Discuss
Control lock light blinking and won' t reset
 in
Dishwasher Repair
We have a Whirlpool Gold Quiet Partner IV dishwasher. A green light above the air dry button is blinking. To
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » Control lock light blinking and won' t reset
  #1 (permalink)
Old 10-05-2013, 09:02 AM
Junior Member
Ford4000 is on a distinguished road
Default Control lock light blinking and won' t reset
Brand: Whirlpool   Age: 5 - 10 years
We have a Whirlpool Gold Quiet Partner IV dishwasher. A green light above the air dry button is blinking. To the right of the air dry button is "control lock press &hold" . The dishwasher will not start now. The cycle time display shows 2 dashes. If you push the air dry button, the light above the "rinse only" button starts blinking. Pushing any other buttons changes nothing on the display.
Help!!!
  #2 (permalink)
Old 10-06-2013, 06:50 AM
Senior Expert
APP Volunteer
denman is a splendid one to behold
Default
A model number may help others help you.
Usually this type of problem is either the control panel (keypad) or the control board.
The normal way to trouble shoot is to check the keypad outputs if they are good then replace the control board.
Still a bit of a crap shoot but odds are better that you will replace the correct part the first time.
__________________
  #3 (permalink)
Old 10-06-2013, 08:52 AM
Junior Member
Default Model number
Is gu1500xtks0 for our whirlpool gold quiet partner IV
  #4 (permalink)
Old 10-06-2013, 09:16 AM
Senior Expert
APP Volunteer
Default
Parts for Whirlpool GU1500XTKS0 Dishwasher - AppliancePartsPros.com
It has the keypad outputs.
Have you tried unplugging it or flipping it's breaker off for a couple minutes to see if it will reset?
__________________
  #5 (permalink)
Old 10-06-2013, 09:50 AM
Junior Member
Default Control lock light blinking and won't reset
Thanks! We tried resetting breaker and leaving it off for a while. No change at all. I appreciate your reply.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
GE dishwasher Reset light blinking will not reset when pressed and unit is not workin Caesar100 Dishwasher Repair 0 01-07-2012 01:04 PM
Samsung dishwasher heavy light is blinking and won't reset jakeerik Dishwasher Repair 1 11-03-2011 09:06 AM
KitchenAid Clean Light blinking 7 times, after reset, motor sounds.. netaron Dishwasher Repair 2 05-10-2011 10:07 AM
Blinking lock light msolty Dishwasher Repair 0 06-26-2010 02:55 PM
Clean light blinking, reset doesn work Steven1 Dishwasher Repair 0 04-18-2010 06:57 PM
