Discuss
Pump replaced, after that motor would not turn off
 in
Dishwasher Repair
Our Kenmore Elite DW started leaking water. The repairman came out and replaced the pump. That night I started a
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » Pump replaced, after that motor would not turn off
  #1 (permalink)
Old 11-05-2013, 07:47 AM
Junior Member
MJW726 is on a distinguished road
Default Pump replaced, after that motor would not turn off
Model Number: 630.17303400   Brand: Kenmore   Age: 5 - 10 years
Our Kenmore Elite DW started leaking water. The repairman came out and replaced the pump. That night I started a load of dishes. The next morning the DW was still running. The motor was constantly running and there was a smell of heat or something getting hot. He came back and said it was the sensor and he dried the pan ( I think what he said). He left with the DW running. Again, the motor wouldn't turn off and this time there is a little water leaking. He came back and said the heater motor needs replaced now. He said it is getting too hot and causing the casing or ring to leak water, or something like that. The motor was not running like this prior to the pump being replaced. I'm not sure if I should trust this guy or if he accidentally did something that caused the heater to malfunction. Do these two problems typically go together? Pump and heater motor needing replaced?
Related Models
Frigidaire 6307B WASHER
Frigidaire 6308A WASHER
Frigidaire 6309A WASHER
Amana 631.000 RANGE- S/C S/I DDRAFT GAS
Amana 631.001 RANGE- S/C S/I DDRAFT GAS
Amana 631.002 RANGE- S/C S/I DDRAFT GAS
Amana 631.003 RANGE- S/C S/I DDRAFT GAS
Amana 631.004 RANGE- S/C S/I DDRAFT GAS
Amana 631.006 RANGE- S/C S/I DDRAFT GAS
Amana 632-3J ROOM AIR CONDITIONER
Frigidaire 6337B WASHER
Frigidaire 6338A WASHER
Frigidaire 6339A WASHER
Hoover 634
Frigidaire 6347B WASHER
Frigidaire 6348A WASHER
Frigidaire 6358A WASHER
Frigidaire 6389-80A WASHER
Frigidaire 6389-80B WASHER
Frigidaire 6389-87A WASHER
Frigidaire 6389-87B WASHER
Hoover 64
Maytag 640C DRYER- GAS
Maytag 640W DRYER- GAS
Magic Chef 6458XRA RANGE- S/C S/I GAS
Magic Chef 6458XRS RANGE- S/C S/I GAS
Magic Chef 6458XRW RANGE- S/C S/I GAS
Magic Chef 6458XTA RANGE- S/C S/I GAS
Magic Chef 6458XTS RANGE- S/C S/I GAS
Magic Chef 6458XTW RANGE- S/C S/I GAS
Kenmore 6476037210 KENMORE 30 IN GAS RANGE
Kenmore 6476037220 KENMORE 30 IN GAS RANGE
Kenmore 6476037240 KENMORE 30 IN GAS RANGE
Kenmore 6476037260 KENMORE 30 IN GAS RANGE
Kenmore 6476037310 KENMORE 30 IN GAS RANGE
Kenmore 6476037311 KENMORE 30 INCH GAS RANGE
Kenmore 6476037312 KENMORE 30 IN GAS RANGE
Kenmore 6476037313 KENMORE 30 INCH GAS RANGE
Kenmore 6476037320 KENMORE 30 IN GAS RANGE
Kenmore 6476037321 KENMORE 30 INCH GAS RANGE
Kenmore 6476037322 KENMORE 30 IN GAS RANGE
Kenmore 6476037323 KENMORE 30 INCH GAS RANGE
Kenmore 6476037340 KENMORE 30 IN GAS RANGE
Kenmore 6476037341 KENMORE 30 INCH GAS RANGE
Kenmore 6476037342 KENMORE 30 IN GAS RANGE
Kenmore 6476037343 KENMORE 30 INCH GAS RANGE
Kenmore 6476037360 KENMORE 30 IN GAS RANGE
Kenmore 6476037361 KENMORE 30 INCH GAS RANGE
Kenmore 6476037362 KENMORE 30 IN GAS RANGE
Kenmore 6476037363 KENMORE 30 INCH GAS RANGE
Kenmore 6476037510 KENMORE 30 INCH GAS RANGE
Kenmore 6476037520 KENMORE 30 INCH GAS RANGE
Kenmore 6476037540 KENMORE 30 INCH GAS RANGE
Kenmore 6476037560 KENMORE 30 INCH GAS RANGE
Kenmore 6476047510 KENMORE 30 INCH GAS RANGE
Kenmore 6476047520 KENMORE 30 INCH GAS RANGE
Kenmore 6476047540 KENMORE 30 INCH GAS RANGE
Kenmore 6476047560 KENMORE 30 INCH GAS RANGE
