Discuss
whirlpool dw filter clogs, pump pressure
 in
Dishwasher Repair
Recently the wash quality has been poor. Upon examining I discovered that fine food debris is building up inside the
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » whirlpool dw filter clogs, pump pressure
  #1 (permalink)
Old 02-11-2008, 08:10 PM
bomac bomac is offline
Junior Member
bomac is on a distinguished road
Unhappy whirlpool dw filter clogs, pump pressure
Model Number: du943pwkt0   Brand: Whirlpool   Age: 1 - 5 years
Upon examining I discovered that fine food debris is building up inside the hollow doughnut like filter and if I used a household sqeeze trigger sprayer to clean the dishes would come out ok.
As of yesterday the filter cleaning routine no longer helps so observed the cycle with the door open by defeating the door close switch and the tub fills quickely but no water comes out of the upper spray arms and the lower spray arm barely rotates with jets almost too short to hit the dishes.
Should food be getting inside that filter?
There are no holes in it that I can see.
Help!
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 02-12-2008, 08:06 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
Looks like the pump has to be partially disassembled and inspected inside for a blockages and/or damages.
I would recommend to buy the impeller kit before you start it. Most likely you will need it.
Remove the upper dish rack.
Remove the water feeding tube (#24 on the water feed parts break down diagram).
Remove all screws holding the pump outlet (#14 on the pump & motor break down diagram) and remove the pump outlet.
Remove the screw (#12 on the pump & motor break down diagram) holding the wash impeller. Remove the wash impeller.
Remove all screws holding the filter assembly (#9 on the pump & motor break down diagram). Remove the filter assembly.
Check the filter and all parts inside.
- The part number for the impeller kit is AP3115180
Here are the break down diagrams for the Whirlpool dishwasher Model DU943PWKT0
__________________
Professional appliance repair in Los Angeles, California.
  #3 (permalink)
Old 02-13-2008, 09:14 AM
Junior Member
Default
Thanks Gene for the help!
Do I need to get the "pump centering tool" to put in the new impeller and stuff?
  #4 (permalink)
Old 02-14-2008, 01:49 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
It's better to have it.
Sometime missing right tool can screw up a whole job.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Low pressure at spraybars Snearxx Dishwasher Repair 0 12-09-2007 03:26 AM
Whirlpool pump replacement kroznest Dishwasher Repair 4 12-05-2007 09:21 AM
whirlpool water filter housing cathyjp7 Refrigerator & Freezer Repair 0 11-25-2007 01:19 PM
Noise, low pressure, etc romeroom Dishwasher Repair 0 11-19-2007 10:13 PM
gas pressure adjusment tuta68 Oven Repair (including Ranges and Cooktops) 1 08-09-2007 06:50 PM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
