 11-24-2013, 11:29 AM
Senior Member
Appliance Ninja is on a distinguished road
Default
You would need a clamp on style ammeter to measure the current draw, clamped on to the main wire supplying voltage to the unit. The most common issue to cause no heat is a poor solder connection on the heater relay on the board. It is easy enough to access and visibly inspect the solder side of the control. The picture below shows what you will likely find. Let me know what inspection turns up!
  #3 (permalink)
Old 11-24-2013, 11:44 AM
Junior Member
Default
Ninja,
I've checked the board and it's clean, no discernible problems there. So, on to the current check. You suggest, "a clamp on style ammeter to measure the current draw, clamped on to the main wire supplying voltage to the unit".
Where is the main wire supplying current located? Just behind and right of the kick plate where it connects to the wire leading to the household breaker panel? If so, which wire to probe for current?
BTW, I have a probe type meter, not a clamp on style.
Thanks!
JD
  #4 (permalink)
Old 11-24-2013, 11:53 AM
Senior Member
Default
You will need a clamp on style to measure the AC current. Usually the line voltage supply is black.
  #5 (permalink)
Old 11-24-2013, 11:54 AM
Senior Member
Default
Yes, the power connections are behind the metal cover on the RH side, behind the lower access panel. You will need a clamp on style to measure the AC current. Usually the line voltage supply is black.
  #6 (permalink)
Old 11-24-2013, 12:05 PM
Junior Member
Default
Quote:
Mr. Ninja - Thanks much! I have an electrician friend who can probably lend me a clamp on meter. Appreciate your help! - JD
  #7 (permalink)
Old 11-24-2013, 12:14 PM
Senior Member
Default
You are very welcome, have a great Sunday!
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Duet dryer power main control board Hollyjayne Dryer Repair 0 09-18-2012 08:37 AM
no power to main panel tcauto01 Oven Repair (including Ranges and Cooktops) 1 04-16-2012 05:05 AM
Maytag Neptune "Power failure has occurred during current cycle..." barney_g Dryer Repair 0 02-27-2011 06:17 PM
Cross wired main power cord Maximillian Oven Repair (including Ranges and Cooktops) 3 02-22-2010 08:03 AM
main power connection katyanno Refrigerator & Freezer Repair 0 09-24-2009 04:54 PM
