Discuss
Lots of intermittent problems
 in
Dishwasher Repair
It started with the soap dispenser not opening, then that worked again. Then the auto wash cycle was starting at
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » Lots of intermittent problems
  #1 (permalink)
Old 10-31-2013, 03:33 PM
Junior Member
djtoo is on a distinguished road
Default Lots of intermittent problems
Model Number: she55m06uc/50   Brand: Bosch   Age: 5 - 10 years
It started with the soap dispenser not opening, then that worked again. Then the auto wash cycle was starting at anywhere from 134 minutes to 158 minutes, then that went back to between 110 & 125. Then it went down to 1 minute left and stayed there and kept running, that went away. Then it stopped heating the water and is staying that way. All of the other problems were off and on. It fills o.k. and drains o.k. If I stop and open it during a cycle and then restart it the time may go up as much as 20 minutes.
Is this a control board problem and if so which one? Any suggestions would be greatly appreciated.
Related Models
Whirlpool SHF3801W0 Dishwasher
Whirlpool SHF3804W2 Dishwasher
Whirlpool SHF4500W0 Dishwasher
Whirlpool SHF5500W0 Dishwasher
Whirlpool SHF5501W0 Dishwasher
Whirlpool SHF5504W0 Dishwasher
Whirlpool SHF5584P1 Dishwasher
Whirlpool SHF5584P2 Dishwasher
Whirlpool SHF5801W0 Dishwasher
Whirlpool SHF5801W1 Dishwasher
Whirlpool SHF5884P1 Dishwasher
Whirlpool SHF5884P2 Dishwasher
Whirlpool SHF7800W0 Dishwasher
Whirlpool SHF7801W0 Dishwasher
Whirlpool SHF7804W1 Dishwasher
Whirlpool SHF7884P0 Dishwasher
Whirlpool SHF7884P1 Dishwasher
Whirlpool SHF7884P2 Dishwasher
Bosch SHI4302 UC/06 -FD8002
Bosch SHI4302 UC/11 -FD8003
Bosch SHI4302 UC/12
Bosch SHI4306 UC/06 -FD8002
Bosch SHI4306 UC/11 -FD8003
Bosch SHI4306 UC/12
Bosch SHI66A05 UC/14 (FD 8211-)
Bosch SHI6802 UC/06
Bosch SHI6802 UC/11
Bosch SHI6802 UC/12
Bosch SHI6805 UC/06
Bosch SHI6805 UC/11
Bosch SHI6805 UC/12
Bosch SHI6806 UC/06
Bosch SHI6806 UC/11
Bosch SHI6806 UC/12
Whirlpool SHU30011 DISHWASHER
Bosch SHU3002
Whirlpool SHU30041 DISHWASHER
Bosch SHU3006
Bosch SHU3012
Whirlpool SHU30140 DISHWASHER
Whirlpool SHU30141 DISHWASHER
Bosch SHU3016
Bosch SHU3032 UC/06 (FD 7908-8002)
Bosch SHU3032 UC/11 (FD 8002-8003)
Bosch SHU3032 UC/12 (FD 8003-)
Bosch SHU3035 UC/12 (FD 8006-)
Bosch SHU3036 UC/06 (FD 7908-8002)
Bosch SHU3036 UC/11 (FD 8002-8003)
Bosch SHU3036 UC/12 (FD 8003-)
Bosch SHU3132 UC/12 (FD 8105-)
Bosch SHU3135 UC/12 (FD 8105-)
Bosch SHU3136 UC/12 (FD 8105-)
Bosch SHU3302 UC/06 (FD 7902-8003)
Bosch SHU3302 UC/11 (FD 8003-8003)
Bosch SHU3302 UC/12 (FD 8003 -)
Bosch SHU3305 UC/06 (FD 7902-8003)
Bosch SHU3305 UC/11 (FD 8003-8003)
Bosch SHU3305 UC/12 (FD 8003 -)
Bosch SHU3306 UC/06 (FD 7902-8003)
Bosch SHU3306 UC/11 (FD 8003-8003)
Bosch SHU3306 UC/12 (FD 8003 -)
Bosch SHU3307 UC/12 (FD 8005 -)
Bosch SHU3322 UC/06
Bosch SHU3322 UC/11
Bosch SHU3322 UC/12
