Discuss
Maytag Netptune washer 5500B
 in
Dishwasher Repair
I can hear the motor running but the drum doesn't move. The washer lets water in and out, but
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » Maytag Netptune washer 5500B
  #1 (permalink)
Old 02-11-2008, 07:19 PM
abe@oztechsystems.com abe@oztechsystems.com is offline
Junior Member
abe@oztechsystems.com is on a distinguished road
Default Maytag Netptune washer 5500B
Model Number: MAH 5500B WW   Brand: Maytag   Age: 1 - 5 years
I can hear the motor running but the drum doesn't move. The washer lets water in and out, but the drum is not moving. I can hear during the spin cycle high pitch spinning of the motor, but drum doesn't move. Any ideas?
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 02-12-2008, 07:07 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
Remove the access panel (#13 on the rear cabinet break down diagram) and check the belt.
If the belt is broken - replace it.
If the belt fall off but it's not broken, open the door and check if the drum is moving up and down.
If it does then most likely the rear bearing is worn out and has to be replaced.
The rear bearing comes as a part of the outer tub assembly.
- The part number for the belt is AP204967
- The part number for the outer tub assembly is AP3841622
Here are the break down diagrams for the Maytag Neptune washer Model MAH5500BWW
__________________
Professional appliance repair in Los Angeles, California.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
maytag washer catwood Washer Repair 1 01-12-2008 02:38 AM
maytag washer dajczak Washer Repair 0 11-20-2007 09:40 AM
maytag washer roquescraig Washer Repair 0 11-13-2007 06:32 AM
Maytag Washer CHFCOOK Washer Repair 5 10-15-2007 12:49 AM
Maytag washer washme Washer Repair 2 09-25-2007 06:51 PM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
