Discuss
Bosch dishwasher not filling
 in
Dishwasher Repair
Hello I have a Bosch dishwasher I am having a problem with. It is not filling with water when I
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » Bosch dishwasher not filling
  #1 (permalink)
Old 11-15-2013, 08:44 AM
Junior Member
kywingnut is on a distinguished road
Default Bosch dishwasher not filling
Model Number: SHU43C07UC/14   Brand: Bosch   Age: More than 10 years
Hello
I have a Bosch dishwasher I am having a problem with. It is not filling with water when I turn it on. I have checked across the 2 terminals with the dishwasher running and I have 0 volts. Each one of these terminals to ground has 120 volts though. I think the 120 volts should be across the terminals though. What does the 120 volts to ground mean?
Any help as to what my next step would be would be greatly appreciated.
Thanks in advance
Mike
Related Models
Bosch SHU43E02 UC/14 (FD 8211-)
Bosch SHU43E05 UC/14 (FD 8211-)
Bosch SHU43E06 UC/14 (FD 8211-)
Bosch SHU43E07 UC/14 (FD 8211-)
Whirlpool SHU45010 Dishwasher
Whirlpool SHU45020 Dishwasher
Whirlpool SHU50041 Dishwasher
Whirlpool SHU50043 Dishwasher
Bosch SHU5302 UC/06 (FD 7705-7912)
Bosch SHU5302 UC/11 (FD 8001-8003)
Bosch SHU5302 UC/12 (FD 8003-)
Bosch SHU5304 UC/06 (FD 7705-7912)
Bosch SHU5304 UC/11 (FD 8001-8003)
Bosch SHU5304 UC/12 (FD 8003-)
Bosch SHU5305 UC/06 (FD 7705-7912)
Bosch SHU5305 UC/11 (FD 8001-8003)
Bosch SHU5305 UC/12 (FD 8003-)
Bosch SHU5306 UC/06 (FD 7705-7912)
Bosch SHU5306 UC/11 (FD 8001-8003)
Bosch SHU5306 UC/12 (FD 8003-)
Bosch SHU5307 UC/12 (FD 8003-)
Bosch SHU5312 UC/06
Bosch SHU5312 UC/11
Bosch SHU5312 UC/12
Bosch SHU5314 UC/06
Bosch SHU5314 UC/11
Bosch SHU5314 UC/12
Bosch SHU5315 UC/06
Bosch SHU5315 UC/06 (FD 7705-7912)
Bosch SHU5315 UC/11
Bosch SHU5315 UC/11 (FD 8001-8003)
Bosch SHU5315 UC/12
Bosch SHU5315 UC/12 (FD 8003-)
Bosch SHU5316 UC/06
Bosch SHU5316 UC/11
Bosch SHU5316 UC/12
Bosch SHU5317 UC/12
Bosch SHU53A02 UC/14 (FD 8211-)
Bosch SHU53A05 UC/14 (FD 8211-)
Bosch SHU53A06 UC/14 (FD 8211-)
Bosch SHU53E02 UC/14 (FD 8211-)
Bosch SHU53E05 UC/14 (FD 8211-)
Bosch SHU53E06 UC/14 (FD 8211-)
Whirlpool SHU55010 Dishwasher
Whirlpool SHU55040 Dishwasher
Whirlpool SHU55042 Dishwasher
Whirlpool SHU60020 Dishwasher
Bosch SHU66C02 UC/14 (FD 8211-)
Bosch SHU66C05 UC/14 (FD 8211-)
Bosch SHU66C06 UC/14 (FD 8211-)
Bosch SHU66C07 UC/14 (FD 8211-)
Bosch SHU66E02 UC/14 (FD 8211-)
Bosch SHU66E05 UC/14 (FD 8211-)
Bosch SHU66E06 UC/14 (FD 8211-)
Bosch SHU66E07 UC/14 (FD 8211-)
Bosch SHU6802 UC/06 (FD 7705-7912)
Bosch SHU6802 UC/11 (FD 8001-8003)
Bosch SHU6802 UC/12 (FD 8003-)
Bosch SHU6805 UC/06 (FD 7705-7912)
Bosch SHU6805 UC/11 (FD 8001-8003)
Bosch SHU6805 UC/12 (FD 8003-)
Bosch SHU6806 UC/06 (FD 7705-7912)
Bosch SHU6806 UC/11 (FD 8001-8003)
Bosch SHU6806 UC/12 (FD 8003-)
Whirlpool SHU70010 Dishwasher
Whirlpool SHU70041 Dishwasher
Whirlpool SHU70050 Dishwasher
Whirlpool SHU70051 Dishwasher
Whirlpool SHU70052 Dishwasher
Whirlpool SHU75010 Dishwasher
Whirlpool SHU75042 Dishwasher
Whirlpool SHU80010 Dishwasher
Whirlpool SHU80041 Dishwasher
Whirlpool SHU80042 Dishwasher
Bosch SHU8802 UC/12 (FD 8105-)
Bosch SHU8805 UC/12 (FD 8105-)
Bosch SHU8806 UC/12 (FD 8105-)
Bosch SHU8812 UC/12 (FD 8105-)
Bosch SHU8815 UC/12 (FD 8105-)
Bosch SHU8816 UC/12 (FD 8105-)
Whirlpool SHU90002 Dishwasher
Whirlpool SHU90041 Dishwasher
Whirlpool SHU90050 Dishwasher
Bosch SHU9902 UC/06
Bosch SHU9902 UC/06 (FD 7905-7912)
Whirlpool SHU99041 Dishwasher
Bosch SHU9905 UC/06
Bosch SHU9905 UC/06 (FD 7905-7912)