Kenmore 6476057210 KENMORE 30 IN GAS RANGE
Kenmore 6476057220 KENMORE 30 IN GAS RANGE
Kenmore 6476057240 KENMORE 30 IN GAS RANGE
Kenmore 6476057260 KENMORE 30 IN GAS RANGE
Kenmore 6476057310 KENMORE GAS RANGE
Kenmore 6476057311 KENMORE 30 IN GAS RANGE
Kenmore 6476057312 KENMORE 30 INCH GAS RANGE
Kenmore 6476057313 KENMORE 30 INCH GAS RANGE
Kenmore 6476057320 KENMORE GAS RANGE
Kenmore 6476057321 KENMORE 30 IN GAS RANGE
Kenmore 6476057322 KENMORE 30 INCH GAS RANGE
Kenmore 6476057323 KENMORE 30 INCH GAS RANGE
Kenmore 6476057340 KENMORE GAS RANGE
Kenmore 6476057341 KENMORE 30 IN GAS RANGE
Kenmore 6476057342 KENMORE 30 INCH GAS RANGE
Kenmore 6476057343 KENMORE 30 INCH GAS RANGE
Kenmore 6476057360 KENMORE GAS RANGE
Kenmore 6476057361 KENMORE 30 IN GAS RANGE
Kenmore 6476057362 KENMORE 30 INCH GAS RANGE
Kenmore 6476057363 KENMORE 30 INCH GAS RANGE
Kenmore 6476057510 KENMORE 30 INCH GAS RANGE
Kenmore 6476057520 KENMORE 30 INCH GAS RANGE
Kenmore 6476057540 KENMORE 30 INCH GAS RANGE
Kenmore 6476057560 KENMORE 30 INCH GAS RANGE
Kenmore 6476137210 KENMORE 30 IN GAS RANGE
Kenmore 6476137220 KENMORE 30 IN GAS RANGE
Kenmore 6476137240 KENMORE 30 IN GAS RANGE
Kenmore 6476137260 KENMORE 30 IN GAS RANGE
Kenmore 6476137310 KENMORE 30 IN GAS RANGE
Kenmore 6476137311 KENMORE 30 INCH GAS RANGE
Kenmore 6476137312 KENMORE 30 IN GAS RANGE
Kenmore 6476137313 KENMORE 30 INCH GAS RANGE
Kenmore 6476137320 KENMORE 30 IN GAS RANGE
Kenmore 6476137321 KENMORE 30 INCH GAS RANGE
Kenmore 6476137322 KENMORE 30 IN GAS RANGE
Kenmore 6476137323 KENMORE 30 INCH GAS RANGE
Kenmore 6476137340 KENMORE 30 IN GAS RANGE
Kenmore 6476137341 KENMORE 30 INCH GAS RANGE
Kenmore 6476137342 KENMORE 30 IN GAS RANGE
Kenmore 6476137343 KENMORE 30 INCH GAS RANGE
Kenmore 6476137360 KENMORE 30 IN GAS RANGE
Kenmore 6476137361 KENMORE 30 INCH GAS RANGE
Kenmore 6476137362 KENMORE 30 IN GAS RANGE
Kenmore 6476137363 KENMORE 30 INCH GAS RANGE
Kenmore 6476157210 KENMORE 30 IN GAS RANGE
Kenmore 6476157220 KENMORE 30 IN GAS RANGE
Kenmore 6476157240 KENMORE 30 IN GAS RANGE
Kenmore 6476157260 KENMORE 30 IN GAS RANGE
Kenmore 6476157310 KENMORE GAS RANGE
Kenmore 6476157311 KENMORE 30 IN GAS RANGE
Kenmore 6476157312 KENMORE 30 INCH GAS RANGE
Kenmore 6476157313 KENMORE 30 INCH GAS RANGE
Kenmore 6476157320 KENMORE GAS RANGE
Kenmore 6476157321 KENMORE 30 IN GAS RANGE
Kenmore 6476157322 KENMORE 30 INCH GAS RANGE
Kenmore 6476157323 KENMORE 30 INCH GAS RANGE
Kenmore 6476157340 KENMORE GAS RANGE
Kenmore 6476157341 KENMORE 30 IN GAS RANGE
Kenmore 6476157342 KENMORE 30 INCH GAS RANGE
Kenmore 6476157343 KENMORE 30 INCH GAS RANGE
Kenmore 6476157360 KENMORE GAS RANGE
  #2 (permalink)
Old 11-05-2013, 05:53 PM
Senior Member
HumboldtRepairMan is on a distinguished road
Default
Your repairman botched the job or put in bad parts to begin with or misdiagnosed it........he should of never left your house with your unit running hot and not shutting off without disabling it. Call the owner of this place or another company.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Haier mini fridge doesn't turn on (replaced motor protector) LeftyAce Refrigerator & Freezer Repair 4 09-06-2012 07:00 PM
Error Message , motor not rotating , I replaced motor with clutch with a new one Danson73 Washer Repair 1 08-31-2011 06:21 PM
replaced motor & pump still doesn't wash russtodd Dishwasher Repair 4 04-17-2009 12:23 PM
Bosch washer pump issue (already replaced pump!) wdt Washer Repair 0 12-02-2008 06:26 AM
Replaced pump now motor wont go jzawacki Washer Repair 5 08-15-2008 07:13 PM
