Discuss
Bosch dishwasher runs for hours
 in
Dishwasher Repair
My Bosch dishwasher runs for hours. I don't know how long it would actually run if I didn't stop it.
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » Bosch dishwasher runs for hours
  #1 (permalink)
Old 11-04-2013, 05:50 PM
Junior Member
Sdillion is on a distinguished road
Default Bosch dishwasher runs for hours
Model Number: SHX33A05UC/22   Brand: Bosch   Age: 5 - 10 years
My Bosch dishwasher runs for hours. I don't know how long it would actually run if I didn't stop it. Prior to this it wasn't completely drying the dishes. I researched and found that it could be the heater assembly (part number 480317) I replaced this part and it still does the same thing. I am not sure what to do next. Any help would be greatly appreciated.
Related Models
Bosch SHX33A06 UC/14 (FD 8211-)
Bosch SHX43E02 UC/14 (FD 8211-)
Bosch SHX43E05 UC/14 (FD 8211-)
Bosch SHX43E06 UC/14 (FD 8211-)
Bosch SHX46A02 UC/14 (FD 8211-)
Bosch SHX46A05 UC/14 (FD 8211-)
Bosch SHX46A06 UC/14 (FD 8211-)
Bosch SHX46A07 UC/14 (FD 8211-)
Bosch SHX46B02 UC/14 (FD 8211-)
Bosch SHX46B05 UC/14 (FD 8211-)
Bosch SHX46B06 UC/14 (FD 8211-)
Bosch SHX46B07 UC/14 (FD 8211-)
Bosch SHX56B02 UC/14 (FD 8211-)
Bosch SHX56B05 UC/14 (FD 8211-)
Bosch SHX56B06 UC/14 (FD 8211-)
Bosch SHX99B05 UC/14 (FD 8212-)
Bosch SHX99B06 UC/14 (FD 8212-)
Bosch SHY56A02 UC/14 (FD8301-)
Bosch SHY56A05 UC/14 (FD8301-)
Bosch SHY56A06 UC/14 (FD8301-)
Bosch SHY66C02 UC/14 (FD8301-)
Bosch SHY66C05 UC/14 (FD8301-)
Bosch SHY66C06 UC/14 (FD8301-)
Bosch SHY99A02 UC/14 (FD 8212-)
Bosch SHY99A05 UC/14 (FD 8212-)
Bosch SHY99A06 UC/14 (FD 8212-)
Amana SI19E REF - SXS/I&W
General Electric SIG140060B SIGNATURE REFRIGERATOR
General Electric SIG1480A66WH DISHWASHER
General Electric SIG1482A68BA DISHWASHER
General Electric SIG60100T0WG SIGNATURE WASHER
General Electric SIG7010ET0WG SIGNATURE ELECTRIC DRYER
General Electric SIG7010ET1WG Electric dryer
Admiral SILVER22 REF - SXS/I&W
Admiral SILVER24 REF - SXS/I&W
Maytag SK525-2W REF - SXS
Maytag SK535-2 REF - SXS/I&W
Gaggenau SK590-2 REF - BOTTOM MOUNTS
Hardwick SKG4622MGA639R RANGE-F/S CONT CLEAN GAS
Hardwick SKG4622MGW639R RANGE-F/S CONT CLEAN GAS
Hardwick SKG9611A540R RANGE-F/S CONT CLEAN GAS
Hardwick SKG9611W540R RANGE-F/S CONT CLEAN GAS
Amana SKI22F REF - SXS/I&W
Amana SKI22F-A REF - SXS/I&W
Amana SKI22F-C REF - SXS/I&W
Amana SKI22F-G REF - SXS/I&W
Amana SKI22FL REF - SXS/I&W
Hardwick SKJ7141819DE WALLOVEN- CONT CLEAN GAS
Maytag SL10AN-A01 STACKED LAUNDRY- ELE
Maytag SL10AN-A02 STACKED LAUNDRY- ELE
Maytag SL10AN-A03 STACKED LAUNDRY- ELE
Maytag SL11AA STACKED LAUNDRY- ELE
Maytag SL11AN STACKED LAUNDRY- ELE
General Electric SL208 Room air conditioner
General Electric SL210 Room air conditioner
General Electric SL212 Room air conditioner
General Electric SL214 Room air conditioner
General Electric SL217 Room air conditioner
General Electric SL220 Room air conditioner
General Electric SL223 Room air conditioner
Amana SL22F REF - SXS/I&W
Amana SL22F-A REF - SXS/I&W
Amana SL22F-C REF - SXS/I&W
Amana SL22F-G REF - SXS/I&W
Amana SL22F-L REF - SXS/I&W
Amana SL22G REF - SXS/I&W
Amana SL22GL REF - SXS/I&W
Amana SL22JB REF - SXS/I&W
Amana SL22JB Ref - SXS/I&W
Amana SL22MBG REF - SXS/I&W
Amana SL22MBL REF - SXS/I&W
Amana SL22MBW REF - SXS/I&W
Amana SL25G REF - SXS/I&W
Amana SL25GL REF - SXS/I&W
Amana SL25H REF - SXS/I&W
Amana SL25J REF - SXS/I&W
Amana SL25J Ref - SXS/I&W
Amana SL25M2L REF - SXS/I&W
Amana SL25M2W REF - SXS/I&W
Amana SL25MG REF - SXS/I&W
Amana SL25ML REF - SXS/I&W
Amana SL25MW REF - SXS/I&W
Amana SLD22JB REF - SXS/I&W
Amana SLD22MB2L REF - SXS/I&W
Amana SLD22MB2W REF - SXS/I&W
Amana SLD22MBG REF - SXS/I&W
Amana SLD22MBL REF - SXS/I&W
Amana SLD22MBW REF - SXS/I&W
Amana SLD25J REF - SXS/I&W
Amana SLD25JB REF - SXS/I&W
Amana SLD25JP REF - SXS/I&W
