Discuss
Maytag Dishwasher control panel doesn't light up
 in
Dishwasher Repair
I have a Maytag model MDB9600AWQ and it is still working, however, about 6 months ago the front display that
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » Maytag Dishwasher control panel doesn't light up
  #1 (permalink)
Old 11-20-2013, 01:16 PM
Junior Member
ms031317 is on a distinguished road
Default Maytag Dishwasher control panel doesn't light up
Brand: Maytag   Age: 5 - 10 years
I have a Maytag model MDB9600AWQ and it is still working, however, about 6 months ago the front display that shows time remaining and the top control panel that you select the cycle and options went out. It was tempermental at first, it would work sometimes then it would stop. Finally it just went out completely. The start/cancel button still works, so I can at least use the machine. I always used normal cycle, so I'm guessing it works only in that mode. Any suggestions?
  #2 (permalink)
Old 11-20-2013, 01:20 PM
Senior Member
Appliance Ninja is on a distinguished road
Default
The touch panel will need to be replaced and is available at the link below. It is accessed for replacement by removing the screws from around the inner door and separating the panels. It simply unplugs and plugs in to the main control, making replacement pretty easy.
Whirlpool 6-917721 Panel-Con - AppliancePartsPros.com
  #3 (permalink)
Old 11-21-2013, 01:15 AM
Senior Expert
APP Volunteer
denman is a splendid one to behold
Default
Before replacing the panel you may want to try the following.
Connector Cleaning / Checking
Unplug the unit
Open it up
Remove the ribbon cable from the keypad to the control board at the control board.
Clean the edge connector. Use electronics contact cleaner or isopropyl alcohol.
If it is the type where there is not a connector just the insulation is removed, it can be cleaned with a pencil eraser. Do not use an ink eraser as it is too abrasive.
Check the tracks in the ribbon cable for hairline cracks. A magnifying glass helps here.
Would not hurt to clean the connector on the board. Use electronics contact cleaner or isopropyl alcohol and a tooth brush. Be gentle and do not reconnect till all the solvent evaporates.
Reconnect everything and give it a try.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Jenn Air Dishwasher works but control panel will not light up. Atoz123 Dishwasher Repair 0 07-05-2013 11:58 PM
MAYTAG Control Panel will not light or function Update revgaryng Dishwasher Repair 3 06-22-2013 04:02 PM
MAYTAG Control Panel will not light or function revgaryng Dishwasher Repair 0 06-20-2013 10:36 AM
dishwasher control panel buttons not working only get the lock light to work servine73 Dishwasher Repair 0 06-16-2012 01:27 PM
Kitchen Aide Dishwasher has blinking light on control panel. schoolinmom Dishwasher Repair 0 09-21-2011 08:08 AM