Bosch SHU3322 UC/12 (FD 8003-)
Bosch SHU3326 UC/06
Bosch SHU3326 UC/11
Bosch SHU3326 UC/12
Bosch SHU3326 UC/12 (FD 8003-)
Bosch SHU3336 UC/06
Bosch SHU3336 UC/11
Bosch SHU3336 UC/12
Bosch SHU3336 UC/12 (FD 8003-)
Bosch SHU33A02 UC/14 (FD 8211-)
Bosch SHU33A06 UC/14 (FD 8211-)
Bosch SHU33AC02 UC/14
Bosch SHU33AC06 UC/14
Whirlpool SHU40011 DISHWASHER
Bosch SHU4002 UC/06
Whirlpool SHU40041 DISHWASHER
Bosch SHU4006 UC/06
Bosch SHU4016 UC/06
Bosch SHU4022 UC/06
Bosch SHU4026 UC/06
Bosch SHU4036 UC/06
Bosch SHU4302 UC/06 (FD 7705-7912)
Bosch SHU4302 UC/11 (FD 8001-8003)
Bosch SHU4302 UC/12 (FD 8003-)
Bosch SHU4306 UC/06 (FD 7705-7912)
Bosch SHU4306 UC/11 (FD 8001-8003)
Bosch SHU4306 UC/12 (FD 8003-)
Bosch SHU4312 UC/06 (FD 7701-7912)
Bosch SHU4312 UC/11 (FD 8001-8003)
Bosch SHU4312 UC/12 (FD 8003-)
Bosch SHU4316 UC/06
Bosch SHU4316 UC/11
Bosch SHU4316 UC/12
Bosch SHU4322 UC/12
Bosch SHU4322 UC/12 (FD 8003-)
Bosch SHU4326 UC/12
Bosch SHU4326 UC/12 (FD 8003-)
Bosch SHU43C02 UC/14 (FD 8211-)
Bosch SHU43C05 UC/14 (FD 8211-)
Bosch SHU43C06 UC/14 (FD 8211-)
Bosch SHU43C07 UC/14 (FD 8211-)
Bosch SHU43E02 UC/14 (FD 8211-)
Bosch SHU43E05 UC/14 (FD 8211-)
Bosch SHU43E06 UC/14 (FD 8211-)
Bosch SHU43E07 UC/14 (FD 8211-)
Whirlpool SHU45010 Dishwasher
Whirlpool SHU45020 Dishwasher
Whirlpool SHU50041 Dishwasher
Whirlpool SHU50043 Dishwasher
Bosch SHU5302 UC/06 (FD 7705-7912)
Bosch SHU5302 UC/11 (FD 8001-8003)
Bosch SHU5302 UC/12 (FD 8003-)
Bosch SHU5304 UC/06 (FD 7705-7912)
Bosch SHU5304 UC/11 (FD 8001-8003)
Bosch SHU5304 UC/12 (FD 8003-)
  #2 (permalink)
Old 11-02-2013, 01:38 PM
Junior Member
jwicklin is on a distinguished road
Default
Manufacturer's module number for that unit is 00641945 Appliance Parts Pro number is AP4298189. Before you buy the control module verify that you actually have circulation. If water isn't circulating it could cause a lot of these other problems because limit switches aren't being tripped. After the water fills it should start to circulate right away. If you open the door and the spray arms aren't coming to a stop as you open it they weren't turning. You should also be able to hear the water circulating if you listen closely. If the motor is turning but the water isn't circulating you most likely have an impeller failure.
  #3 (permalink)
Old 11-03-2013, 09:07 AM
Junior Member
Default
Thanks, I'll run it and check to make sure the spray arms are turning.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
GE Washer intermittent problems zjw2112 Washer Repair 1 10-27-2013 05:37 AM
Intermittent washer problems rscha787 Washer Repair 1 10-14-2011 06:24 PM
Kitchenaid intermittent cycle problems Superburner Dishwasher Repair 0 04-11-2011 08:31 PM
HE4T intermittent power problems jayusa123 Dryer Repair 0 10-13-2010 04:34 PM
One part causing many problems, or just lots of problems? Woogy Oven Repair (including Ranges and Cooktops) 1 10-07-2008 12:52 PM
