Appliance Repair Forum
-   Dishwasher Repair (http://forum.appliancepartspros.com/dishwasher-repair/)
-   -   High Limit Thermostat wire burned (http://forum.appliancepartspros.com/dishwasher-repair/538783-high-limit-thermostat-wire-burned.html)
rosskell 11-09-2013 08:49 AM
1 Attachment(s)
My dishwasher stopped heating. When I looked underneath the wire connected to the high limit thermostat was burned. Checked continuity on the heating element and the thermostat and both were good. Things don't generally burn for no reason. Where should I look next if both the heating element and thermostat look ok?
rosskell 11-21-2013 08:10 PM
fixed it
I ended up replacing the High limit thermostat and for now the dishes dry.
Appliance Ninja 11-21-2013 08:25 PM
I would replace both of the thermostat wire connectors. Typically, loose or poor connections cause that burning you have there.