  #2 (permalink)
Old 11-04-2013, 06:34 PM
Senior Member
HumboldtRepairMan is on a distinguished road
Default
First off because of congress pushing the so called "energy efficiency" appliances onto the market dishwashers can run for 3+ hours to complete cycle i've even called manufactures and they say it's perfectly normal. Try the quick wash or 1 hour cycles for shorter cycles. Does your unit stop at some point in time? And exactly how long does it cycles? Try different cycles see if you get the same results.
  #3 (permalink)
Old 11-05-2013, 02:07 PM
Junior Member
Default
Thanks for the information. This is a new pattern for the dishwasher, it has not always done this. I have never let it run until it quit, the longest it has ran has been 4 hours and I stopped it. It still had soap in it and the water was only lukewarm, I just had to cancel the cycle and run the rinse cycle to get the soap off. Also, this model only has 3 cycles, pots and pans, regular and rinse and hold and there is no timer to indicate how long it has left.
  #4 (permalink)
Old 11-05-2013, 05:52 PM
Senior Member
Default
The continuous cycling more then likely could be the main control that's the case in most situations on these bosch models. The luke warm water could be your heater or something in your heat cycle or your water supply leading to the unit. The heater not working though could be the main board not sending voltage to the heater if you have an amp clamp test the amp pull to the heater wire and you should get around 8 amps give or take a couple amps if you do then the heating circuit should be fine. Test the thermistor too on the unit make sure you got a complete circuit on that as well here's your parts for identifying things.
Parts for Bosch SHX33A05 UC/14 (FD 8211-) Dishwasher - AppliancePartsPros.com
Here's some video's for bosch's to help you as well.
bosch dishwasher never stops - YouTube
  #5 (permalink)
Old 01-06-2016, 10:19 AM
Junior Member
gpiotto44 is on a distinguished road
Default Bosch SHE42L runs a long time
I found this website that has great pictures showing a problem with one of the solders on the control board going bad. Re-soldering or installing a new board appears to have solved the problem for quite a few folks on various Bosch models.
Bosch SHU43 Dishwasher Repair - Dishwasher keeps running (Stuff)
For the model SHE42L it is a little tricky getting the control module out. It is an enclosed plastic box. You first have to separate the metal mounting bracket from the plastic face. There is a clip on either end that you have to release. Then you can remove the mounting. Flip it over and there are two clips that hold the plastic control box to the mounting. To open the control box you must release several clips that are in little slots below where the wiring clips go. Then you have to gently pry the box open as there are two hidden clips on the sides that I see no way of depressing. Once open there are two clips on either side of the board to release the board from its plastic box.
After doing all that I saw the same burned out solder connection that are shown at the link I provided above. Unfortunately for me there is nothing left of the little wire to re-solder it to the board. So, I think I must buy a new control unit.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Bosch Dishwasher Runs for hours..white film on dishes tklmnesser Dishwasher Repair 1 04-26-2013 11:05 PM
Dishwasher runs every 2 hours & can't cancel it! Abobb Dishwasher Repair 1 07-31-2012 06:38 PM
Bosch dishwasher stalls at 1 minute for hours and then dishes don't dry. rdelbell Dishwasher Repair 0 04-27-2012 03:41 PM
Bosch Dishwasher (Model SHX46B05UC/14) is running 3+ hours... pvan Dishwasher Repair 2 01-17-2012 11:23 AM
bosch dishwasher runs for 5+ hours acktorelax Dishwasher Repair 1 01-10-2012 08:02 PM
