2 Pages12>
pilot1
#1 Posted : Wednesday, November 13, 2013 8:47:20 AM(UTC)
pilot1
One of the pins from the control board connector (5 wire) is broken off and stuck in the connector. Is there a way to change out the connector or is a whole new wire harness required?
JK
Appliance Ninja
#2 Posted : Wednesday, November 13, 2013 9:56:39 AM(UTC)
Appliance Ninja
Is the broken connector part of the harness or part of the control board? Is the connector labeled on the board, like CON1 or CON2, P2, etc?
pilot1
#3 Posted : Wednesday, November 13, 2013 10:38:36 AM(UTC)
pilot1
The broken pin is from the control panel but broke off in the connector socket. I have a new control panel but need to get the broken pin out of the connector/and or replace wire end in connector.
JK
Appliance Ninja
#4 Posted : Wednesday, November 13, 2013 10:45:09 AM(UTC)
Appliance Ninja
Okay, so you should be able to use a needle nose plier to grab the spade terminal that is stuck in the female connector and simply pull it out.
pilot1
#5 Posted : Wednesday, November 13, 2013 10:46:35 AM(UTC)
pilot1
It is the P 2 connector on the board.
JK
pilot1
#6 Posted : Wednesday, November 13, 2013 10:48:21 AM(UTC)
pilot1
Thanks. I'll try that approach. If the female connector is damaged can it be replaced?
pilot1
#7 Posted : Wednesday, November 13, 2013 10:52:37 AM(UTC)
pilot1
Also, if I were to replace the connector, where can I find a replacement? I don't see the P2 connector listed as a part for this machine.
JK
Appliance Ninja
#8 Posted : Wednesday, November 13, 2013 11:05:49 AM(UTC)
Appliance Ninja
The connector by itself is not available, you would need to replace the harness. Is it one of the small pin connectors or one of the larger 1/4" spade connectors?
pilot1
#9 Posted : Wednesday, November 13, 2013 11:12:30 AM(UTC)
pilot1
It is one of the small pin connectors
Appliance Ninja
#10 Posted : Wednesday, November 13, 2013 11:23:52 AM(UTC)
Appliance Ninja
Okay, if you cannot get the old pin out, the harness will indeed need to be replaced.
2 Pages12>
