The control unit on my dish washer stalls and has to be helped (by hand) onto its next cycle. Should I purchase a new control unit Part # 264177 or a Switch-Selector Part # 265997. to fix this problem or is there some other part I need. Also, today I have had a flooded floor resulting from water building up in the dish washer even though the machine is switched off. Could this be a faulty inlet valve or dirt having got into the valve and how does one go about replacing or cleaning the valve? I have had to shut the hot water shut off valve off to stop the water flow. Help would be appreciated. Thanks, JWF:mad:
