2 Pages12>
Repair Rookie
#1 Posted : Tuesday, November 12, 2013 10:27:15 AM(UTC)
Repair Rookie
Hello,
My dishwasher will fill with water and will also drain.
It heats the water but does not clean the dishes.
The spray arms appear to be clear and I have searched in vain for
any blockages.
The motor will turn when I spin the the blades from behind with a stick.
So it does not appear to be locked up.
What could the problem be?
Appliance Ninja
#2 Posted : Tuesday, November 12, 2013 10:32:46 AM(UTC)
Appliance Ninja
Can you hear the motor humming or buzzing after it fills with water? Do you have a meter to test for voltage with?
Repair Rookie
#3 Posted : Wednesday, November 13, 2013 5:56:38 AM(UTC)
Repair Rookie
Appliance Ninja, thanks for your interest.
Yes, the motor hums and the blades on the back of the motor are turning.
I just got a multimeter but dont know how to take the reading or what is considered a good reading
Appliance Ninja
#4 Posted : Wednesday, November 13, 2013 6:36:05 AM(UTC)
Appliance Ninja
If the blades are turning, the motor is working. So, that means that the issue is with the recirculation of the water. Number 508 filter is likely plugged. It is under the number 506 cover. Can you have a look at that filter and see if it is indeed plugged?
Appliance Ninja attached the following image(s):
Repair Rookie
#5 Posted : Wednesday, November 13, 2013 7:39:17 AM(UTC)
Repair Rookie
Thanks Ninja!
I will check that filter when I get home this afternoon.
Appliance Ninja
#6 Posted : Wednesday, November 13, 2013 7:58:11 AM(UTC)
Appliance Ninja
Sounds good, keep me posted!
Repair Rookie
#7 Posted : Wednesday, November 13, 2013 2:47:10 PM(UTC)
Repair Rookie
I took the filter out this afternoon, it had a little debris but was definitely not clogged. Also I ran my hand down into the hole where the filter was but could not find any blockage.
Appliance Ninja
#8 Posted : Wednesday, November 13, 2013 2:52:53 PM(UTC)
Appliance Ninja
Okay, so if that filter is clean, the motor is running and there is adequate water in the tub, the recirculation impeller will likely need to be replaced. The kit comes with installation instructions and is available below.
http://www.appliancepartspros.c...d19x10038-ap3883871.html
Repair Rookie
#9 Posted : Thursday, November 14, 2013 6:16:26 AM(UTC)
Repair Rookie
Ok, I bought the impeller kit, will post results after installation.
Appliance Ninja
#10 Posted : Thursday, November 14, 2013 6:43:42 AM(UTC)
Appliance Ninja
2 Pages12>
