Discuss
circulation pump
 in
Dishwasher Repair
ordered replacement pump AP28263484 Have issue with wiring existing pump on dishwasher has a blue wire connected to one side
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » circulation pump
  #1 (permalink)
Old 10-21-2013, 02:15 PM
Junior Member
bobscan is on a distinguished road
Unhappy circulation pump
Model Number: shx46a05   Brand: Bosch   Age: 5 - 10 years
Have issue with wiring existing pump on dishwasher has a blue wire connected to one side of the capacitor . New motor has no terminal for blue wire.
Is this the correct motor?
What do i do with wire?
Related Models
Bosch SHX46A05 UC/14 (FD 8211-)
Bosch SHX46A06 UC/14 (FD 8211-)
Bosch SHX46A07 UC/14 (FD 8211-)
Bosch SHX46B02 UC/14 (FD 8211-)
Bosch SHX46B05 UC/14 (FD 8211-)
Bosch SHX46B06 UC/14 (FD 8211-)
Bosch SHX46B07 UC/14 (FD 8211-)
Bosch SHX56B02 UC/14 (FD 8211-)
Bosch SHX56B05 UC/14 (FD 8211-)
Bosch SHX56B06 UC/14 (FD 8211-)
Bosch SHX99B05 UC/14 (FD 8212-)
Bosch SHX99B06 UC/14 (FD 8212-)
Bosch SHY56A02 UC/14 (FD8301-)
Bosch SHY56A05 UC/14 (FD8301-)
Bosch SHY56A06 UC/14 (FD8301-)
Bosch SHY66C02 UC/14 (FD8301-)
Bosch SHY66C05 UC/14 (FD8301-)
Bosch SHY66C06 UC/14 (FD8301-)
Bosch SHY99A02 UC/14 (FD 8212-)
Bosch SHY99A05 UC/14 (FD 8212-)
Bosch SHY99A06 UC/14 (FD 8212-)
Amana SI19E REF - SXS/I&W
General Electric SIG140060B SIGNATURE REFRIGERATOR
General Electric SIG1480A66WH DISHWASHER
General Electric SIG1482A68BA DISHWASHER
General Electric SIG60100T0WG SIGNATURE WASHER
General Electric SIG7010ET0WG SIGNATURE ELECTRIC DRYER
General Electric SIG7010ET1WG Electric dryer
Admiral SILVER22 REF - SXS/I&W
Admiral SILVER24 REF - SXS/I&W
Maytag SK525-2W REF - SXS
Maytag SK535-2 REF - SXS/I&W
Gaggenau SK590-2 REF - BOTTOM MOUNTS
Hardwick SKG4622MGA639R RANGE-F/S CONT CLEAN GAS
Hardwick SKG4622MGW639R RANGE-F/S CONT CLEAN GAS
Hardwick SKG9611A540R RANGE-F/S CONT CLEAN GAS
Hardwick SKG9611W540R RANGE-F/S CONT CLEAN GAS
Amana SKI22F REF - SXS/I&W
Amana SKI22F-A REF - SXS/I&W
Amana SKI22F-C REF - SXS/I&W
Amana SKI22F-G REF - SXS/I&W
Amana SKI22FL REF - SXS/I&W
Hardwick SKJ7141819DE WALLOVEN- CONT CLEAN GAS
Maytag SL10AN-A01 STACKED LAUNDRY- ELE
Maytag SL10AN-A02 STACKED LAUNDRY- ELE
Maytag SL10AN-A03 STACKED LAUNDRY- ELE
Maytag SL11AA STACKED LAUNDRY- ELE
Maytag SL11AN STACKED LAUNDRY- ELE
General Electric SL208 Room air conditioner
General Electric SL210 Room air conditioner
General Electric SL212 Room air conditioner
General Electric SL214 Room air conditioner
General Electric SL217 Room air conditioner
General Electric SL220 Room air conditioner
General Electric SL223 Room air conditioner
Amana SL22F REF - SXS/I&W
Amana SL22F-A REF - SXS/I&W
Amana SL22F-C REF - SXS/I&W
Amana SL22F-G REF - SXS/I&W
Amana SL22F-L REF - SXS/I&W
Amana SL22G REF - SXS/I&W
Amana SL22GL REF - SXS/I&W
Amana SL22JB REF - SXS/I&W
Amana SL22JB Ref - SXS/I&W
Amana SL22MBG REF - SXS/I&W
Amana SL22MBL REF - SXS/I&W
Amana SL22MBW REF - SXS/I&W
Amana SL25G REF - SXS/I&W
Amana SL25GL REF - SXS/I&W
Amana SL25H REF - SXS/I&W
Amana SL25J REF - SXS/I&W
Amana SL25J Ref - SXS/I&W
Amana SL25M2L REF - SXS/I&W
Amana SL25M2W REF - SXS/I&W
Amana SL25MG REF - SXS/I&W
Amana SL25ML REF - SXS/I&W
Amana SL25MW REF - SXS/I&W
Amana SLD22JB REF - SXS/I&W
Amana SLD22MB2L REF - SXS/I&W
Amana SLD22MB2W REF - SXS/I&W
Amana SLD22MBG REF - SXS/I&W
Amana SLD22MBL REF - SXS/I&W
Amana SLD22MBW REF - SXS/I&W
Amana SLD25J REF - SXS/I&W
Amana SLD25JB REF - SXS/I&W
Amana SLD25JP REF - SXS/I&W
Amana SLD25M2G REF - SXS/I&W
Amana SLD25M2L REF - SXS/I&W
  #2 (permalink)
Old 10-29-2013, 01:37 PM
Junior Member
jwicklin is on a distinguished road
Default
For this model the violet wire goes from terminal 3 of the circulation motor to terminal 2 of the door switch. There should be a black wire on the dishwasher (comes from control board) that you need to connect to terminal one of the motor. Those two wires and the green ground wire are all that you should have to disconnect / connect when replacing the motor & capacitor as a unit.
Terminals 2 & 3 of the motor are common to each other. There should be a spade connector that has two wires one of these wires leads to one terminal of the capacitor the other wire goes to the motor windings. Wiring diagram doesn't list colors for these (presumably because motor and capacitor are purchased together and thus come prewired). This spade connector per the diagram should be connected to terminal 2 of the motor. The wire coming from the other side of the capacitor goes to the other side of the motor windings. I don't think these capacitors are polarized however if you do see a negative terminal marking that side of the capacitor should be connected to the wire going to terminal 2 of the motor since 2 & 3 are connected to each other and 3 is routed to the negative side of the power switch.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Circulation Pump not working Rick in Pittsburgh Dishwasher Repair 1 09-09-2015 02:53 PM
Circulation Pump Mark Rininger Dishwasher Repair 1 04-17-2012 04:15 PM
Circulation Pump the problem? fused Dishwasher Repair 0 02-04-2012 08:03 AM
YES, Bad circulation pump on the SHU9922, NOW WHAT mspeed777 Dishwasher Repair 0 11-23-2008 07:37 PM
Circulation pump berg Dishwasher Repair 0 06-13-2008 12:08 PM
