Discuss
Whirlpool Quiet Partner V leaking from diverter motor
 in
Dishwasher Repair
I have a 3 year old Whirlpool Gold Quiet Parnter V dishwasher, model GU3600XTVY2, that is leaking at the diverter
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » Whirlpool Quiet Partner V leaking from diverter motor
  #1 (permalink)
Old 11-06-2013, 06:20 AM
Junior Member
hoppster is on a distinguished road
Default Whirlpool Quiet Partner V leaking from diverter motor
Model Number: GU3600XTVY2   Brand: Whirlpool   Age: 1 - 5 years
I have a 3 year old Whirlpool Gold Quiet Parnter V dishwasher, model GU3600XTVY2, that is leaking at the diverter motor (W10056349). Do I need to replace the sump at the same time I replace the diverter motor? I'm not seeing any leak from the large sump seal, so I'm wondering if I can just replace the diverter motor by itself.
Related Models
Whirlpool GU3600XTVY2 UNDERCOUNTER DISHWASHER
Whirlpool GU3600XTVY3 UNDERCOUNTER DISHWASHER
Whirlpool GU3600XTVY4 UNDERCOUNTER DISHWASHER
Whirlpool GU630XTLQ0 UNDERCOUNTER DISHWASHER
Whirlpool GU630XTLQ1 UNDERCOUNTER DISHWASHER
Whirlpool GU640XTLQ0 UNDERCOUNTER DISHWASHER
Whirlpool GU640XTLQ1 UNDERCOUNTER DISHWASHER
Whirlpool GU940SCGB0 UNDERCOUNTER DISHWASHER
Whirlpool GU940SCGB1 UNDERCOUNTER DISHWASHER
Whirlpool GU940SCGB2 UNDERCOUNTER DISHWASHER
Whirlpool GU940SCGB3 DISHWASHER
Whirlpool GU940SCGQ0 UNDERCOUNTER DISHWASHER
Whirlpool GU940SCGQ1 UNDERCOUNTER DISHWASHER
Whirlpool GU940SCGQ2 UNDERCOUNTER DISHWASHER
Whirlpool GU940SCGQ3 DISHWASHER
Whirlpool GU940SCGT3 DISHWASHER
Whirlpool GU940SCGZ0 UNDERCOUNTER DISHWASHER
Whirlpool GU940SCGZ1 UNDERCOUNTER DISHWASHER
Whirlpool GU940SCGZ2 UNDERCOUNTER DISHWASHER
Whirlpool GU940SCGZ3 DISHWASHER
Whirlpool GU960SCGB0 DISHWASHER
Whirlpool GU960SCGQ0 DISHWASHER
Whirlpool GU980QPDB0 UNDERCOUNTER DISHWASHER
Whirlpool GU980QPDQ0 UNDERCOUNTER DISHWASHER
Whirlpool GU980QPDZ0 UNDERCOUNTER DISHWASHER
Whirlpool GU980SCGB0 UNDERCOUNTER DISHWASHER
Whirlpool GU980SCGB1 UNDERCOUNTER DISHWASHER
Whirlpool GU980SCGB2 UNDERCOUNTER DISHWASHER
Whirlpool GU980SCGB3 DISHWASHER
Whirlpool GU980SCGQ0 UNDERCOUNTER DISHWASHER
Whirlpool GU980SCGQ1 UNDERCOUNTER DISHWASHER
Whirlpool GU980SCGQ2 UNDERCOUNTER DISHWASHER
Whirlpool GU980SCGQ3 DISHWASHER
Whirlpool GU980SCGS1 UNDERCOUNTER DISHWASHER
Whirlpool GU980SCGS2 UNDERCOUNTER DISHWASHER
Whirlpool GU980SCGS3 DISHWASHER
Whirlpool GU980SCGT2 DISHWASHER
Whirlpool GU980SCGT3 DISHWASHER
Whirlpool GU980SCGZ0 UNDERCOUNTER DISHWASHER
Whirlpool GU980SCGZ1 UNDERCOUNTER DISHWASHER
Whirlpool GU980SCGZ2 UNDERCOUNTER DISHWASHER
Maytag GV1110PRW RANGE- F/S STD GAS
Admiral GV1226NXEW FREEZER- VERTICAL
Admiral GV1726NXEW FREEZER- VERTICAL
Hoover GV3177WUA RANGE- F/S STD GAS
Hoover GV3177WUW RANGE- F/S STD GAS
Hoover GV3177WUW5 RANGE- F/S STD GAS
Maytag GV3277XUA RANGE- F/S STD GAS
Maytag GV3277XUW RANGE- F/S STD GAS
Hoover GV3531WUA RANGE- F/S STD ELE
Hoover GV3531WUW RANGE- F/S STD ELE
General Electric GVSR1060H7WW WASHER
General Electric GVSR1060H9WW WASHER
General Electric GVSR1080H8WW WASHER
Whirlpool GVW9959KL0 WASHER
Whirlpool GVW9959KL1 WASHER - DIRECT DRIVE
Whirlpool GVW9959KL2 WASHER - DIRECT DRIVE
Whirlpool GVW9959KL3 AUTOMATIC WASHER
Whirlpool GVW9959KQ0 WASHER
Whirlpool GVW9959KQ1 WASHER - DIRECT DRIVE
Whirlpool GVW9959KQ2 WASHER - DIRECT DRIVE
Whirlpool GVW9959KQ3 AUTOMATIC WASHER
Whirlpool GVW9959KT0 WASHER
Whirlpool GVW9959KT1 WASHER - DIRECT DRIVE
Whirlpool GVW9959KT2 WASHER - DIRECT DRIVE
Whirlpool GVW9959KT3 AUTOMATIC WASHER
Maytag GW18F1A WASHER-TOP LOADING
Maytag GW18F1H WASHER-TOP LOADING
Maytag GW18F1W WASHER-TOP LOADING
Maytag GW18F2A WASHER-TOP LOADING
Maytag GW18F2H WASHER-TOP LOADING
Maytag GW18F2W WASHER-TOP LOADING
Maytag GW18G1A WASHER-TOP LOADING
Maytag GW18G1HW WASHER-TOP LOADING
Maytag GW18G1WW WASHER-TOP LOADING
Maytag GW20F6A WASHER-TOP LOADING
Maytag GW20F6H WASHER-TOP LOADING
Maytag GW20F6W WASHER-TOP LOADING
Frigidaire GW30SPEA2 Wwh(v1) / Electric Range
Frigidaire GW30SPED1 Wwh(v2) / Electric Range
Frigidaire GW30SPEW1 Wwh(v1) / Electric Range
Frigidaire GW30SPEW2 Wwh(v2) / Electric Range
Whirlpool GW395LEGB0 GAS RANGE
Whirlpool GW395LEGB1 GAS RANGE
Whirlpool GW395LEGB2 GAS RANGE
Whirlpool GW395LEGB3 GAS RANGE
Whirlpool GW395LEGB4 GAS RANGE
Whirlpool GW395LEGB5 GAS RANGE
Whirlpool GW395LEGB6 GAS RANGE
Whirlpool GW395LEGQ0 GAS RANGE
Whirlpool GW395LEGQ1 GAS RANGE
Whirlpool GW395LEGQ2 GAS RANGE
Whirlpool GW395LEGQ3 GAS RANGE
Whirlpool GW395LEGQ4 GAS RANGE
Whirlpool GW395LEGQ5 GAS RANGE
Whirlpool GW395LEGQ6 GAS RANGE
Whirlpool GW395LEGT2 GAS RANGE
Whirlpool GW395LEGT3 GAS RANGE
Whirlpool GW395LEGT4 GAS RANGE
Whirlpool GW395LEGT5 GAS RANGE
Whirlpool GW395LEGT6 GAS RANGE
Whirlpool GW395LEGZ0 GAS RANGE
Whirlpool GW395LEGZ1 GAS RANGE
Whirlpool GW395LEGZ2 GAS RANGE
Whirlpool GW395LEGZ3 GAS RANGE
Whirlpool GW395LEPB00 30" Slide-In GAS OVEN NON-CONV
Whirlpool GW395LEPB01 30" Slide-In GAS OVEN NON-CONV
Whirlpool GW395LEPB02 30" Slide-In GAS OVEN NON-CONV
Whirlpool GW395LEPB03 30" Slide-In GAS OVEN NON-CONV
Whirlpool GW395LEPB04 30" Slide-In GAS OVEN NON-CONV
Whirlpool GW395LEPB05 30" Slide-In GAS OVEN NON-CONV
Whirlpool GW395LEPQ00 30" Slide-In GAS OVEN NON-CONV
Whirlpool GW395LEPQ01 30" Slide-In GAS OVEN NON-CONV
Whirlpool GW395LEPQ02 30" Slide-In GAS OVEN NON-CONV
Whirlpool GW395LEPQ03 30" Slide-In GAS OVEN NON-CONV
Whirlpool GW395LEPQ04 30" Slide-In GAS OVEN NON-CONV
Whirlpool GW395LEPQ05 30" Slide-In GAS OVEN NON-CONV
Whirlpool GW395LEPS00 30" Slide-In GAS OVEN NON-CONV
Whirlpool GW395LEPS01 30" Slide-In GAS OVEN NON-CONV
Whirlpool GW395LEPS02 30" Slide-In GAS OVEN NON-CONV
  #2 (permalink)
Old 11-15-2013, 07:45 PM
Junior Member
Default
Quote:
Page 2: I did more research and found that the only reason I would need to get the sump would be to get the shaft seal for the dvtr motor. A rather expensive option if all you need is the seal because you can't purchase the shaft seal separately. So, I decided to remove the dvtr motor and pull the shaft seal. After a bit of cleaning, I reassembled the seal and motor but this time positioning the seal with the groove side towards the motor as it seems to fit onto the shaft shoulder better (this is opposite of how the seal was originally installed). I've run the dishwasher several times now and have yet to see a leak.
My question now is, what is the proper orientation of the pump shaft seal? groove side up towards the sump, or down towards the divertor motor?
  #3 (permalink)
Old 11-16-2013, 12:05 PM
Senior Member
Appliance Ninja is on a distinguished road
Default
I have never really paid attention to the way the seal goes in, but the picture at the link below looks like the grooved side goes toward the motor. I blew the image size to 400% and it shows pretty good.
Whirlpool W10168822 Sump Housing - AppliancePartsPros.com
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Leaking Dishwasher (diverter motor) rmsmith Dishwasher Repair 53 07-23-2017 02:51 AM
Kitchen Aid leaking from diverter motor mherm5001 Dishwasher Repair 1 10-06-2013 09:12 AM
Whirlpool Quiet Partner II drain motor stays on Nsgibson Dishwasher Repair 5 01-17-2013 09:04 AM
Whirlpool Quiet Partner III is leaking at bottom & top of door TLeonard Dishwasher Repair 0 12-08-2010 06:26 AM
Whirlpool Quiet Partner I motor noise Val D. Dishwasher Repair 0 06-14-2010 09:03 PM
