Discuss
Loose screws found in Frigidaire dishwasher drain
 in
Dishwasher Repair
Hi everybody this is my first post so thank you for any help that you can provide I recently had
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » Loose screws found in Frigidaire dishwasher drain
  #1 (permalink)
Old 10-22-2013, 08:39 AM
Junior Member
Jspirritano is on a distinguished road
Default Loose screws found in Frigidaire dishwasher drain
Brand: Frigidaire   Age: 1 - 5 years
Hi everybody this is my first post so thank you for any help that you can provide I recently had issues with cloudiness and spotting on my dishes on my dishwasher so I decided to do some maintenance on it. I opened it all up decided to clean out the drain and everything make sure everything was okay and when I pulled everything out I noticed 2 loose screws in the bottom of the dishwasher underneath the mesh screen, just sitting at the very bottom beginning to cause rust. Does anybody have any clue where the screws could have come from? and is there any way that they may actually have come from my disposal, and worked their way back through the drain and into the dishwasher, the only reason I'm wondering this is because my disposal also just started making some clunky rattling noises. I did remove the screws and clean up everything in the dishwasher and it still creating cloudiness on the dishes so my problem has not been resolved.
  #2 (permalink)
Old 10-24-2013, 04:02 AM
Senior Expert
APP Volunteer
denman is a splendid one to behold
Default
A model number may help others help you.
Or at least you should be able to look at a parts breakdown and perhaps see where the screws came from.
Find your model number - AppliancePartsPros.com
I cannot say where they came from but since they were rusting I doubt they are from inside the dishwasher.
Again I cannot say but I doubt it. It depends how your disposal is hooked up.
Usually the drain hose is looped up higher that the drain entrance at the disposal so the screws would of had to travel up hill.
Is the rinse aid operating?
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Need Quick Help!!! Found white plastic ball in drain...is this a part? beathorne Dishwasher Repair 2 01-05-2018 03:55 PM
Kenmore stackable sounds like loose screws merc1100sc Dryer Repair 7 07-16-2012 07:23 AM
Washer won't drain, new pump, not clogged; brass pin found? MikeMc7734 Washer Repair 1 05-14-2011 12:32 PM
Screws and inserts for Frigidaire oven door edwinkler Oven Repair (including Ranges and Cooktops) 3 08-31-2009 05:50 PM
trying to replace water actuator on FRS26HF7BB2 frigidaire. Screws rusted help michram1 Refrigerator & Freezer Repair 3 06-18-2009 08:28 AM