Whirlpool SHU99052 Dishwasher
Whirlpool SHU99053 Dishwasher
Bosch SHU9906 UC/06
Bosch SHU9906 UC/06 (FD 7905-7912)
Bosch SHU9912 UC/06
Bosch SHU9912 UC/06 (FD 7908-8002)
Bosch SHU9912 UC/11
Bosch SHU9912 UC/11 (FD 8002-8003)
Bosch SHU9912 UC/12
Bosch SHU9912 UC/12 (FD 8003-)
Bosch SHU9915 UC/06
Bosch SHU9915 UC/06 (FD 7908-8002)
Bosch SHU9915 UC/11
Bosch SHU9915 UC/11 (FD 8002-8003)
Bosch SHU9915 UC/12
Bosch SHU9915 UC/12 (FD 8003-)
Bosch SHU9916 UC/06
Bosch SHU9916 UC/06 (FD 7908-8002)
Bosch SHU9916 UC/11
Bosch SHU9916 UC/11 (FD 8002-8003)
Bosch SHU9916 UC/12
Bosch SHU9916 UC/12 (FD 8003-)
Bosch SHU9922 UC/12 (FD 8003-)
Bosch SHU9925 UC/12 (FD 8003-)
Bosch SHU9926 UC/12 (FD 8003-)
Bosch SHU9952 UC/12 (FD 8105 -)
Bosch SHU9955 UC/12 (FD 8105 -)
Bosch SHU9956 UC/12 (FD 8105 -)
Bosch SHV4303 UC/06
Bosch SHV4303 UC/06 (FD 7712-8002)
Bosch SHV4303 UC/11
Bosch SHV4303 UC/11 (FD 8002-8003)
  #2 (permalink)
Old 11-15-2013, 08:56 AM
Senior Member
Appliance Ninja is on a distinguished road
Default
You don't say specifically, but I suspect you are testing across the terminals to the inlet valve. If so, the control is calling for water (because the 120 VAC to ground is present), so that means that you are losing the neutral somewhere. I suspect one of the switches on the water fill assembly has issues. The picture below will help identify the switches you will need to test. That assembly is mounted on the LH side of the tub.
  #3 (permalink)
Old 11-15-2013, 09:52 AM
Junior Member
Default
Thanks very much for your quick reply. Yes, I checked between the terminals on the water inlet valve first and found the 120 volts to ground.
I will check the float switch next. Thanks for the post with the link to the switches.
  #4 (permalink)
Old 11-15-2013, 09:56 AM
Senior Member
Default
You bet, let me know what you find!
  #5 (permalink)
Old 11-15-2013, 01:11 PM
Junior Member
Default
Ninja
Well, I checked the float switch, manually it moves up and down okay. I took the leads off and checked continuity, that seemed okay also.
I plugged the connector in and turned on the dishwasher.
The top of the connector had a red and white wire, the middle connector had a single gray wire, and the bottom had a single white wire.
With the dishwasher on and the connector plugged in, I checked voltage where the wires went in.
I had 120 volts between the red/white and single gray. Also had 120 volts between the single gray and single white wire. (top prong/middle prong & bottom prong/middle prong)
0 volts between the top red/white and bottom single white wire.
120 volts from top red/white to ground and 120 volts between bottom single wire and ground.
Not sure where to go from here.
Thanks again
  #6 (permalink)
Old 11-15-2013, 01:20 PM
Senior Member
Default
The page below will help you test from the control. There are several things involved with that fill. I figured it would be something common, but looks like not. Let me know what you find with the tests below.
  #7 (permalink)
Old 11-15-2013, 01:37 PM
Junior Member
Default
Thanks Ninja. I will troubleshoot that next and let you know.
  #8 (permalink)
Old 11-15-2013, 02:24 PM
Senior Member
Default
You are very welcome, keep me posted!
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Bosch Dishwasher not filling with water RSC007 Dishwasher Repair 1 03-29-2011 06:35 AM
Bosch dishwasher not filling - please help mjl0733 Dishwasher Repair 0 03-29-2011 05:12 AM
Bosch dishwasher not filling with water rritter Dishwasher Repair 3 01-17-2008 08:10 PM
