Diswasher only displays Quick clean up cycle and Energy saver dry. cannot change cycles or dry modes. 4 hour delay seems to still work. Any suggestions?
Other posts have noted similar problems with the control panel the control lock is activated. If so hold air dry down for 5 - 10 seconds to release the lock.
Control lock works fine. Tried multiple times to switch cycles but no luck. Originally Posted by: csager Other posts have noted similar problems with the control panel the control lock is activated. If so hold air dry down for 5 - 10 seconds to release the lock.
Here are your parts Replacement parts for WHIRLPOOL KUDS01DLSS0 | AppliancePartsPros.comHere is the tech sheet run the diagnostics. http://www.servicematters.com/d...0Sheet%20-%208533399.pdfClean the connections as shown below. Check the keyboard with a meter. If the keyboard checks out OK then the control board comes to the top of the list as the cause. Connector Cleaning Unplug the unit Open it up Remove the ribbon cable from the keypad to the control board at the control board. Clean the edge connector. If it is the type where there is not a connector just the insulation is removed, it can be cleaned with a pencil eraser. Do not use an ink eraser as it is too abrasive. Check the tracks in the ribbon cable for hairline cracks. A magnifying glass helps here. Would not hurt to clean the connector on the board. Use electronics contact cleaner or isopropyl alcohol and a tooth brush. Be gentle and do not reconnect till all the solvent evaporates. Reconnect everything and give it a try. |
THIS FORUM IS DEAD!!!!!!! |
Thanks for the tech sheet, I will try to use it and your advise this weekend. Thanks once again!
You are welcome
Please let us know how it goes. |
